Why Does the Inequality 3x2 + 13 < 12x Have No Real Solution?
In summary: Thanks, again!In summary, the inequality 3x2 + 13 < 12x has no real solution because 3x2 - 12x + 13 < 0. The property of the quadratic that makes it possible to argue that the graph is completely above the x-axis is the +1.
Peter G.
442
Hi,
Prove that the inequality 3x2 + 13 < 12x has no real solution
Is it because:
3x2 - 12x + 13 < 0
And, using the quadratic equation we have to square root a negative number, meaning, the answer will be always greater than 0, not smaller?
Thanks,
Peter G.
Yes, except you're missing one crucial point in your argument. Consider a parabola that is completely under the x-axis, it too will have non-real roots but it is less than zero for all x. Which property of the quadratic makes it such that you can argue that it's completely above the x-axis?
And if you're interested, a better proof (although yours isn't wrong) would be to complete the square instead.
Ah! Gotcha I think:
3x2 - 12x + 13
3 (x2 - 4x + 13/3)
3 (x - 4x + 4 -4 + 13 / 3)
3 ((x-2)2 - 4 + 13/3)
3 (x-2)2 + 1 = 0
The + 1 proves that the graph was transformed upwards.
Is that what you meant?
And, what's the property of the quadratic you mentioned?
Thanks once again,
Peter G.
Peter G. said:
Ah! Gotcha I think:
3x2 - 12x + 13
3 (x2 - 4x + 13/3)
3 (x-2)2 + 1 = 0
Thanks once again,
Peter G.
Good, you completed the square correctly. Now think about what it's telling us, for the expression [tex]3(x-2)^2+1[/tex] we can only have a value of 0 or more for the (x-2)2 part because any number squared is equal to or more than zero, and the constant multiplier of 3 means that it is in fact going to be a positive number for all x (equal to 0 at x=2). This, coupled with the +1 means it'll have to be more than zero for all x.
You just need to mention that if the value of a in ax2+bx+c is positive, then the quadratic is a :smile:, and if it is less than zero, it's a :frown:
Ok, cool! Thanks!
Oh, if you don't mind, just one last doubt:
Graph the following showing the vertex and x and y intercepts:
y = x2 + 3x + 5
First, I found it has no x intercept
The y intercept I found to be + 5
The vertex, by means of the completing the square: (x + 1.5)2 + 2.75, I found (-1.5, 2.75)
But I need another point do be able to plot don't I?
You've found that y = 5 when x = 0, and that the vertex is at (-1.5, 2.75). The axis of symmetry is a vertical line through the vertex, so another point on the graph will be at (-3, 5).
However, since you have the equation, you can also get as many points as you want by picking an x value and calculating the y value that goes with it.
y = x2 + 3x + 5
Yes. A parabola has an axis of symmetry. The vertex is on this axis. So draw a dotted line for the axis (x = -1.5), plot the vertex, (-1.5, 2.75), and plot the y-intercept (0, 5). The y-intercept is 1.5 units to the right of the vertex in the x-direction. Because of the symmetry, you'll have another point, 1.5 units to the left of the vertex in the x-direction, that has the same y-coordinate as the y-intercept. What is that point?
EDIT: Never mind, Mark44 beat me to it. :wink:
Nice, thanks for the alternatives, never thought about using the axis of symmetry and I always forget to resort to the simple skill of plugging the numbers in the equations :redface:
What are quadratics?
Quadratics are mathematical expressions of the form ax^2 + bx + c, where a, b, and c are constants and x is a variable. They are used to model various real-world phenomena, such as projectile motion and profit-maximizing production levels.
What is the quadratic formula?
The quadratic formula is a formula used to solve quadratic equations, which are equations in the form ax^2 + bx + c = 0. The formula is x = (-b ± √(b^2 - 4ac)) / 2a.
What are inequalities?
Inequalities are mathematical expressions that compare two quantities and show their relationship. They use symbols such as <, >, ≤, and ≥ to indicate which quantity is larger or smaller.
How are quadratics and inequalities related?
Quadratics can be used to model inequalities, particularly when dealing with maximum or minimum values. For example, a quadratic equation can represent the profit function of a company, and an inequality can be used to determine the production levels that will result in the maximum profit.
What are some real-world applications of quadratics and inequalities?
Quadratics and inequalities are used in a variety of fields, including physics, economics, and engineering. They can be used to model the motion of objects, optimize production and profit, and determine the maximum and minimum values of a given situation.
  • General Math
