QM Interpretations: Most Popular & Why?
In summary: The more you will work with your...the more you will realize that there is no single "right" answer, and that the answer may change depending on the experimental setup you are using.
  • #71
How about this?
Dmitry67 said:
“Definitely not. Then intensity is not important. Even if we have Frequent event (90%) and Rare event (10% probability), and we make 100 tries, then all combinations are possible, like FFFFFFFFFFFF… (100 Fs), and RRRRRRRRR (100Rs which is also rare). All 2^100 branches must exist! There are 2^100 observers observing all these branches”
“Lets make that experiment. I bet we get about 85-95Fs and 5-15Rs. What is a prediction of MWI?”
“Hmmmm…. Everything is possible…”
I am blocked at this point.
Let's play with idea of the many observer view rather than many world view? (or just think of MWI, but where there is a physical basis for each world, which is an subjective view)
If we instead acknowledge that each observer, actually sees a different statistical basis, and thus has acquired different priors. No finite real inside observer have something we can call complete statistical basis, or a "fair sampling".
This explains (assuming the observer is rational) why the different observers in a given population act differently. Each observers rationally act upon his own history only.
I think it's central to ask what is the point of "making a prediction"? Clearly the rational action of one observer, depends on the expected future. "anything is possible" would be a useless constraint. But otoh, a particular observer would not infer that anything is possible, since the distinguishable state space of a given observe is truncated.
I'm not sure if this makes sense to you, but I don't see this as as problem. But then I don't have the degree of realist desire you have :)
/Fredrik
  • #72
Quite relevant to what I tried to convey relates to what user=Fredrik (not Fra) said about his impression of MWI
Fredrik said:
The same as the axioms for the statistical interpretation (Link), plus the additional assumptions that it makes sense to consider the Hilbert space of the universe (even though it includes yourself), and that a state vector in that Hilbert space is a representation of all the properties of a physical system (the omnium). (The statistical interpretation doesn't assume that, and it never includes the observer in the Hilbert space).
According to my way of reasoning, these two ideas does not even mix consistently.
IMHO a possible corrected version of something close to it, but still very different is to consider a kind of holographic picture where each observer encodes an image of it's own environment (the remainder of the universe). But obviously each observers has encoded a different version of the universe, and more so, only the OBSERVABLE part of the universe. This should even constrain the size of the observable universe, and relate it to the observers complexity in a kind of holographic spirit.
A kind of statistical interpretation can still be maintained, but it's of subjective nature - which is no problem per see.
And instead of a an very ambiougs and unclear infinite superposition of universes, we instead have a set of interacting VIEWS of worlds, represented by a population of observers in our one evolving universe (since the observes aren't static).
/Fredrik
  • #73
Count Iblis said:
I think that in the MWI, the Born rule can be derived from the weaker assumption that measuring an observable of a system that is in an eigenstate will yield the corresponding eigenvalue with certainty.
The problem with such an additional assumption is that it destroys all the beauty of pure MWI without that assumption. This is because such an assumption raises questions that cannot be answered within MWI:
What does it mean "to measure"?
Are measurements and/or observers described by the Schrodinger equation?
Or are they something external?
In short, with this additional assumption, MWI is not much different from the Copenhagen interpretation.
On the other hand, without that assumption (or a similar one) MWI is really beautiful and elegant, but unfortunately - physically empty. It's physically empty because it cannot explain the emergence of the Born rule - the crucial part of standard QM without which QM is physically empty.
So there are only 2 possibilities:
1. Abandon MWI completely, or
2. Accept MWI but add something additional that will destroy a part of its beauty.
If you choose 2., then you can add something that will make it either vague (like the assumption above), or not vague. The price for choosing something not vague is that it will probably look somewhat ad hoc. The best known example of non-vague but ad hoc assumption that can be added to MWI in order to recover the Born rule is - the Bohmian particle trajectories.
Personally, I find the last choice most appealing because this "ad hoc" assumption does not look to me so much ad hoc at all. Unfortunately, there is no objective quantitative measure of "ad hocness", so I cannot present a proof that the Bohmian trajectories are not so much ad hoc as many think that they are. I can present arguments, but not the proof.
In short, I believe that pure MWI is correct, but not complete. A possible completion of MWI is provided by the Bohmian interpretation.
  • #74
Dmitry67 said:
the Born rule… personally, I think for MWI it must be interpreted differently.
