PV=nRT for solids?
  • Thread starter Mechanic
PV=nRT for solids??
For a perfect gas PV = nRT. This is a very handy little equation that allows determination of temperature given pressure, volume, etc. for gasses, but is there some equivalent equation that relates temperature, pressure and volume for solids?
Thanks
Likes Ethan1983
Answers and Replies
Although the ideal gas law can be derived from statistical physics for many real gases it is just a linearization. I’d probably write something like:
PoVo=Z R To
Z=(Zo+(dZ/dTo)dTo+(dZ/dVo)dVo+(dZ/dPo)dPo )
Where R is the ideal gas constant
V is the molar volume
The Wikipedia article on compressibility may give more insight.
http://en.wikipedia.org/wiki/Compressibility
Borek
Mentor
28,975
3,596
No.
Or rather - there is no equation of practical value. Just like with solutions. You need a lot of tables with experimental coefficients to use these equations.
No.
Borek
http://www.chembuddy.com
http://www.ph-meter.info
Yeah but these things are often liberalized. For instance the spring coefficient or the coefficient of thermal expansion.
Borek
Mentor
28,975
3,596
Yes, they are linearized - but still you have to find coefficients for your material in experiment (or tables).
Ideal gas equation gives reasonably good results regardless of the gas used for the wide range of PT - using only one universal constant. There is no one universal constant for solids and liquids nor one universal equation that'll not use experimentally determined parameter. I bet that's the answer OP was looking for. Could be I am wrong.
Maybe I should start differently...according to the Ideal Gas law, for a given amount of gas at constant volume the temperature will increase if P is increased. Is the same thing true of a solid?
FredGarvin
No. However you do need to state the entire situation in which you are looking. For example, if you have a piece of steel that is sitting by itself and you raise the temperature, there will be no increase in stress due to the delta T. However, if you have that same piece in intimate contact and constrained and add a delta T to it, you will most certainly induce stresses.
In what I think is the spirit of your question, the answer is it is not applicable. That is why it is referred to as the ideal GAS law.
No, because solids are considered to have a "definite" volume, since their particles are tightly packed together.
Here's an example: If you cook a steak in the oven at, for example, three times room temperature, does the steak expand to three times its size? With solids and liquids, the densities must be used to convert to moles, while temperature and pressure have little effect on the volume.
Borek
Mentor
28,975
3,596
That's an interesting question. I wonder... In most (if not all) cases when you increase pressure volume will decrease. That means some work was done on the object - this work is PdV and it most likely increased object temperature (even if the process is isothermic work was done, just the heat was transferred outisde). So in a way it is the same for solids as for gas, although you will need very high pressures for this effect to be observable.
Maybe at zero k but the vibration of the molecules causes phonons to travel within the solid which behave like an ideal gas. The vibration of the molecules (related to temperature) determines the average distance between molecules related to volume.
Mapes
For the posters answering "no":
[tex]\left(\frac{\partial T}{\partial P}\right)_V=-\left(\frac{\partial V}{\partial P}\right)_T\left(\frac{\partial V}{\partial T}\right)_P^{-1}=\beta/\alpha=(\mathrm{compressibility})/ (\mathrm{volumetric}\,\mathrm{thermal} \,\mathrm{expansion}\,\mathrm{coefficient})\neq 0[/tex]
May be small for a solid, but not zero.
Related Threads on PV=nRT for solids?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
