Quadratic identities
  • Thread starter zebra1707
By substituting y for 9x^2 solve 81x^4 - 63x^2 + 10 = 0
My attempt at a solution is:
y^2 - 7y + 10
(y-2)(y-5)
therefore y = 2 y = 5 Can someone double check this?
Cheers
Answers and Replies
That's correct. Now solve for x by setting 9x2 equal to each solution of y.
Many thanks for the reply?
Is this to check the solution?
It just seemed to easy for some reason - maths is not my strong point, might I add.
Cheers
Oh I see - are you then saying
9x^2 = 2
9x = +- Sqroot 2
x = + - Sqroot 2/9
9x^2 = 5
9x = +- Sqroot 5
x= + - Sqroot 5/9
Cheers
Mentallic
3,798
94
Yes that is correct :smile:
You can even check for yourself by substituing those x values back into the original quadratic equation. You should find they work.
The only reason it asked you to substitute [tex]y=9x^2[/tex] into the equation [tex]81x^4 - 63x^2 + 10 = 0[/tex] is because it makes it more simple and easy to see how it should be solved.
Rather than substituing, you could've always factorized it as so:
[tex]81x^4-63x^2+10=(9x^2-2)(9x^2-5)=0[/tex]
9x^2 = 2
9x = +- Sqroot 2
x = + - Sqroot 2/9
9x^2 = 5
9x = +- Sqroot 5
x= + - Sqroot 5/9
Cheers
√(ab) = √(a)√(b) ≠ a√(b) which is what you did between the first and second lines above.
You need to divide by 9 first, then take the square root of both sides.
[tex]9x^2 = 2 \rightarrow x^2 = \frac{2}{9} \rightarrow x = \pm\sqrt{\frac{2}{3}} = \pm\frac{\sqrt{2}}{3}[/tex]
Or take the square root of both sides completely, then solve for x
[tex]9x^2 = 2 \rightarrow \sqrt{9x^2} = \sqrt{2} \rightarrow 3x = \pm\sqrt{2} \rightarrow x = \pm\frac{\sqrt{2}}{3}[/tex]
Mentallic
3,798
94
Oh when I skimmed through it I read sqroot 2/9 as [tex]\sqrt{\frac{2}{9}}[/tex]. I didn't believe simplifying was top priority.
Thanks for spotting that Bohrok.
Hi there
Many thanks for both your assistance - it is greatly appreciated.
Cheers P
Related Threads on Quadratic identities
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