Dmitry67 said:
...like, total number of observers observing X divided by the total number of observers in some subbranch on a given basic...
We can and should interpret it differently, but I don't know if there's a way to interpret it the way you're suggesting. There are several different ways to derive the Born rule's assignment of probabilities from the assumption that the Hilbert space of the omnium can be decomposed into a tensor product of Hilbert spaces of subsystems (and some minor technical assumption such as the one Count Iblis mentioned). We can also prove the converse. This suggests that in the MWI, we should think of the Born rule as the assumption that these decompositions are allowed. The actual probability assignment should be thought of as a result derived from that axiom. Just don't forget that the this decomposition axiom is very non-trivial.
The decompositions are not only allowed, they're what turns the model into a theory. In the MWI, Hilbert space with the Schrödinger equation and without the Born rule, is a perfectly valid mathematical model of reality, but it's not a theory because it doesn't make any predictions about results of experiments. An experiment is an interaction between subsystems, so we can't even begin to think about predictions until we have decomposed the omnium into the appropriate subsystems. The most useful way seems to be to decompose the omnium into the tensor product of "the system" and "the environment". The observer is part of the environment.
What you said about probability is how I was thinking about the MWI before this thread. That's actually the main reason why I felt that the MWI was complete nonsense. I have never seen anyone even try to define the "branches", or to quantitatively define probability in terms similar to what you're talking about, and without that, I felt that the MWI was at best a few "loosely stated ideas about what sort of things are happening". (And that really was the most positive way I could describe it. Most of the time I wouldn't be so kind).
Edit: I don't fully understand any of the derivations of the Born rule's assignment of probabilities from the decomposition assumption + minor technicalities. It's possible that someone who does would think that this approach does explain how to think about probabilities in a way that's similar to what you describe.
  • #75
Such as?
(I ask for a reference where such a derivation can be seen.)
Edit: Now I have seen your edit in which you admit that you do not fully understand any of such derivations.
  • #76
I agree fully with your analysis (especially that you need *some kind of Born rule* to turn MWI into something observable).
Fredrik said:
I'm starting to come around a little bit about the MWI. For a long time, it just seemed more nonsensical the better I understood it, but it's been going in the other direction while I've been writing my posts in this thread. I still think the terminology is confusing at best and idiotic at worst, and the same goes for the statements that MWI proponents make about the MWI, but I think it's possible to make sense of some of their ideas.
These are some of my thoughts:
The way I look upon MWI is that in the "omnium" the state of the omnium contains several terms with several "classical brain states", and by the Born rule, I'm aware of one of them. What's somewhat clear is that I can't at the same time have an wareness of "several classical brainstates" and have an illusion of "free will" because that would imply that I could act differently as a function of comparisons of "different brain states", and hence, the evolution of the state of the omnium would not be linear (superposition wouldn't hold). So any awareness and illusion of free will must automatically include the point that you can only be aware of "one" classical state at once. I can't be aware of the dead cat and the live cat simultaneously. So there must be SOME rule that tells me which awareness I'm about to experience, and we can just say that it is the Born rule.
And there it stops for me, this is good enough. As to the question of what ARE classical brain states, well, you could delve into those brain states which are more or less robust against decoherence and so on, but it doesn't matter. This is an unsolved problem in any case, because also in a Copenhagen, of a statistical ensemble interpretation, at a certain point you must DEFINE what are the pointer states, the states of "awareness", the possible outcomes of "observation".
I agree that it is not satisfying entirely to have to "stop there", but it has the advantage of being able to treat everything in the lab under unitary evolution, without having to ask "what's a measurement ?". It has also the advantage of not having to say that there's some objective physical action by "consciousness", and that there is no "transition from quantum to classical at some point".
In the end, you still don't know exactly how and where the probabilities come from, that's true, but at least you can have some intuition of what "physically happens" - at least in the omnium - this in contradiction to the "ensemble" interpretation where there's no "physical hold-on" to give you a relationship between the calculations and "the physical world".
You can say that the way I see this MWI thing is that it generates "ensembles of states of awareness". This is somewhat unorthodox in MWI, because a pure MWI adherent still thinks that you can obtain the Born rule from the unitary evolution alone. There are arguments in favor of that view, but I don't think any of them is conclusive - so I don't see the problem of introducing a Born rule for awareness.
