• Support PF! Buy your school textbooks, materials and every day products Here!
PSI and Pascals for pressure
This isnt anything course related but i was just curious, why do we use several units for pressure? Primarily PSI and Pascals? Theyre both units used to measure pressure, but why are 2 units used? What are they similarities and differences? and where are they used?(situations scenarios) and what do they both mean? (i suppose psi = pounds per square inch so pressure per inch on a surface or object?)
Answers and Replies
PhanthomJay
502
The United States and Myanmar use psi for pressure units, while all other countries (with a few holdouts)use Pascals (Newtons/square meter). The US system is the old Imperial System (Customary Units) which uses pounds as the force unit and feet or inches as the length unit (like 1 foot = 12 inches), whereas other countries use the more modern SI or Metric System units which uses Newtons as the force unit and meters as the length unit. (like 1 meter = 100 cm = 1000 mm). The SI system is easier to use because it is decimal based, whereas the US system is a random set of units. You can convert from one system to another by using conversion factors (like 1 meter = 3.28 feet). The Federal government of the US tried to mandate the SI conversion about 40 years ago, but failed to do so to this day, partly for ecomomic reasons associated with the change, and partly due to fierce opposition from engineers and contractors unfamiliar with SI. It is unlikely that full conversion to metric in the USA will take place in the foreseeable future, although manuals list values in both systems of measure just in case. Pressure values are units of force per unit area, like tire pressure, pump pressure, water pressure, or stresses in materials.
Just a tip: The title should give a hint of content in the thread.
Yes i agree, also one can click the little "+" to see whats in the thread before even opening it to see whats in it.
Related Threads on PSI and Pascals for pressure
  • Last Post
  • Last Post
  • Last Post
  • Last Post
