Homework Help: Python: print problem
  1. Mar 22, 2015 #1
    I made a program that would some up a grade average. Everything seems fine, the only problem, when I run the program at the end it prints out like this:
    Code (Text):
    Jack
    Stacy
    Jack
    Stacy
    Jack
    Stacy
    How can I make the program print out, for example:
    Name Grade Average
    Name Grade Average
    separately for every student's name used?
    3. The attempt at a solution
    Code (Text):
    grades = []
    names = []
    ch = 1
    while (ch!=0):
        name = input('Enter a name: ')
        if (name.isalpha()):
            grade = int(input('Enter a grade: '))
            if(grade <= 10 and grade > 0):
                names.append(name)
                grades.append(grade)
            else:
                while (grade <= 0) or (grade > 10):
                    print ('The grade you entered is not correct, try again!')
                    grade = int (input('Enter a grade: '))
                names.append(name)
        elif(name == '0'):
            print ('A zero was entered, end of program.')
            ch = 0
        else:
            print ('The name was entered wrong, try again!')
    #problem probably starts from here
    howmuch = len(grades)
    result = []
    for k in range(0, howmuch):
        nreal = names[k]
        for i in range(0, howmuch):
            if (nreal == names[i]):
                result.append(grades[i])
        greal = len(result)
        sumup = 0
        print (nreal)
        howmuch = len(names)
        for z in range(0,greal):
            a = result[z]
            b= int(a)
            print (b)
            sumup = sumup + b
        avg = sumup /(z+1)
        print (avg)
        result = []
  3. Mar 22, 2015 #2
    jedishrfu
    Staff: Mentor
    Try replacing your prints with string appends and the last print statement to print the appended string:
    pstring = ""+real
    pstring = pstring+" "+b
    print pstring
  4. Mar 23, 2015 #3
    By default python outputs a space and newline when you use print
    so if you did:
    Code (Python):
    print "Hello"
    print "bob"
    you'll get:
    Hello
    bob
    adding a , after the print will suppress the newline eg:
    Code (Python):
    print "Hello",
    print "bob"
    results in:
    Hello bob
    or you can use jedishrfu's solution as well :)
Have something to add?
Draft saved Draft deleted
