Homework Help: Pullys with a mass
  1. Dec 4, 2009 #1
    You've been given a pulley for your birthday. It is a fairly big pulley 12 cm in diameter and with mass 2kg. You get to wondering if the pulley is uniform. To find out, you hang a 1kg textbook 1.0 meters above the floor and use a stopwatch to measure the time it takes it to fall (.71 seconds). What can you conclude about the pully
    2. Relevant equations
    t= r x F
    t = I[tex]\alpha[/tex]
    F= ma
    3. The attempt at a solution
    I solved for the acceleration of the books
    1.0 = .5a(.71)^2
    a= 3.97 m/s^s
    Then used force equation on the book with a mg down and T up (axises are pointing down and to the right)
    mg- T = ma
    T= m(g-a) = 5.83N
    Since the tension is equal to the force of on the pully I used it to find the torque on the pully
    t= r x F
    t=(.06)(5.83) = .350 N*m
    I used to the torque to solve for Moment of Inertia using the other torque equation
    t= I( a/r)
    t(r/a)= I = .0053 kg*m^2
    Then I solved for Moment of Inertia of a uniform disk
    I= 1/2Mr^2
    I=.5(2)(.06)^2 = .0036 kg * m^2
    Since the two moments on inertia are not the same the pully is not uniform. Is that correct?
  3. Dec 4, 2009 #2
    rl.bhat
    Your calculation is correct.
