Proving Heine-Borel Theorem: A Compactness Characterization in Metric Spaces
  • Thread starter quasar987
In summary, the conversation discusses the proof of Bolzano-Weierstrass, a characterization of compactness for metric spaces, and the Heine-Borel theorem. The first method of proving Heine-Borel uses the topological definition of compactness, while the second method uses the characterization by sequences. However, the conversation also proposes another, possibly more enlightening method, which shows that Heine-Borel is not limited to R^n and only requires completeness and the property of being bounded.
quasar987
32
In my book, they first prove Bolzano-Weierstrass (compact iff sequentially compact), then they prove a characterization of compactness for metric spaces: "A metric space M is compact iff it is complete and totally bounded." As a corollary of this, we get yet another characterization of compactness: "A subset A of a complete metric M space is compact iff it is closed in M and totally bounded."
Then they embark on the adventure of proving Heine-Borel (a subset of R^n is compact iff it is closed and bounded). They go about this in two ways. The first way sets out to prove the result using only the topological definition of compactness. After 3 lemmas the job is done. The second way uses the characterization by sequences (B-W) and after a dozen lines of reasoning, the job is done.
But it seems to me that they have left out the easiest and perhaps more enlightening way. Indeed, we already know that the metric space R^n is complete. Therefor, by the corollary I talked about, it suffices to show that in R^n, bounded ==> totally bounded. This way is more enlightening IMO because it actually shows that H-B is not a result that is restricted to R^n as the statement of the thm leads to believe. Rather, it suffices that a metric space M be complete that the the metric be not so exotic as to make a distinction btw bounded and totally bounded!
Or am I mistaken somewhere?
You're not mistaken. In fact, the corollary you've given is sometimes called the "metric space Heine-Borel theorem."
What is the Heine-Borel Theorem?
The Heine-Borel Theorem is a fundamental result in real analysis that characterizes the compactness of a subset of Euclidean space. It states that a subset of Euclidean space is compact if and only if it is closed and bounded.
Why is the Heine-Borel Theorem important?
The Heine-Borel Theorem has important implications in the fields of mathematics and physics. It is used in proofs of other theorems and is a key concept in the study of metric spaces and topology. In physics, the Heine-Borel Theorem is used to understand the behavior of continuous systems, such as the motion of particles or the flow of fluids.
What is the difference between closed and compact sets?
A closed set is a set that contains all of its limit points, while a compact set is a closed set that is also bounded. In other words, a compact set is a set that is both closed and finite in size.
What is an example of a compact set?
An example of a compact set is a closed interval on the real number line, such as [0,1]. This set is both closed and bounded, and therefore satisfies the conditions of the Heine-Borel Theorem.
Why is the Heine-Borel Theorem sometimes referred to as "puzzling"?
The Heine-Borel Theorem can be puzzling because it seems counterintuitive that a set can be both closed and bounded, yet not compact. This is because our intuition from working in finite-dimensional Euclidean space does not always translate to infinite-dimensional spaces, where the Heine-Borel Theorem is often applied.
  • Topology and Analysis
11K
