Homework Help: Pulley problem
  1. Mar 9, 2005 #1
    tony873004
    A box of mass M = 5.7 kg is suspended by a rope over a pulley (Figure 5.64). Find the tension in the rope supporting the box and in the rope supporting the pulley.
    The tension in the rope supporting the box should just be mg? right?
    But the two labeled angles are not the same. Combined, they must be equal to -mg or the pulley would accelerate. But without knowing theta angle, I'm not sure how to do this? Do they want the tension of the rope supporting the pulley to be expressed in terms of something else, or is it possible to come up with a precise number in Newtons?
  3. Mar 9, 2005 #2
    Doc Al
    Staff: Mentor
    Right.
    Hint: the tension in the rope wrapped around the pulley is the same throughout.
  4. Mar 9, 2005 #3
    tony873004
    Hi, DocAl. Thanks for your reply. I got an answer. Can you tell me if I did it correctly.
    It would seem to me that tension in the rope attached to the box would just be mg.
    So the rope supporting the weight would have a tension of mg in the y direction and 0 in the x direction.
    The rope after it passes through the pulley also has a tension of mg which can be broken up into its components by fx = mg cos 37, and fy = mg sin 37.
    Adding this to the components of the part of the rope holding the box, I get
    fx = cos37 * 5.7 * 9.9
    fy = sin37 * 5.7*9.8 + 5.7 * 9.8
    which should be the resultant force (tension in the other rope) needed to make sure the pulley does not accelerate. Plugging it into the calculator:
    fx = 44.61 N
    fy = 89.48 N
    Using pothag, tension in the other rope is sqr (44.612 + 89.482) = 99.98 N.
    So the final answer:
    tension in the rope supporting the box = 55.86 N away from the box
    tension in the rope supporting the pulley = 99.93 N away from the pulley
    Did I do it right??
    And tension is a force, therefore a vector. Is it correct to give it direction. For example, the one attached to the box pulls in both directions. It pulls the box up and it pulls the pulley down. Or should I express tension as a scalar and not worry about direction?
  5. Mar 9, 2005 #4
    Doc Al
    Staff: Mentor
    Looks good to me. (See comments below about describing tension.)
    The force exerted by a rope (due to the tension in the rope) is of course a vector. The direction of the force is along the line of the rope (and ropes can only pull). But the tension is a property of the rope, best described as a scalar. (As long as there is no danger of confusion, it's standard to refer to the force exerted by the rope as "the tension", but that's not strictly accurate.)
  6. Mar 9, 2005 #5
    Just wait untill you get into pulles that have mass. You thought this was fun. It gets more fun.
    Regards,
    Nenad
  7. Mar 10, 2005 #6
    arildno
    Dearly Missed
    It gets even more fun when the ropes are given mass..:wink:
