PWM Power
Hi
I have a question to do with using PWM
If for example I had a 1ohm load and a voltage supply of 4JC-1, I would get a power draw of 16JS-1, now if I had a duty cycle of say 50% I should get an average power output of 8JS-1. However if i thought of it as having an average current of 2CS-1 and a average voltage of 2JC-1 then the power output comes out to be 4JS-1, which is 4 times less and not half. If it should be the half what does the actual voltage and current average out to?
Thank you very much.
berkeman
Mentor
55,344
5,518
(4V)^2/1 Ohm = 16W continuous = 4A * 4V
50% duty cycle
8W = 4A * 4V * 0.5
You can't average both the current and voltage, without taking an RMS average. RMS averages give you the right answer -- can you see why?
I can see that it does seem work. However I thought that RMS using route 2 was for sine waves? Am i missing something?
Thank you
Averagesupernova
533
Be sure to keep in mind that .707 * Vpeak is the RMS equivalent for sine waves only. But real actual RMS doesn't care what the waveform is.
Thank you both very much for your help. I understand it alot better now.
Related Threads for: PWM Power
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
