Python 3 question
  • Python
  • Thread starter Bipolarity
Main Question or Discussion Point
print(1!=0==0) seems to print the value 'True'. I'm trying to understand why.
Does it first evaluate (1!=0) ?
Or does it first evaluate (0==0) ?
Or does it separate them into (1!=0)^(0==0) ?
I appreciate all help.
BiP
Answers and Replies
5,533
Not sure but I think it would use the left to right rule since != and == would have the same precedence as operators.
It's best to write code without an ambiguity like this by explicitly using parenthesis to order the sequence of operations.
D H
Staff Emeritus
Insights Author
15,393
683
That's what it does. There's some python comparison chaining magic going on here to enable expressions such as 0<x<1 to mean x is between 0 and 1 -- just like one would write in math. That you can use it for 1!=0==0 is a side effect of this magic.
uart
Thanks for the tip on the 0<x<1 syntax DH. That's useful to know. :)
Though surely it's equivalent to (1!=0) and (0==0), rather than xor.
D H
Staff Emeritus
Insights Author
15,393
683
Correct. I read the ^ as the mathematical shorthand for boolean and, which is not the case.
It's not quite equivalent to (1!=0) and (0==0). There is a subtle difference. Consider
self.inbounds = 0 < self.some_function() < 1
This will call self.some_function() once and only once. Now let's rewrite this expression as
self.inbounds = (0 < self.some_function()) and (self.some_function() < 1)
With this rewrite, self.some_function() will be called once if the result from the first call is non-positive, twice if it is positive. Calling the function sometimes once, sometimes twice, can be deleterious if the function has side effects.
Related Threads on Python 3 question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
