QFT & Entanglement: NRQT vs. PCT Transform
In summary, the conversation discusses the differences between nonrelativistic quantum theory (NRQT) and quantum field theory (QFT) in terms of their treatment of PCT and the collapse of the wave function. It also touches on how QFT addresses the EPR paradox and the measurement problem in quantum theory. The conversation also mentions experiments that have measured violations of the discrete symmetries built with C, P, and T, and the role of entanglement in QFT.
  • #36
stevendaryl said:
Or more precisely, every entangled particle is entangled with every other entangled particle.
Something along these lines is what I'm thinking, though because of the monogamy of entanglement, it can't be that simple.
The reason it looks strange is you can assume Erik will measure 1 and do a Bell test on A&D, then throw away the results where Erik doesn't actually measure 1. Viola, A&D were entangled o_O. If Erik decides not to measure them, it'll still be possible to bin them into buckets that violate a Bell test, either by knowing about the relative phases or the Bell test outcomes.
So maybe Erik's measurement is just as way to discover the relative phases of A&D, allowing the bucketing.
  • #37
Eric cannot measure anything but relative phase because that is unitary. Yes, the data has to be selected (based on Erics outcome) before the Bell violations can be seen.
  • #38
stevendaryl said:
I'm not sure I understand the question. My original state was a product state in which the first two particles had the state:
##\frac{1}{\sqrt{2}}(|H_A H_{EC}\rangle + |V_A V_{EC}\rangle)##
and the last two particles had the state
##\frac{1}{\sqrt{2}}(|H_{ED} H_{B}\rangle + |V_{ED} V_{B}\rangle)##
The product has 4 terms:
##\frac{1}{2}(|H_A H_{EC} H_{ED} H_B \rangle + |H_A H_{EC} V_{ED} V_B \rangle + |V_A V_{EC} H_{ED} H_B \rangle + |V_A V_{EC} V_{ED} V_B \rangle)##
Ok, I will take a step back.
Following the way how it is explained in https://arxiv.org/abs/1203.4834:
can be rewritten as:
##\frac{1}{4}( (|H_A H_{EC} H_{ED} H_B \rangle + |V_A H_{EC} H_{ED} V_B \rangle + |H_A V_{EC} V_{ED} H_B \rangle + |V_A V_{EC} V_{ED} V_B \rangle) +##
##+ (|H_A H_{EC} H_{ED} H_B \rangle - |V_A H_{EC} H_{ED} V_B \rangle - |H_A V_{EC} V_{ED} H_B \rangle + |V_A V_{EC} V_{ED} V_B \rangle) +##
##+ (|H_A H_{EC} V_{ED} V_B \rangle + |V_A H_{EC} V_{ED} H_B \rangle + |H_A V_{EC} H_{ED} V_B \rangle + |V_A V_{EC} H_{ED} H_B \rangle) +##
##+ (|H_A H_{EC} V_{ED} V_B \rangle - |V_A H_{EC} V_{ED} H_B \rangle - |H_A V_{EC} H_{ED} V_B \rangle + |V_A V_{EC} H_{ED} H_B \rangle) )##
and it is equal to:
##\frac{1}{4}( (|H_A H_B\rangle + |V_A V_B\rangle) \otimes (|H_{EC} H_{ED}\rangle + |V_{EC} V_{ED}\rangle) +##
##+ (|H_A H_B\rangle - |V_A V_B\rangle) \otimes (|H_{EC} H_{ED}\rangle - |V_{EC} V_{ED}\rangle) +##
##+ (|H_A V_B\rangle + |V_A H_B\rangle) \otimes (|H_{EC} V_{ED}\rangle + |V_{EC} H_{ED}\rangle) +##
##+ (|H_A V_B\rangle - |V_A H_B\rangle) \otimes (|H_{EC} V_{ED}\rangle - |V_{EC} H_{ED}\rangle) )##
Does it seem right so far?
  • #39
If Erik makes no measurement: All you would ever see at A & D would be completely random combinations. No pattern, no Bell test violations.
  • #40
and it is equal to:
It looks right.
  • #41
stevendaryl said:
It looks right.
But isn't it now obvious that detecting together
##(|H_{EC} H_{ED}\rangle + |V_{EC} V_{ED}\rangle)## with ##(|H_{EC} H_{ED}\rangle - |V_{EC} V_{ED}\rangle)##
would put together
##(|H_A H_B\rangle + |V_A V_B\rangle)## with ##(|H_A H_B\rangle - |V_A V_B\rangle)##
so it won't be entangled state?
  • #42
would put together
Why not? After projection with ##\Pi_A##, you'll be in the state:
##1/2 (|H_A H_{EC} H_{ED} H_B\rangle + |V_A V_{EC} V_{ED} V_B\rangle)##
Alice's and Bob's photons seem entangled to me: they're either both H or both V, but it's not predetermined which.