The big points are that as long as you consider the wavefunction, you do give it some physical ontological reality within the omnium, and it evolves strictly according to unitary evolution. That's for me the essence of the MWI idea. It implies that all instruments, and all observers, end up physically by being in an entangled superposition with "all possible outcomes" in some "real" kind of way. It allows for "physical intuition". That's good enough for me, to give me a picture of what quantum mechanics is about.
  • #77
Vanesch, would you agree that the Bohmian interpretation can be viewed as an attempt to make a completion or refinement of MWI, by providing a possible origin of the Born rule in MWI?
  • #78
I would say that the difficulty here is that suddenly, one requires of a physical theory to solve a lot of philosophical issues which have been recognized since ages as being difficult (or even unsolvable) issues, like what is "awareness", and "why am I "I" " and questions like that. The only reason being that now, in MWI, these considerations enter into the theory in a non-negligible way. That doesn't make their philosophical consideration less difficult. So in as much as in classical physics, we don't know the answer really to "why am I experiencing *my* body" and things like that, but we don't care because it doesn't seem to have the slightest incidence on "the physics", in MWI it does seem to play a role, but we still don't know the answer. Let's pretend we do, in MWI as much as in classical physics, no ?
  • #79
To decompose the omnium into the tensor product of "the system" and "the environment", and give the interaction sufficent time to allow correlations to form between eigenstates of a self-adjoint operator on the system's Hilbert space and pointer states of the environment. (Which observable that is is defined by the environment)
Don't ask me exactly what a pointer state is. I need to study decoherence theory in greater detail first. My intuitive understanding of pointer states includes the notion that every pointer state has every observer in a well-defined memory state. So memories of results of experiments are correlated with the actual results.
Yes, definitely. The problem is just that the description includes all possible measurement results without any sort of probability assignment. (See my previous post).
I don't think that the Born rule (which we can state as the axiom that a tensor product decomposition is allowed + some minor technicality) destroys the beauty. Without it, the model doesn't even look like it has anything to do with the real world. It's just a vector space with an equation that describes the shape of a curve in it. But I think it's extremely cool that the additional axiom both turns the model into a theory that agrees with experiment with an amazing accuracy, and also tells us a bunch of things about the real world that we would never have expected to find in a theory that has any chance of being right.
  • #80
Yes, you can say that. The bohmian view gives you an "objective" token that can assign probabilities to branches, which are derived ultimately from "initial conditions", as in classical statistical mechanics.
I said already several times that if it weren't for the difficulty the Bohmian view has with the *spirit* of relativity, it would be my favorite interpretation, free of all the philosophical difficulties that come with MWI - or at least, we could again do as if we didn't need to think about them to do physics.
  • #81
Demystifier said:
Such as?
I was thinking about Zurek's derivation based on the concept of "envariance", and Hartle's derivation, which is what Count Iblis is talking about. This article claims to cover Zurek's method better than he did. I have only taken a very quick look at it. If you don't like it, I'm sure there's a reference to Zurek's original article in it. Hartle's derivation is discussed here. There's a link to his article in #3.
  • #82
Yes, I remember you said that. But I also remember that, when I drawn your attention to a paper that formulates Bohmian mechanics in a completely relativistic spirit without a preferred foliation, you were not interested in styding the details. Perhaps you will now, so I will try again:
arXiv:0811.1905 [Int. J. Quant. Inf. 7 (2009) 595]
For further developments see also
arXiv:0904.2287 [to appear in Int. J. Mod. Phys. A]
  • #83
Strange that you did not mention the problem with the initial conditions: while in BM they are infinitely complex, in MWI the initial state of the 'omnium' can be very simple.
For me it is a part of the beauty of MWI. I will never believe that God had positioned all these BM particles so 13 billions years after that I would type this very post.
  • #84
I will try to read it, but I have to say that I've a bit lost interest in the interpretational issues. Not totally, but it is less on my mind than it was a few years ago. Probably I'm growing mentally old :smile:
  • #85
Fredrick,
What was your opinion about Max Tegmark's MUH before and after your trip to the MWI world?
I mean, if there is nothing else except the evolution of omnium, and that evolution is deterministically defined by 1 or more equations, what is Universe but a solution to these equations?
