Quadratic Residues
  1. Apr 2, 2006 #1
    I have this problem Ive been looking at for about 6 hours. It requires me to find all primes p such that 3 is a quadratic residue (mod p).
    All I could come up with is that every prime p ending in a 1 makes 3 a QR mod p. But this came after using excel and computing all primes. Surely there must be an easier way (assuming that my assumption is correct). The question does give a hint to use the Quadratic reciprocity law, but I have no idea what that is! :redface:
  3. Apr 2, 2006 #2
    Looking up that law wouldn't be a bad idea, don't you think? :smile:
  4. Apr 2, 2006 #3
    This is my version of the QRL, there may be others written differently.
    [tex]\mbox{Let }p\mbox{ and }q\mbox{ be distinct odd prime numbers. Then}[/tex]
    [tex](p/q)(q/p) = (-1)^{(p-1)(q-1)/4}}[/tex]
  5. Apr 2, 2006 #4
    The first thing I did was realize that the question was also asking that
    [tex] 3 \mbox{ is a Quadratic Residue } \Leftrightarrow 3^{\frac{p-1}{2}} \equiv 1(\mod p)[/tex]
    which means that all primes p such that 3 is a QR mod p will be a solution to the above congruence. So I started testing
    p=3
    [tex]3^1 = 3 \equiv 0(\mod 3)[/tex]
    p=5
    [tex]3^2 = 9 \equiv 4(\mod 5)[/tex]
    p=7
    [tex]3^3 = 27 \equiv 6(\mod 7)[/tex]
    p=11
    [tex]3^5 = 243 \equiv 1(\mod 11)[/tex]
    I was doing all the calculations in excel, and when I filled the columns in, I got equivalent to 1 mod p whenever my prime p ended in a 1.
    But I realize this method used only Euler's Criterion, nowhere did I use the QRL.
  6. Apr 2, 2006 #5
    shmoe
    What did you get for 13? 41? Something is wrong with your calculations if you went this far and ended up with that conclusion.
    In any case, a finite number of calculations like this would never be able to prove a general result. It can point towards a general conjecture, but not prove it.
    Try using the law of quadratic reciprocity. It lets you turn a question about whether 3 is a quadratic residue mod p to a question about whether p is a quadratic residue mod 3 (and there's a simple congruence critera for this).
  7. Apr 2, 2006 #6
    AKG
    Let a and b be odd numbers. Then:
    (a/b) = (b/a) if a = 1 (mod 4) or b = 1 (mod 4)
    ........= -(b/a) if a = b = 3 (mod 4)
    Also, if p is an odd prime, a and b are integers, then
    (a/p)(b/p) = (ab/p)
    Of course, you also know that:
    (a/p) = ([a modulo p]/p)
    So with all these facts, you should be able to find the answer.
  8. Apr 3, 2006 #7
    You're absolutely right, my aim in doing that was to find a pattern which could motivate a possible line of attack in solving it. Unfortunately it didnt work, as we all now know.
    Ok, so now I have to determine whether or not a prime p is a QR mod 3.
    The Legendre symbol [itex](3/p)[/itex] equals 1 if 3 is a QR mod p right?
    Then Euler's criterion says that if [itex](3/p) = 1[/itex] then
    [tex]3^{(p-1)/2} \equiv 1(\mod p)[/tex]
    Then the QRL says that if [itex]3,p[/itex] are odd primes, and if [itex]3,p \equiv 3(\mod 4)[/itex], then
    [tex](3/p) = -(p/3)[/tex]
    Working backwards now, we have that if [itex](p/3) = 1[/itex] then
    [tex]p^{(3-1)/2} \equiv 1(\mod p)[/tex]
    which equals
    [tex]p\equiv 1(\mod p)[/tex]
    So p is a QR mod 3 if [itex]p\equiv 1(\mod 3)[/itex]
    This looks sketchy to me, I may have forgotten a negative sign too. hmmm Am I close?
  9. Apr 3, 2006 #8
    shmoe
    yes, and -1 if it's not.