  • #43
But they have to be correlated in diagonal basis too. But they won't be.
  • #44
stevendaryl said:
It just shows that the intuition that particles become entangled by interaction is not correct. Particles don't need to have ever interacted in order to be entangled.
What do you mean by interacted? When ##B## interacts with ##C## you could hypothesis that ##B## collapses the result of its interaction to ##A## and ##C## collapses the result of it interaction to ##D## so that when you measure ##A## and ##D## they are correlated. If it happens in this way then interaction is a requirement for the entanglement.
  • #45
But the entanglement between A and B happens afterward when Eric performs his measurement---long after A and C have gone their separate ways, and long after D and B have gone their separate ways.
  • #46
What definition of "entangled" are you using?
  • #47
I don't understand why it matters. We are talking about best known type of entanglement - two polarization entangled photons. You can test your definition of entanglement with this type of entanglement and not really the other way around.
  • #48
You originally said ##A## and ##B## were one of the entangled pairs before the measurement:
stevendaryl said:
If you produce one pair of entangled particles, ##A## and ##B##, and another pair, ##C## and ##D##, then a measurement involving ##B## and ##C## can force ##A## and ##D## to become entangled (I think)
Now you are saying ##A## and ##B## are entangled after the measurement:
Did you change the experiment?
  • #49
I may have gotten my own naming convention screwed up, but no. Originally, we have 4 particles:
  1. ##A## and ##EC##, which are entangled. ##A## is sent to Alice and ##EC## is sent to Eric.
  2. ##ED## and ##B##, which are entangled. ##B## is sent to Bob and ##ED## is sent to Eric.
  3. At this point, ##A## and ##B## are NOT entangled.
  4. But Eric performs a measurement on ##EC## and ##ED## which causes ##A## and ##B## to become entangled.
If I ever said that A and B were an entangled pair to start with, I screwed up my names. That was never the intention.
  • #50
Because they certainly are entangled, by the definition that I know of: Two particles are entangled if their measurement results are correlated, but neither measurement result is predetermined.
  • #51
To me, there's two different phenomena: (1) Entanglement of states, and (2) Bell-violating correlations. The Bell-violating correlations imply that two systems have entangled states, but not vice-versa. There can be at most two systems that have Bell-violating correlations, but there can be any number of systems that are entangled.
I'm not sure that the terminology is standardized. But to me, entanglement is the underlying mechanism, and Bell-violations is the symptom. The mechanism doesn't always lead to Bell violations.
Likes DarMM
  • #52
As far can be known, we would get the same random values if Erik makes a measurement. It's just that Erik picks out pairs that (on average) violate the Bell test along some basis. Seems like his actions don't have any effect on the individual pairs of A+D, like entangling them. A simple story of the experiment which doesn't contain any nonlocal aspect (except the Bell test) goes like this:
  1. Two pairs of photons with entangled polarisations A+B (Alice) and C+D (Bob) are created independently.
  2. We assume pair Alice is entangled with pair Bob along some random basis.
  3. The relative phase between B+C is measured, revealing the relative phase between A+D.
  4. Now we know along what basis A+D will violate a Bell Test.
I'm open to the possibility that this scheme may not work, but to understand what this experiment is telling us, it would be good to know why.
  • #53
I'm not sure what you mean by "we know along what basis A+D will violate a Bell Test". The Bell test involves measurements at multiple (at least two) angles.
I've already gotten in trouble with the names, but I specifically sent particle B to Bob.
Anyway, if Eric measures the middle two (one entangled with Alice's particle, one entangled with Bob's) and finds that the pair are in the state:
##|HH\rangle + |VV\rangle##
then that state is actually independent of the basis. If you take another orthogonal basis--##|X\rangle = cos(\theta) |H\rangle + sin(\theta) |V\rangle## and ##|Y\rangle = -sin(\theta) |X\rangle + cos(\theta) |Y\rangle##, then
##|HH\rangle + |VV\rangle = |XX\rangle + |YY\rangle##
Likes akvadrako
  • #54
akvadrako said:
...The relative phase between B+C is measured, revealing the relative phase between A+D...
Oops. This is experimentally incorrect. You can measure the relative phase between B & C with causing a swap. You simply measure B and C separately, not allowing them to be in a Bell state. Now you know their relative phase. A & D will not be entangled, and no Bell test violation.
Likes akvadrako
  • #55
vanhees71 said:
Of course, relativistic QFT has no problem with EPR, because it describes on the one hand the observed strong correlations described by entanglement without violating relativistic causality, and it does this by construction, fulfilling the socalled Linked Cluster Principle. This clearly shows that entanglement doesn't imply any "spooky action at a distance".