  • #86
Thanks! :smile:
  • #87
That is not strange at all, for two reasons:
First, this alleged advantage of MWI is not something widely known. In fact, you seem to be the only guy who uses this argument. Or do you know anybody else?
Second, you have never proved that it is really true that a complex universe can really emerge from a very simple initial state. In fact, at another thread you admitted that it was not so obvious as you thought it were.
Third, I have a challenge for you. Give me a relatively clear argument that a simple MWI initial condition can lead to a complex universe, and I will turn your argument (whatever it will be) into an analogous and equally clear argument that a simple Bohmian initial condition can also lead to an equally complex universe.
  • #88
As opposed to picking infinitely many values to set an initial wavefunction?
If it makes you feel better, the position of all those particles is just a single point in a 36 billion dimensional vector space -- much smaller than the Hilbert space the wavefunction is chosen from.
  • #89
1 Yes, and I am trying to understand why
2 Well, we don't know the equations of the superstring/loop gravity near the Big bang, so it is diffucult to do it right now
3 Do you remember your own analogy: MWI is a tree, but without an ant? The root of a tree is very simple, the complexity is on the leaves. Or what do you mean by 'Simple Bohmian condition'? In BM information is conserved (if we include hidden variables), so it was the same at BB.
On the contrary, in MWI the final state is not pre-coded.
Say, I make a cat experiment. Cat dies, I cry. I repeat experiment again, cat dies, I commit suicide. But if the second cat is alive, I feel relieved. But if the very first cat was alive, I (would) lose interest to science, make a sturtup, and end being a millionaire.
Is all that complexity 'encoded' in the state of the neutron used in the cats experiment? No of course. The relatively simpel state evolved into a tree of different final states
  • #90
What if these infinitely many values at the BB are defined by very simple equation we don't know yet?
  • #91
When I hear all these complex discussions concerning various interpretations, I can't help but think of King Alfonso X who upon studying the Ptolemaic universe stated, "If the Lord Almighty had consulted me before embarking on creation thus, I should have recommended something simpler."
  • #92
Yes I do.
You probably mean the complexity is on the branches, not leaves. However, it is important to emphasize that each particular branch must be complex by itself, because otherwise no complexity would be perceived (by "frogs").
I said that I will turn YOUR argument on MWI into my argument on BM. So you must first say what do YOU mean by "The root of a tree is very simple". I have some idea what does it mean, but the crucial point of my challenge to you is that I base my arguments on YOUR arguments. In other words, I want to beat you by your own weapon. Otherwise, my arguments will not be sufficiently convincing to you. (This is like the famous case when Bohr beat Einstein by using argument based on General Relativity. Later it turned out that this Bohr's argument was not valid, but at that time it served the purpose to convince Einstein.)
In MWI information is also conserved (if we include the whole wave function), so it was the same at BB. [That's what I call beating you by your own weapon.]
Yes it is (if, as I said, we include the whole wave function - the bird view).
  • #93
What if Bohmian initial values at the BB are also defined by very simple equation we don't know yet?
[I continue with beating you by your own weapon, including your typos.]
  • #94
I have always liked that suggestion. What has changed is just that I previously didn't think it was possible to interpret this particular mathematical structure (Hilbert space) as a description of a physical system that we're a part of. Now I think it's possible.
It's too soon to say. I mean, we're still not even able to explicitly construct a Hilbert space and operators on it for the standard model, and it's possible that QM needs to be modified to be fully compatible with gravity.
  • #95
Fredrik said:
OK, that's a statement I haven't heard before. How does the C*-algebra formulation deal with subsystems, and how is it relevant?
If we start with the algebra of all observables that can be "observed" in the entire universe, then we can (in principle) write down the subalgebra of those observables that relate to the subsystem of interest.
e.g. interested in spin? Then we can look at the algebra generated by the spin observables. Other experiments? Maybe we should restrict to just those observables localized to the laboratory.
Since a state is a function, it automatically restricts to a function on the subalgebra (and the restriction remains a state).
In other words, a state is a function that maps observables to complex numbers... and when looking at a subsystem, the restricted state is just the same map (but with the restricted domain) from observables to complex numbers.
The point I was trying to make (I think) was that dealing with subsystems doesn't require invoking Born's rule or trying to make any sort of statement about (seemingly arbitrary) factorizations of a Hilbert space.
