Purpose of The Imaginary Unit
  1. Apr 24, 2010 #1
    Why do we have an imaginary number? I don't see it's usefulness. Why dos it matter if we can make up a number that satisfies this equation
    ([tex]\ x^{2}+1=0 [/tex] )? It must have real world applications that I'm unaware of.
  3. Apr 24, 2010 #2
    Well, I guess a mathematician would be of much more use in such a subject, but I'll try and give an answer.
    The imaginary unit, leading later to complex numbers and the corresponding set, were first introduced, as mine and every other school book says, to solve several third-grade equations, where the determinant is negative, that would previously mean that there are no solutions in the real number system, but on the contrary there were real obvious solutions of the equation. Therefore mathematicians had to accept that several real numbers could be written as expressions that included roots of negative numbers. I say these things in risk of you knowing them already, but I want to point out that there are a lot of equations that probably are encountered in nature and require "higher" sets than the real set to be explained and solved. In other words, it's useful as a notation and has helped to simplify several procedures. That's what I think.
  4. Apr 24, 2010 #3
    I can't give you an answer as to why they were first defined, but they simplify many analysis of real-world applications. I'm only a third-year in college studying engineering, but I've already run into several topics where using the imaginary plane is very useful. In the study of vibrations, Euler's identity is used to simplify an equation that might be 10 times its size without the use of imaginary numbers.
    Imaginary numbers are also used widely in the study of electronics. It's not my area of expertise, but from what I've learned it's used for calculating the impedance of capacitors and inductors.
  5. Apr 24, 2010 #4
    LCKurtz
    Although it doesn't talk about applications, you might find this interesting:
    http://math.asu.edu/~kurtz/complex.html
  6. Apr 25, 2010 #5
    i allows you to extend the ring R[x] into the complexes.
    R[x]/[(x2+1)] ~ C
    where R[x] is the ring of polys. over the reals (as a ring of polys. in one variable) ,
    and C is the complexes, and (x2+1) is the maximal ideal generated by the irreducible (over R[x]) poly. x2+1 .
    Maybe someone who has their abstract algebra fresher/better than mine can give you
    a proof or good argument for why an ideal generated by an irreducible poly. in F[x]
    is maximal in F[x].
  7. Apr 25, 2010 #6
    Mute
    There are always applications. For the imaginary unit, the biggest one is probably quantum mechanics. Unlike classical mechanics, which can be written entirely in real numbers, quantum mechanics necessarily requires the use of complex numbers. If we didn't have [itex]i[/itex], we wouldn't have a theory of quantum mechanics.
  8. Apr 25, 2010 #7
    What's the difference between [tex] i[/tex] and complex numbers?
  9. Apr 25, 2010 #8
    jasonRF
    The complex numbers are used all the time in applications - certainly in many areas of engineering. The primary reason the imaginary number is useful is because of Euler's identity
    [tex]
    e^{i x} = cos(x) + i \, sin(x)
    [/tex]
    So systems that deal with sinusoidal-like signals use complex numbers just to make analysis easier. Examples include such every-day things as dealing with the 60 Hz (US) power distribution and communications systems. Analog circuits (eg the tuner or amplifier in your stereo) are also designed and analyzed using complex numbers. I promise you that the power company, the cell-phone companies, etc., use complex numbers in their design and analysis work. There are many, many other examples as well. These could be done without complex numbers in principle, but it is sooo much easier with them that no-one in their right minds would do it without them.
    If you know calculus, I recommend the book "an imaginary tale" by Paul Nahin, as it has some great history as well as showing how functions of a complex variable can be used to do things like evaluate integrals in a way that is sometimes much easier than if you stuck to real variables.
    jason
  10. Apr 25, 2010 #9
    Integral
    Staff Emeritus
    i is defined to be [tex] \sqrt {-1} [/tex]
    A complex number is a number which takes the form a + bi. Where a and b are both real; a is called the real part, b is the imaginary part.
  11. Apr 25, 2010 #10
    Redbelly98
    Staff Emeritus
    A similar discussion took place last fall.
  12. Apr 25, 2010 #11
    turbo
    It might be helpful to audit some of the popular talks given by Penrose. He elucidates quite clearly the power of imaginary and complex numbers, and gives the viewer an insight into the power of numbers with multiple (tiered) exponents.
