Pulley system
The diagram shows a pulley system consisting of two pulleys of weights 10 N each. The system is doing work to lift a load of 100N upwards for 10m at constant speed.
Calculate (1) the total work done by the pulley system. (2) the magnitude of force,F
(3) the efficiency of the system.
(1) W= Fs = 1000 N
(2) F=100+10+10=120N
(3) not sure.
Answers and Replies
tiny-tim
25,832
251
hi thereddevils! :smile:
not even close :redface:
in questions like this, always mark all the forces on the diagram first :wink:
in this case, there are four tensions (one of which is F) …
what are they? :smile:
Thanks Tim,
Do i solve this by breaking it into layers? The tensions in the string of the bottom pulley equals the weight of the bottom pulley itself plus the load. Then, the tension in the string of the upper pulley equals the its own weight + the weight of the bottom pulley and the load. This is what i had in mind.
Yes,i see the four tensions but what do they equal to?
tiny-tim
25,832
251
Give the tensions names (T1 T2 T3 and F), and write the equations for each pulley, starting with the lower one …
what do you get? :smile:
ok let me try
Let T1 and T2 be the tensions of the strings of the bottom pulley, and T3 be the tension of the string of the upper pulley.
T1 + T2 = 110 (load+weight of pulley)
T3 + F = T2 + 10
Am i somewhere near?
tiny-tim
25,832
251
Perfect! :smile:
ok, now (i'm assuming the pulleys are "frictionless") the tension in the rope on either side of a pulley is the same,
so T1 = T2, and T3 = F, and so … ? :wink:
Perfect! :smile:
Thanks Tiny Tim!
Related Threads on Pulley system
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