  • #96
And for each such subalgebra, the GNS construction gives us a representation of observables as bounded operators on a Hilbert space, right? What's the relationship between these Hilbert spaces and the Hilbert space that corresponds to the huge C*-algebra we started with? Is the latter a tensor product of the former?
  • #97
I do not question the connection between algebras defined by operators, and the corresponding sets/structure space.
The question is, wether there is any physical leap here, but making use on an "in principle" argument, that as far as I see it, can never be physicall realized, and is not a plausible premise to me.
I know many people refer to this GNS reconstruction and seem to somehow feel better there, but I do not find this more plausible, than just accepting other axioms. It mainly suggest a connection between operations and representations. But they both come together IMO.
/Fredrik
  • #98
I confess that I'm not aware of any way in which this differs from dealing with subsystems in any other physical theory. Would you elaborate?
  • #99
Don't forget GNS takes a state as input too! Your question seems a little off -- but since I only have a shallow understanding of the subject, I don't have a good guess what the right question to ask is.
So two notes:
. Every representation of the big algebra is automatically a representation of the subalgebra.
. (Once I'm sure what we're asking) I imagine the tensor product factorization is somewhat unlikely... but I expect there is no essential difference whether or not a factorization exists, so it's useful to look at the algebraically simpler case.
  • #100
If we are talking about existing mature "theories", then I think you have a point.
But since my opinon as expressed earlier in this thread, is that to me these interpretational questions are justified only to the extent that they make a difference to extending the theory. Also your argument isn't a theory IMO, it's more a supposed possible plausible argument for motivating parts of it, and I just think it isn't that plausible after all.
So my opinion, implies that I think that QM needs revision. Not because it doesn't make sense for most of particle and atomic physics, but becaues we still have several issues, including gravity, that is not on par with this framework, and because there are IMHO clearly identifiable highly questionable assumptions in it's construction or axiomatisation.
What I mean specifically in the comment above is that I think a real observer, can not in a way that makes sense to me at least never simultaneously relate to all possible observables in the universe. This means that a justified argument, instead should acknowledge this and see how this changes the inference.
I think the result would be that the notion of a large state space of the universe, or a large set of possible measurements, from which one can shave out the observables and measurements state space seen by any subsystem is making the mistake byt not acknowledging where THIS very inference lives. As I see it, this inference must be executed by a third real observer. And in general an observer is bounded.
The implications of this, would then suggest a new direction to be explore. Namely one where the QM framework with hilber spaces and operators, rather is a result of evolution, but not in the decoherence sense, but in a more intrinsic sense where there is no outside description of it. It would be an evolving law.
What I HOPE to eventually understand, but which isn't yet developed, is why the specific representations and structures of operators incl commutators in QM is the way is is, from a fitness perspective. I've always had as a for me plasible working hypothesis that QM logic is a result of a kind of data compression. Where the information state space (hilbert state space) can be understood as the state space of an encoded observations, that is preferred since it provides a more memory/cost effective basis for actions.
/Fredrik
  • #101
You're right. It's a little off, because your example earlier shows that subalgebras in the algebraic formulation do not in general correspond to subsystems in the Hilbert space formulation. I don't know what I should be asking instead, so I'll just say that nothing that I know of gives me any reason to think that the problems I've been talking about can be avoided by using the algebraic approach to QM. We're going to need the Born rule or something equivalent to it, no matter what approach we're using, and its main purpose (in the MWI) is to define ways to decompose the "omnium" into subsystems.
Each decomposition defines a specific way to describe the unitary time evolution of the state vector of the universe in terms of correlations between subsystems. (This is a lot like how each inertial frame in SR gives us a specific way to describe what's going on in the universe).
  • #102
You guys might be interested in some info on the many minds approach (essentially MWI) here:
http://thestargarden.co.uk/The%20Everett%20Approach.html"
http://thestargarden.co.uk/What%20happens%20when%20the%20world%20splits.html"
http://thestargarden.co.uk/What%20are%20probabilities.html"
http://thestargarden.co.uk/Lockwood%20and%20utilitarianism.html"
http://thestargarden.co.uk/Proving%20parallel%20worlds%20exist.html"
http://thestargarden.co.uk/Quantum%20mechanics%20and%20biology.html"
http://thestargarden.co.uk/The%20anthropic%20principle.html"
http://thestargarden.co.uk/Freewill.html"
  • Quantum Interpretations and Foundations
11K