    No need for Euler's criterea here.
    Yes. Another case to consider is when p is 1 mod 4.
    This goes both ways, but there's no need to use Euler's critera. 1 is a QR mod 3 and 2 is not, so it's clear which primes mod 3 are quadratic residues.
    So if p=3 mod 4 and p=1 mod 3, is 3 a QR mod p or not? And the other cases?
  10. Apr 3, 2006 #9
    So p=1,7,13,19,etc... could be QR because they are all congruent to 1 mod 3, is this right?
  11. Apr 3, 2006 #10
    shmoe
    Quadratic residues mod p, yes. if a=b mod p then (a/p)=(b/p)
  12. Apr 3, 2006 #11
    Where did "if [itex]p\equiv 3(\mod 4)[/itex]" come from?
  13. Apr 3, 2006 #12
    shmoe
    When you applied the law of quadratic reciprocity you had assumed that p=3 mod 4, you have to consider the other case as well.
  14. Apr 3, 2006 #13
    Ok, so I have two cases:
    1.
    [tex]p \equiv 1(\mod 3)[/tex]
    [tex]p \equiv 3(\mod 4)[/tex]
    2.
    [tex]p \equiv 1(\mod 4)[/tex]
    and using both cases togther I should be able to find exactly what p should be, instead of an (infinite) list of possible primes like I had before?
  15. Apr 3, 2006 #14
    shmoe
    What if p=2 mod 3?
    You need more cases, you have to consider what p is mod 3 and what it is mod 4, 2 possibilities for each.
  16. Apr 3, 2006 #15
    But I found that p=1(mod 3). And the only restrictions I have imposed from the QRL are that p=3(mod 4) and p=1(mod 4). What other restrictions are there? I havent said anywhere that p=2(mod 3).
  17. Apr 3, 2006 #16
    shmoe
    No you didn't! You found that when (p/3)=1 you must have p=1 mod 3. But you arbitrarily imposed this condition (p/3)=1, why couldn't it have been -1? actually looking back if you were trying to force (3/p) to be 1 then you wanted (p/3)=1 then you should have looked at (3/p)=-1 (this was when you were in the case p=3 mod 4).
    There's a couple of things you need to know about to find (3/p),
    1)how (3/p) relates to (p/3). this is entirely determined by p=1 or 3 mod 4
    2)what is (p/3)? this is entirely determined by p=1 or 2 mod 3
    Hence the 4 cases. These will cover all primes
  18. Apr 3, 2006 #17
    STEP 1.
    Find all primes p such that 3 is a QR (mod p)
    <==> (by the QRL)
    Find all primes p such that p is a QR (mod 3)
    STEP 2.
    When is p a QR (mod 3)?
    p is a QR mod 3 precisely when (3/p) = 1.
    STEP 4
    The QRL says that if 3 and p are odd primes then
    1. (3/p) = (p/3) iff p=1(mod 4)
    OR
    2. (3/p) = -(p/3) iff p=3(mod 4)
    STEP 4.
    Take (3/p) = (p/3) (when p=1(mod 4))
    Then (3/p) = (p/3) = p^((3-1)/2) = 1(mod p)
    => p = 1(mod p)
    STEP 5.
    Take (3/p) = -(p/3) (when p=3(mod 4))
    Then -p=1(mod p) => p=2(mod p)
  19. Apr 3, 2006 #18
    So to answer your questions:
    1. (3/p) is related to (p/3) in two ways, each of which has its own restriction.
    2. What is (p/3)? Not sure yet...
  20. Apr 3, 2006 #19
    shmoe
    Remember if a= b mod 3 then (a/3)=(b/3)
  21. Apr 3, 2006 #20
    Since [itex](p/3) \equiv p(\mod 3)[/itex], then let [itex]a = (p/3)[/itex], and [itex]b=p[/itex], then from your last posted identity we have
    [tex]((p/3)/3)=(p/3)[/tex]
    Im not sure if this is what you wanted.
