Pythagoras's Theorem ideal
  • Thread starter Dappy
Dappy
23
Pythagoras's Theorum is considered to be an ideal. The accuracy of its results are dependent upon the flatness of the surface to which it is being applied. Since there is no such thing as a perfectly flat surface, Pythagoras's Theorum results can only be seen as an approximation. Is this true in its application to Lorentz transformation?
Answers and Replies
12,925
The theorem is exact, you just have to keep its requirements in mind. Triangles in the real world are just approximations to perfect [strike]rectangular[/strike] right triangles, but that is not part of the theorem. Real triangles are not three ideal lines connected at three ideal points anyway.
In special relativity, space is flat. The theorem can be applied by every observer, if the (idealized) triangle has a right angle for this observer (that is frame-dependent).
Dappy
23
-In special relativity, space is flat. The theorem can be applied by every observer, if the (idealized) triangle has a right angle for this observer (that is frame-dependent).
In General relativity space time is curved. I'm confused. Surely the flat space of SR must also be an ideal.
12,925
Sure, special relativity is general relativity without gravity. You asked about Lorentz transformations, they are mainly a tool of special relativity.
SteamKing
Staff Emeritus
12,798
1,670
I'm still working on what a 'rectangular triangle' is.
Nugatory
Mentor
13,940
7,442
Since there is no such thing as a perfectly flat surface, Pythagoras's Theorem results can only be seen as an approximation.
It's the other way around - Pythagoras's theorem is exact and real triangles drawn on real surfaces in the real world are approximations of that ideal.
This will be true of just about any application of mathematics to engineering and experimental science.
Dappy
23
Pythagoras's Theorum is exact and therefore can only give an approximate
result to a real situation in an imperfect world. I think we're saying the same thing. I'm confused again.
12,925
I'm still working on my second language.
There is no "therefore". Nothing can give exact results in the real world, as there are no exact values or measurements.
dauto
1,948
201
Would you please stop saying Theorum? It's really distracting. Why not say theorem?
Dappy
23
Can we trust Lorentz transformations as being accurate? Pardon me for asking, but what is your first language?
Dappy
23
My apologies, theorem.
WannabeNewton
544
What's distracting are your irrelevant and pointless comments.
Dale
Mentor
Insights Author
2021 Award
32,982
10,227
This thread is drifting into philosophy. If you wish to discuss "perfection" here then you need to start with a scientific definition of perfection.
dauto
1,948
201
I didn't make any comments. I asked Dappy for a favor and he was happy to oblige. Thank you Dappy. Now who is making pointless comments.
Dappy
23
Thankyou
We, I assume, accept that Pythagoras's theorem is an ideal. Is that ideal realized in the real world when calculating Lorentz transformations for time, length and relativistic mass?
Dale
Mentor
Insights Author
2021 Award
32,982
10,227
Provided gravitational effects are not significant, then yes.
12,925
If you take gravitational effects into account, no experiment has ever found a deviation from Lorentz transformations. And there are experiments testing that with a precision of better than one part in a billion.
German.
Dappy
23
That's almost good enough for me. Can you imagine how flat a surface would have to be for Pythagoras's theorem to be accurate to better than one part in a billion. The mirror in the Hubble telescope comes to mind. I wonder how accurate it is in that context.
I don't know how to double quote, but German, I would never of guest. I'm dyslexic and slip up a lot more than that.
Reagards Dappy.
12,925
Flatter than one part in a billion? :D
To have length deviations of one part in a billion on a perfect sphere with the size of earth, the triangle needs an area of ~0.05 km^2.
1 part in a billion is just a random number, the quality of the tests depends on the tested quantity. The stability of the speed of light in different directions can be tested way better (wikipedia gives 1 part in 1017).
The next generation of ring lasers is expected to measure the rotation of earth more precise than satellites and telescopes. That's a 1 part in 1 billion measurement for an already tiny effect.
More: Modern searches for Lorentz violation
5,031
On a curved 2D surface, the Pythagorean Theorem cannot be accurately applied over large distances. However, over short distances, it can provide an excellent approximation. Thus, on the surface of the earth, it will not be accurate over large variations of latitude and longitude. However, over short distances like a few miles, it typically provides an excellent approximation. In space-time, the analog of the Pythagorean theorem is the Minkowski metric. Over large spans of space-time in a region of large mass-induced curvature, it is not possible to define a set of coordinates that accurately describes distances using the Minkowski metric. However, over small local regions, it is possible.
Dappy
23
That isn't quite what I said, but it made me laugh and when I realized what I actually said, it was equally ridiculous.
Now that you've pointed that out, I have to say "right angled triangle". ;-)
Thankyou mfb for the link. I found it most informative and need to give it more attention, to allow it all to soak in.
Dappy
23
So can I assume that Lorentz violation may exist there, but only because of our inability to define a set of coordinates?
12,925
That is not considered as a violation of Lorentz invariance - it is just a setup where Lorentz transformations are not the right tool for the whole space. You need general relativity then.
Dappy
23
I think I understand now. Lorentz transformation is the application of Pythagoras's theorem to two distance ratios, 1:v/c where 1 is the speed of light. The fact that the speed of light is invariant means that we can trust that 1 will always be 1 and hence Lorentz invariant.
Suggested for: Pythagoras's Theorem ideal
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