DarMM said:
It describes that they exist, certainly, but not how they come about (i.e. what's causing the strong correlations) that's the contentious part.
vanhees71 said:
But as for any state the cause of entanglement is the preparation procedure to bring the system into this state.
DarMM said:
Firstly can't you have entanglement between systems that have never been in physical contact due to vacuum entanglement, it's not always our preparations that do it possibly? I might be wrong on this.
After reading through this thread many times, I think vanhees71 is correct to say "the cause of entanglement is the preparation procedure to bring the system into this state." I would like to see a counter to this.
In the example of entanglement swapping, a local interaction of the photons seems to be the cause of entanglement between the photons. Using the stevendaryl description, Eric performing the measurement is the local interaction that causes the non-local collapse of state that is propagated to Alice and Bob. In other words the cause of entanglement is the local interaction and the result is the non-local collapse.
That being said, I don't see how this relates to the discussion on how QFT clearly shows that entanglement doesn't imply any "spooky action at a distance".
I am inclined to agree with stevendaryl post in so much that #2 (the Born rule) is what describes the entanglement and collapse. And so clearly showing that there is no "spooky action at a distance" would need to involve it.
stevendaryl said:
Right. Whether it's QFT or nonrelativistic quantum mechanics, the theory has two parts:
1. Probability amplitudes are computed using unitary evolution.
2. Upon a measurement, measurement results occur nondeterministically with probabilities given by the Born rule (the square of an appropriate amplitude)
The issue about nonlocality is about #2, not #1. So pointing out that QFT fulfills the Linked Cluster Principle is irrelevant. (Well, it's relevant to proving that part #1 satisfies locality, but it's not relevant to part #2).
  • #56
It's a cause, but doesn't fully explain the correlations, that's more the point. In the sense that there is no event ##E## such that the probabilities of the entanglement measurements ##A## and ##B## obey:
$$p(A \wedge B | E) = p(A|E)p(B|E)$$
This is what is usually the minimum required for something to be an explanation statistically (see Reichenbach's principle). So there is no dispute that the preparation is a cause, I never disagreed with that, but it doesn't fully explain the entanglement.
See: https://arxiv.org/abs/1503.06413
Edit: In simpler language, we don't know how the correlations are achieved.
  • #57
Maybe relative phase isn't the right word - I'll try to be more correct with my terminology. But you'll have to learn about a joint property of A&D that's incompatible with learning their values, which is what separate measurements of B&C will give you.
  • #58
Sorry, I was using names from another paper; I'll stick to yours. What I meant by "basis" is that A&B start out entangled either along the same bases or cross bases.
If it's same, ##AB = |HH\rangle + |VV\rangle##, Erik will measure 1, ##E = |HH\rangle + |VV\rangle##.
If it's cross, ##AB = |HV\rangle + |VH\rangle##, Erik will measure 0, ##E = |HV\rangle + |VH\rangle##.
That's at least the basic idea and I think it has some nice properties. (1) There is no "unitary collapse" or retrocausality, just post-selection. (2) Without access to EA&EB, the A&B correlation is forever hidden. To be natural the assumed prior correlation should be fully general; could the prior correlation be any superposition of same and cross and would that ruin the statistics?
  • #59
vanhees71 said:
Sure, with philosophical rather than physical arguments ;-)) SCNR.
Said someone who uses philosophical arguments himself. ;-)) SCNR.
  • #60
Yeah, that's the possibility I referred to way back in https://www.physicsforums.com/threads/qft-and-entanglement.959593/page-2#post-6089411: Even if the measurement results may not be predetermined, maybe the entanglement relationships are. I don't think that that's consistent, but I don't have a quick argument why not. But note that Eric can measure different things about his pair of particles, leading to different conclusions about the correlation between Alice's particle and Bob's particle. So it doesn't seem to me to be consistent to assume that Alice's and Bob's particles have a pre-existing entanglement relationship.
  • #61
In physics, "philosophy" means "a different philosophy than the one I believe".
Likes bhobba and PeterDonis
  • #62
Yes, I know you got it right away; I was just replying to posts from you and Dr. Chinese and now I think the idea is more clear. I'm not sure what to believe — if you take your complete initial state and you trace out Erik's part, it seems like it leaves a mixed state of the two entangled states. I'm just curious, do you think this scenario needs some non-classical feature (besides the Bell test part), like retrocausality or "unitary collapse" ?
  • #63
This is how it is done.
From
High-fidelity entanglement swapping with fully independent sources
arXiv:0809.3991v3
I'm hoping that someone can explain how this works. From my understanding, a 50:50 meam splitter with a photon in each input will have both photons in one output IFF the photons are completely in phase. Otherwise they behave independently. The explanation in the paper uses coincidences between detectors at possibly empty outputs.
