- #36
- 13,349
- 3,122
The first postulate of QM...?:uhh:
Daniel.
Daniel.
The first postulate of QM is as given in Cohen-Tannoudji et al is defined asdextercioby said:The first postulate of QM...?:uhh:
Daniel.
There is nothing in there which demands one have learned group theory. One need only understand what a state space is. Whether it is a group one is not required to know.At a fixed time t0, the state of a physical system is defined by specifying a ket |[itex]\psi(t_0)[/itex]> belonging to the state space.
lecture notes on QM said:"The state of a quantum system at a certain moment of time is described by sequence at most countable
[tex] \left\{|\psi_{k}\rangle,p_{k}\right\} [/tex]
,in which [itex] |\psi_{k}\rangle [/itex] are normalized vectors from a separable Hilbert space called "the space of states associated to the system" and [itex] p_{k} [/itex] are real nonnegative numbers satisfying the normalization condition
[tex] \sum_{k} p_{k} =1 [/tex]
and are called weights associated to the vectors [itex] |\psi_{k}\rangle [/itex].
Nope what? "Nope" that is not what Cohen-Tannoudji et al states? I don't know why you're trying to respond to a question I directed to selfAdjoint but you haven't even addressed the question as if yet. The question wasdextercioby said:Nope.
Please give an example where group theory is absolutely necessary.
For what reason do you refer to it as "lightweight"? Is it because you consider that which is more mathematically oriented is defined as "heavy weight"? If so then that's pretty off-topic here.In the "lightweight" version I've been learned in school,the first postulate reads..
This is the elementary version taught in my school.It doesn't account for supraselection rules.
does what is impossible to do without group theory? You're not sticking to the question posed to selfadjoint. Seems more to me that you're trying to impress someone with math.There are more rigurous formulations using
*rigged Hilbert spaces.
*unit rays and Wigner's theorem.
*Bargmann's theorem and projective representations of symmetry groups.
*coherent subspaces accounting for supraselection rules.
pmb_phy said:Nope what? "Nope" that is not what Cohen-Tannoudji et al states?
pmb_phy said:For what reason do you refer to it as "lightweight"? Is it because you consider that which is more mathematically oriented is defined as "heavy weight"? If so then that's pretty off-topic here.
pmb_phy said:does what is impossible to do without group theory? You're not sticking to the question posed to selfadjoint. Seems more to me that you're trying to impress someone with math.
So what you're telling me is that you were not able to comphrehend this until you learned group theory? Unless you didn't catch the "absolutely" in my question?
