Why are the accelerations of blocks A and B different in this pulley problem?
  • Thread starter PineApple2
  • Tags
    Pulley
In summary: I actually did try to do it with a friend and we were so confused by the different accelerations that wecouldn't figure out which way it was going.In summary, the problem involves two masses connected by a rope over a pulley. The pulley allows the rope to move, resulting in different accelerations for the two masses. This is demonstrated in parts B and C, where the force applied to the rope is enough to lift one mass but not the other. This illustrates the independence of the masses due to the pulley.
PineApple2
49
It is not actually homework, but a physics problem I have encountered. For ease of discussion, I am attaching the question [University Physics, Young and Freedman, 12th edition] and it's solution as appeared in the solutions manual.
What I don't understand is: In section (c), how can the accelerations of blocks A and B be different? They are connected by the same string. Doesn't it imply (by geometrical considerations, the string length remains the same) that the accelerations are also the same?
  • question.pdf
But they're on a pulley--the string isn't fixed to anything but the two masses.
Look at part B as well--you're applying enough force to lift only one of the masses [EVEN THOUGH the total force (294N) is the same as the combined two gravitational forces 9.8(20 + 10) = 294 N]. But this force is divded equally between the two, so each feels 147N. The smaller mass will surely lift then. However you're not applying enough for the other mass. This mass will stay on the ground. This implies different accelerations. It is the same in part C, but you're now applying just enough force to lift the bigger block, but that is still more than enough to lift the smaller one.
It is applying an equal force to each of the two masses (different masses + equal forces = different accelerations)If both masses were simply tied to a string your analysis would be in the right direction because they're basically one mass. You'd be able to model it as if they were one mass of combined mass m_a + m_b. The pulley, however, makes them independent.
but it IS the same rope connecting the 2 masses over the pulley. Do the different accelerations mean the rope is not taut?
It is the same rope but it can slide along the pulley--meaning you can be pulling up the lighter mass, making that part of the string shorter, while increasing the amount of string on the side of the heavier. The rope is taut the whole time, it just isn't able to lift up the heavier mass while it is able to lift up the lighter mass.
Do you see the difference? In a situation where the pulley was replaced by a knot, you couldn't have the rope moving like that, but since the pulley is there, you can, and since the rope can move, the accelerations on the masses can be different.
This is the kind of problem that you should try to model in the real world, if you're in a physics class go ask to borrow a pulley and do an analog to this experiment and you'll be able to see that one mass can move while the other stays stationary (due to the different accelerations)
You're thinking about the system like this:
Code:
                | <-- rope
               & <-- knot
          M1     M2
But it is this:
Code:
                | <-- rope
               O <-- pulley
          M1     M2
With parts b and c of that problem making it look like this eventually:
Code:
                | <-- rope
               O <-- pulley
             /    M2
          M1
You're right. My problem was that I imagined the rope not slipping. But since it can slip, the accelerations can be different.
Thanks!
No problem, sorry my wording was confusing in the first post :smile:
Funny...
1. How does a pulley lift an object upwards?
A pulley uses a combination of tension and friction to lift an object upwards. When a force is applied to one end of the rope, the tension in the rope transfers that force to the other end, which is attached to the object. Friction between the rope and the pulley also helps to prevent the object from sliding down.
2. What are the advantages of using a pulley to lift an object upwards?
One advantage of using a pulley to lift an object upwards is that it allows a single person to lift heavier objects than they could on their own. Additionally, using a pulley can also help distribute the weight of the object more evenly, making it easier to lift and maneuver.
3. What factors affect the lifting capacity of a pulley?
The lifting capacity of a pulley is affected by the number of pulleys used, the angle of the rope, and the amount of friction in the system. Generally, the more pulleys used, the easier it is to lift an object, but this also increases the length of rope needed. A smaller angle of the rope also increases lifting capacity, while too much friction can make it more difficult to lift an object.
4. How can I calculate the mechanical advantage of a pulley system?
To calculate the mechanical advantage of a pulley system, divide the weight of the object being lifted by the amount of force needed to lift it. This will give you the mechanical advantage, which represents the number of times the force is multiplied by using the pulley system. For example, a mechanical advantage of 5 means that the force applied is multiplied by 5 to lift the object.
5. Are there different types of pulley systems for lifting objects upwards?
Yes, there are three main types of pulley systems: fixed, movable, and compound. A fixed pulley has a stationary axle and is used to change the direction of the force being applied. A movable pulley has a pulley attached to the object being lifted and is used to decrease the amount of force needed. A compound pulley combines fixed and movable pulleys to increase the mechanical advantage and make lifting heavier objects easier.