  • #64
If both photons have the same polarization they will end up in the same output of BS (because of HOM interference) and in the same output of PBS (because they have the same polarization). So all these you can throw out as there will be no detections in two separate detectors.
If both photons have different polarization they will be either in the same or different outputs of BS subject to phase difference between ##H_2/H_3## modes vs phase difference between ##V_2/V_3##. If phase difference between horizontal modes is the same as phase difference between vertical modes they will end up in the same port (I guess ... because one mode has it's phase flipped), and if relative phases differ by ##\pi## then in different ports. And because they have different polarization they end up in different ports of PBS. So they can detect both photons separately.
That way they single out two states:
##(|H_1 V_4\rangle + |V_1 H_4\rangle) \otimes (|H_2 V_3\rangle + |V_2 H_3\rangle)##
and
##(|H_1 V_4\rangle - |V_1 H_4\rangle) \otimes (|H_2 V_3\rangle - |V_2 H_3\rangle)##
  • #65
Thanks. The beam splitter equation does not include polarization. It is written in terms of photon creation and anihilation operators in the channels.
The HOM effect measures the relative phase - not polarization angle.
Unless the beam-splitter is different. Apart from that your explanation looks OK.
  • #66
HOM interference happens for identical photons (whatever that means, but it certainly means the same polarization). Relative phase is certainly not a factor. Look at Fig.2 in the same paper. There are no fluctuations as relative delay is changed. This is common mistake to expect some phase dependent fluctuations in HOM interference, but there are none.
  • #67
I think I've worked it out. Normally in the entangled scenario we can write ##P(xy|\alpha\beta)=\tfrac{1}{2}P(x|\alpha)P(y|\alpha\beta) + \tfrac{1}{2}P(y|\beta)P(x|\alpha\beta)## and applying Malus' law we get ##P(11\ or\ 00) = \cos(\alpha-\beta)^2##. In the swapping case the information about the ##\alpha (\beta)## setting does not get transferred across from A to B. Instead the polarizations of photons 1 and 4 are projected in the same, or perpendicular polarizations ( ie V or H).
We can write ##P(xy|\theta_1\theta_4)=P(x|\theta_1)P(y|\theta_1\theta_4)##
Applying Malus' gives ##P(11|\theta_1\theta_4)=\cos(\theta_1-\alpha)^2\cos(\theta_1-\beta)^2## and ##P(00|\theta_1\theta_4)=\sin(\theta_1-\alpha)^2\sin(\theta_1-\beta)^2## and summing the last two is the probability of a coincidence between A and B. The sum reduces to ##\frac{\cos\left( 4\,\theta_1-2\,\alpha-2\,\beta\right) +\cos\left( 2\,\beta-2\,\alpha\right) }{4}+\frac{1}{2}##. For ##\alpha=(0, \pi/4),\ \beta=(\pi/8,\ 3\pi/8)## it turns out that ##a+b=\pm(a-b)## and also for the pairings ##(a,b'),\ (a',b),\ (a',b')## so setting ##\theta_1=0## we can write
##\frac{\cos\left( 4\,\theta_1-2\,\alpha-2\,\beta\right) +\cos\left( 2\,\beta-2\,\alpha\right) }{4}+\frac{1}{2}=\frac{\cos\left( 2\,\beta-2\,\alpha\right) }{2}+\frac{1}{2}=\cos(\alpha-\beta)^2##
So under certain assumptions it is possible for photons 1 and 4 to give the right statistics for total entanglement. This would be apparent if these events could be filtered out. I have not tried to work out what the Q1 and Q2 coincidences would be for this but they no doubt exist.
  • #68
Okay, I think I found a way to make sense of it. The AB system is normally written in the classical basis:
##|H_A + V_A\rangle \otimes |H_B + V_B\rangle##
but for the entanglement swapping experiment, the same/cross basis is more convenient:
##|H_A + V_A\rangle \otimes |same + cross\rangle##
This makes it look just like any standard measurement of entangled qubits. When Erik measures same/cross on his system, of course it collapses the AB system. And just like any fully entangled pair, they should also be able to violate a Bell inequality along that basis.
  • #69
In entanglement swapping experiments polarization relationship is determined between two photons and relative phase relationship is determined between two pairs of polarization modes. Determining just one relationship is not enough to perform entanglement swapping.
One possible problem with a view that Bell state measurement (BSM) just reveals preexisting entanglement is that analysis of swapping is done in particular basis. Say maybe BSM forces photons from different entangled pairs to certain polarization and phase relationships and if it is not done we can't sort the quartets to four necessary bins before measurement of Alice's and Bob's photons.
  • Quantum Physics
  • Quantum Interpretations and Foundations
10K
  • Beyond the Standard Models
14K
10K
