QED Calculations: Progress Made in Last 25-30 Years
In summary, the conversation discusses the difficulty of evaluating equations in Quantum Electrodynamics, specifically due to the complexity of integrals. Progress has been made in the last 25-30 years, with the help of computers and computer algebra systems, but it is still a challenging task. Examples of integrals in QED are given and it is noted that the fine structure constant not being smaller makes the calculations more difficult. There has been little analytical progress since the 1960s, but numerical methods have greatly improved. QED has been calculated up to 4 loops, with some referring to it as 16 loops due to the number of powers of the coupling constant, but no complete 5 loops calculation has been done.
ObsessiveMathsFreak
406
I'm not sure if this is the right forum for this topic, so apologies if I got it wrong.
I've been reading the Feynman Lectures on Physics. In it, Feynman states that though Quantum Electrodynamics is highly successful, it is still extremely difficult to evaluate the equations to obtain a theoretical result to compare to experiment. I believe he said it was the integrals that were the difficult part(I imagine this would indeed be the case).
The Feynman lecture were written/given in the sixties I believe, but I've also seen videos of Feynman in Auckland University in 1979, where he again reiterate this fact, and even states that there are experiments for which no-one has been able to evaluate a theoretical result.
The question I would like to ask is; what progress has been made on evaluating such integrals in the last 25-30 years. Specifically, have computers and computer algebra systems helped to tame this task? Can anyone give an example of the integrals QED theorists are faced with, if indeed it is the integrals that are giving the trouble.
Is this aspect of QED still a serious problem, or is it simply a question of throwing more CPU cycles at the problem. Naive I know, but my real question is can the equations nowadays be beaten into submission?
To get an idea of the state of the art, you could look up the work of Toichiro Kino****a of Cornell and his work on the calculation of g-2 (If I recall he completed the four-loop calculation). It's more tricky than just throwing CPU at it because of all the divergences involved. One has to take care of nasty overlapping divergences and renormalize things in a very clever way.
Not surprisingly, things are even more difficult in a bound state. I did a two loop calculation in positronium for my thesis and it was doable only because I used a clever technique developped by my adviser and which was applicable only because positronium is nonrelativistic.
A lop of people are working on NNLO (next to next to leading order) contributions in things like the top quark decay and other systems but usually the techniques are targeted at specific kinematical points.
Yeah, it's somewhat unfortunate that the fine structure constant isn't smaller than it is, and thus avoid us having to calculate third and forth order corrections ;)
Analytically not much progress has been made since the sixties. I know of only 2 counterexamples in 4d since then.
So people just keep doing perturbation theory, and yes the numerical methods have vastly increased in efficiency: Lattice methods, twistor methods, powerful algorithms for planar feynman graphs etc etc.
What is it now, they have QED down to 16 loops or something like that?
Are you sure? As far as I know, QED has "only" been done to 4 loops! (I am talking a bout a full calculation, including the finite pieces. Sometimes people may go a bit beyond if they are interested in just extracting the divergence structure for the renormalisation group analysis).
Sometimes, people wil talk about "eight order" or "tenth order" instead but this is referring to the powers of the coupling constant (roughly, the electric charge) but this is not the number of loops. For example, a one-loop calculation may be called either a fourth order calculation (because there are 4 powers of the coupling constant in the amplitude) or a second order correction to the tree level (because there are two more powers of e than the tree level).
I have never seen that, but maybe some people also give the powers of e appearing in the cross section or decay rate (in a measurable quantity). So maybe this is where the number 16 might have come from! A four-loops calculation would generate 8 powers of "e" relative to tree level, which when squared would give " a 16th order correction". Maybe that is the context in which you saw that number. But I am pretty sure that no complete 5 loops calculation has been done. When I was at Cornell, Kino****a (the world expert in g-2) had completed the 4 loops calculation and he did not intend to do the 5 loops, I think!
Regards
Patrick
Hi Nrqed. That sounds correct. Its been several years since I thought about this (probably dating back to when I was a grad student taking a class or somesuch), so its very possible my memory has transformed it into something erroneous (loop instead of order).
What is QED calculation?
QED calculation stands for quantum electrodynamics calculation, which is a theoretical framework for understanding the interactions between matter and light. It is based on the principles of quantum mechanics and special relativity.
Why is progress in QED calculations important?
Progress in QED calculations is important because it allows us to make accurate predictions about the behavior of particles and their interactions with electromagnetic fields. This has practical applications in fields such as particle physics, chemistry, and materials science.
What advancements have been made in QED calculations in the last 25-30 years?
In the last 25-30 years, there have been significant advancements in QED calculations, including the development of new techniques and algorithms for solving complex equations, the incorporation of higher-order corrections and precision measurements, and the use of powerful supercomputers for faster and more accurate calculations.
What challenges still remain in QED calculations?
Despite the progress made in the last 25-30 years, there are still challenges that remain in QED calculations. These include accounting for the effects of strong electromagnetic fields, improving the precision of calculations, and incorporating the effects of virtual particles and higher-order interactions.
What impact do QED calculations have on our understanding of the universe?
QED calculations have a significant impact on our understanding of the universe, as they provide a theoretical framework for understanding the behavior of particles and their interactions with electromagnetic fields. This allows us to make predictions about phenomena that are not directly observable and helps us to better understand the fundamental laws of nature.
  • STEM Academic Advising
  • General Discussion
  • Art, Music, History, and Linguistics
