How Is Net Work Calculated When Pulling a Boat?
  • Thread starter mikefitz
  • Tags
    Boat Work
In summary, "pulling a boat" refers to the physical effort of moving a boat through water using a net, with the option of using mechanical devices or tools. It involves creating resistance against the water to propel the boat forward, and the amount of force needed depends on factors such as weight, net size and shape, speed, and water conditions. To make it more efficient, proper equipment and techniques should be used. Alternatively, a boat can be moved using a motor, sails, or the current of the water, each with its own advantages and limitations.
mikefitz
155
http://img517.imageshack.us/img517/6533/c6p4ty2.jpg
The drawing shows a boat being pulled by two locomotives through a canal of length 1.04 km. The tension in each cable is 4.27 x 103 N, and theta = 20.0o. what is the net work done on the boat by the two locomotives?
Here is what I've done so far:
Force=4.27*10^3
delta(r)=1.04
theta=20
W=2* [4.27*10^3 (1.04) (cos20) ]
=8345J
What am I doing wrong here? thanks
The distance is given in km--convert to meters.
Your calculation is correct, but it is not the net work done on the boat by the two locomotives. In order to find the net work, we need to consider the direction of the force and displacement.
The net work is the sum of the work done by both locomotives, which can be calculated using the formula W = Fdcosθ, where F is the force, d is the displacement, and θ is the angle between the force and displacement.
In this case, the force and displacement are both in the same direction, so θ = 0. Therefore, the net work done by both locomotives can be calculated as:
W = (4.27*10^3 N)(1.04 km)(cos 0°) + (4.27*10^3 N)(1.04 km)(cos 0°)
= 8,832 J
This is the total amount of work done by both locomotives on the boat.
1. What is "pulling a boat" in terms of net work?
"Pulling a boat" refers to the physical effort required to move a boat through the water using a net. This can also include the use of mechanical devices or tools to assist in the pulling process.
2. How does pulling a boat work?
Pulling a boat involves using a net to create resistance against the water, which allows for the boat to move forward. The pulling force can come from human strength, wind, or mechanical power.
3. What factors affect the amount of force needed to pull a boat?
The amount of force required to pull a boat depends on several factors, including the weight of the boat, the size and shape of the net, the speed of the boat, and the type of water conditions (such as calm or rough).
4. How can pulling a boat be made more efficient?
To make pulling a boat more efficient, it is important to use the right equipment and techniques. This may include using a well-designed net, properly distributing the weight on the boat, and utilizing proper rowing or paddling techniques.
5. Are there any alternative methods to pulling a boat using a net?
Yes, there are alternative methods for moving a boat through the water. These may include using a motor, sails, or even using the current of the water to move the boat. Each method may have its own advantages and limitations depending on the situation.
