Q for Isobaric Processes
  • Thread starter songsteel
Just wanted to ask why is it that for isobaric processes, when we wanted to find Q, sometimes we use Q = nCpΔT and sometimes we use Q = nCvΔT + p(Vf - Vi)?
How do we determine which should be used and when?
Answers and Replies
135
They are not different things .Both of the above expressions are correct and can be used simultaneously , or separately depending on the situation.
For an isobaric process ΔQ = nCPΔT.
From First law of Thermodynamics ΔQ = ΔU+ΔW .
Now ΔU=nCVΔT applies to all kinds of processes involving an ideal gas.
So ,putting values of ΔQ and ΔU ,we have nCPΔT = nCVΔT + pΔV
To elaborate it further-
Case 1) What is the heat required to raise the temperature of 'n' moles of an ideal monoatomic gas by 'ΔT' .
You can simply use Q = nCPΔT
Case 2) How much heat is supplied to 'n' moles of an ideal monoatomic gas in a chamber fitted with a light piston , when the temperature changes by 'ΔT' and volume changes by ΔV ? Consider the process to be isobaric
Here ,use ΔQ = nCVΔT + pΔV
Case 3) What is the change in the volume of 'n' moles of an ideal monoatomic gas in a chamber fitted with a light piston , when the temperature changes by 'ΔT' ? Consider the process to be isobaric .
Now use nCPΔT = nCVΔT + pΔV
Edit:Removed the word - "insulated" and removed a typo
4,649
Case 2) How much heat is supplied to 'n' moles of an ideal monoatomic gas in an insulated chamber fitted with a light piston , when the temperature changes by 'ΔT' and volume changes by ΔU ? Consider the process to be isobaric
Case 3) What is the change in the volume of 'n' moles of an ideal monoatomic gas in an insulated chamber fitted with a light piston , when the temperature changes by 'ΔT' ? Consider the process to be isobaric .
Hi Tanya. You need to "lose" the word insulated from cases 2 and 3. If Q is not equal to zero, the chamber is not insulated. In all three cases, you need to lose the word monoatomic, and in case 1 you need to add the words at "at constant volume". Also, in item 2 there is a typo: replace ΔU with ΔV.
Chet
135
Hi Chet...
Yes you are right :redface: .I have edited my post.
Why? These are just examples i have taken using monoatomic ideal gas.
Why ? The heat supplied at constant pressure is nCPΔT
4,649
Hi Chet...
It might give the impression that the relationship applies only to a monoatomic ideal gas.
Oh, sorry. I misread the Cp as Cv. I think it would be worthwhile adding the words "at constant pressure" to Case 1.
Chet
135
Well..these are just random questions/cases I formed .But...you may be correct.
Chet
Right.
Thanks for your valuable suggestions :smile: .I very much like reading your posts .They are full of insight.
Related Threads on Q for Isobaric Processes
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
20K
39K
