Find Applied Force: Mass, Accel Given
In summary, the problem involves finding the applied force needed to open a window with a mass of 4.5 kg and accelerate it at 0.25 m/s^2. Using Newton's 2nd law and taking into account the weight of the window and the tension in the cord, a value of 12.825 N is obtained for the applied force. A second equation can be obtained by considering the forces acting on the 3 kg mass and applying Newton's 2nd law again.
Coco12
272
The mass of the two objects on both sides if the pulley is given. So is the acceleration to start moving. It's asking to find the applied force. How do I do that?
Mass of 1- 4.5kg
Mass if 2- 3.0 kg
How much force must u exert to get M1 to accelerate at .25m/s2
Fnet= ma
-F1g+ f2g= (m1+m2)a
I tried putting Fa into the fnet equation and solving for Fa but. It's not working??
4.5(a) = 4.5(9.8) - 3(9.8) - F
if a = .25
F = 13.575 Newtons added to mass 2 in order to slow the decent of mass 1 to .25m/s^2. Assuming frictionless pulley.
The answer is supposed to be 17N
if a = .25
It's just asking the applied force needed to open the window which is M1
The other person who replied said that you need to add what they got (13.575) to M2, which is 3
Rounding that gives you 17
-F
-3(9.8) + T = 3a
4.5(9.8) - T = 4.5a
-F -3(9.8) +4.5(9.8) = 7.5a
solve for F the force.
12.825 Newtons
Solutions should be attempted by the requestor, not the responder.
Draw free body diagrams of each mass, and apply Newton's Laws to each mass.
The book answer looks correct.
Just wondering why is the force F- and why the 4.5(9.8) isn't negative since that's on the left side of the pulley?? The applied force is going up the pulley on the left so..
Ok so m1 is the 4.5 Kg window on the left, its weight acts down on it, you apply a force F upward on it to open it, and together with the cord tension acting up on it, it accelerates up at 0.25 m/s^2. Apply Newton's 2nd law, and continue on , next identifying the net force acting on m2 which accelerates m2 downward at 0.25 m/s^2...
Ok I understand it now however why do u have to add the mass to the 12.825N ? How can u add mass to a N force?
You can't. You should attempt the problem yourself rather than follow someone elses work.
Let's look again at the window, which has a mass m1 = 4.5 kg. Draw a free body diagram. The windows weight, m1(g) acts down. You apply a Force F, up. The tension, T, in the cord acts up (tension forces always pull away from the objects on which they act).
Now apply Newton's 2nd law, F_net = ma, thus
F + T -(m1)g = m1(a)
That is your first equation. You know m1, g, and a, but you still have 2 unknowns, F and T, so you need a second equation. You can get that second equation by drawing a free body diagram of m2, the 3 kg mass, and identifying the forces acting on it, and applying Newton's 2nd law. What do you get?
Likes 1 person
What is the equation for finding applied force with mass and acceleration given?
The equation is F = m*a, where F represents the applied force, m represents the mass, and a represents the acceleration.
What is the unit for force in this equation?
The unit for force is Newtons (N).
Can you use this equation to find the applied force in any situation?
No, this equation is specifically for finding applied force when the mass and acceleration are given. It cannot be used for other situations such as finding acceleration or mass.
How do you calculate the applied force if the mass is not given?
To calculate the applied force without knowing the mass, you would need to use a different equation, such as F = m*a, where F represents the applied force, m represents the mass, and a represents the acceleration.
Is the applied force always equal to the mass multiplied by the acceleration?
Yes, according to Newton's Second Law of Motion, the applied force is equal to the mass multiplied by the acceleration. This relationship is represented by the equation F = m*a.
