What is the acceleration of the blocks in a pulley constraint problem?
In summary: Is it 2(x1-x2)+ x3 = l ? You'd have subtract that little bit of string attached to p1 and p2 so 2(x1-x2)+ x3 = l+2q , so i differentiate twice and I'll...Yes
Vriska
138
Need to find the acceleration of the blocks, all surfaces are smooth : https://drive.google.com/file/d/0B5bF4yPQOejoazhWeEgySmtfSnc/view?usp=drivesdk
a1 + a2 + a3 =0 (acceleration of strings lengths must sum to zero)
F = ma
Acceleration of topmost string = a_a(acceleration of block a)
- a_b (is this right? I feel like this should be right but idk why)Acceleration of middle string also must be the same
And acceleration of bottom string is simply T (where T is tension in the string, assuming mass is 1)
3T = 4a_b (for block b), F - 2T = 2a_a, T = a_c.
Solving all this gives me the wrong answer : /I'm suspecting somethings wrong with the first step, is it?
F = ma
If the problem is asking for the acceleration of the 3 block system as a whole, the solution is a lot simpler than you think.
What would that mean? The acceleration of the centre of mass of the system? I'm not sure whether that fact helps
Yes, what is the acceleration of the center of mass of the system (if that is what the problem is asking...please post the question exactly as given)
It's asking the individual acceleration of the blocks unfortunately
Oh. In which case, it seems like the best way to proceed is to take free body diagrams of each block and solve for the accelerations of each block with respect to the ground.
Isn't that what i did? Isnt giving me the right answer
Hello ,
Next time please try and upload image on PF using upload button .
Your constraint equation isn't correct . Can you express the length of the string in terms of the displacements of the three blocks .
conscience said:
Hello ,
Hi
I had significant difficulty in uploading the image so i had to use drive : /. In terms of displacement you say? I'm finding it difficult but so far I've got this : change in top length of string = x_a(displacement of a) - x_b, change in middle length of string =x_a-x_b + x_c, change in bottom string in just x_c, they should all sum to zero right?
Vriska said:
Hi
No .
Place your coordinate system to the right of block B . Left direction is taken positive. Let A at any instant be at distance x1 from origin , B at x2 , C at x3 .
Use a pen and a paper , think carefully and tell what is the length of the string in terms of x1,x2,x3 ?
conscience said:
No .
Is it 2(x1-x2)+ x3 = l ? You'd have subtract that little bit of string attached to p1 and p2 so 2(x1-x2)+ x3 = l+2q , so i differentiate twice and I'll get constraints. Thank you
No . Aren't both blocks B and C moving :wink: ?
Right, x2 - x3 then?
Should that be x3 - x2 ?
Yes! So now my equations are :
2(a1-a2)+a3-a2= 0,
1 - 2T =2a1, (assyming F = 1 and m = 1
3T =4a2,
T =-a3 (minus because its going opposite to coordinate system)
Does this look alright? I'm not getting the right answer. (except for block b whose accleartion is equal to that of the centre of mass, is this a coincidence?)
What is the direction of tension on C ? In F= Ma , you put a sign on the force , not on the acceleration term :smile:
Ah that makes more sense. Rest of the equations are alright right?
What are you getting ?
a1 =13/42, according to the book its 4/21 (at F=1, m =1)
I am getting a1 = 13F/42m , a2 = F/7m , a3= -4F/21 .
May be the answer key is wrong .
What is the name of the book ?
Thank you for your help, I've been struggling with these constraints problems for quite sometime, now it makes sense . It looks like my books actually wrong, its a nondescript college issued workbook. Oh btw is the fact that accleartion of block b = acceleration of centre of mass a complete coincidence?
Edit : it isn't! When i change b to 5, the acceleration of cm is 1/8, as expected! Why is this happening?
Mathematically they have same value in this problem.But that is due to string constraint and for the particular masses as given in the problem .
The CM of the system has a different location than that of block B , but due to string constraint and specific value of the masses as given in the problem, their accelerations are turning out to be same .Quite interesting !
1. What is a pulley constraint problem?
A pulley constraint problem refers to a mechanical engineering problem that involves finding the forces and movements in a system of pulleys connected by ropes or cables. The objective is to determine the tensions in the ropes and the direction of motion of the pulleys.
2. What are the types of pulley constraints?
There are two main types of pulley constraints: fixed pulley and movable pulley. In a fixed pulley, the pulley is attached to a fixed point and only changes the direction of the force. In a movable pulley, the pulley is attached to the object being moved and changes both the direction and magnitude of the force.
3. How do you solve a pulley constraint problem?
To solve a pulley constraint problem, you need to first draw a free-body diagram of the system, showing all the forces acting on each pulley and rope. Then, apply the equations of motion and equilibrium to determine the unknown forces and movements. Finally, check your solution for consistency and accuracy.
4. What are the common assumptions made in solving pulley constraint problems?
The most common assumptions made in solving pulley constraint problems are: the ropes and pulleys are massless, there is no friction between the ropes and pulleys, and the ropes do not stretch or break. These assumptions simplify the problem and provide a good approximation in most practical situations.
5. Can pulley constraint problems be solved using software?
Yes, there are various software programs available that can solve pulley constraint problems. These programs use numerical methods and algorithms to solve complex systems of pulleys and ropes. However, it is still important to understand the underlying principles and equations used in solving these problems in order to properly interpret and verify the results.
