Savant13
- 85
- 1
How does special relativity affect a quantized spacetime? Specifically, how can time and space be quantized the same way for all observers?
Savant13 said:Specifically, how can time and space be quantized the same way for all observers?
I guess there is no mainstream answer to this.
Savant13 said:How does special relativity affect a quantized spacetime? ...
BenTheMan said:There IS a mainstream answer, and it's that it's not consistent with special relativity.
A minimum length implies a breakdown of Lorentz Invariance at that scale. The reason is easy to see---in who's frame are you quantizing space? If I quantize space in my frame, and you come running by me really fast, then you see that my little chunk of quantized space is smaller by a factor of gamma. So "smallest chunk of spacetime" is a relative notion in special relativity.
Savant13 said:What I mean by 'the same to all observers' is that it should not depend on your velocity...
Haelfix said:Regge calculus is sort of the historical forebear to the whole atom of space idea. You can retain lorentz invariance provided that there is enough residual symmetry left over in the marginal operators, not unlike textbook lattice gravity.
The problem really is getting these five (not necessarily independant) conditions to mix:
1) Lorentz invariance or at least lorentz breaking effects but only up to very small factors (which is very constraining and hard to do)
2) Flat spacetime in at least some sort of limit (as opposed to crumpled up phases)
3) Manageable entropy densities (as opposed to Planckian entropy^4, which leads to ridiculous cosmologies)
4) Unitarity
5) Existence of a continuum limit.
All treatments known to date end up sacrificing 1 or 2 conditions, depending on the context.
Haelfix said:ST is not a discretization theory (atom of space idea) so it doesn't apply. Incidentally, LGQ is not really a discrete theory either. CDT is though!
Savant13 said:LQG is definitely discrete
Haelfix said:...LGQ is not really a discrete theory either. CDT is though!
Savant13 said:In Three Roads to Quantum Gravity, author Lee Smolin, one of the founder of LQG explicitly states that spacetime is quantized in LQG
marcus said:that was a non-mathematical popularization written for wide audience.
But it does mean it's unlikely to be precise, and a Bad Idea to cite authoritatively.Savant13 said:That does not mean that the statement was not correct on some level.
Haelfix said:I'm not the best one to ask about that sort of question, I am sure a stheorist could explain it better and with more authority.
From what I gather the question becomes illdefined. If you start probing the string (either via scattering or dumping energy into the free string) eventually past a certain point (not necessarily the Planck scale, but thereabouts) you no longer are probing strings, but rather black holes (b/c all that energy density eventually pushes the system past its Schwarzschild radius). At that point, transplanckian physics is no longer well described by string theory, but becomes quasi classical again (eg GR.. scattering of black holes and so forth).
In a certain sense, that's kinda what you want. It makes good sense that the degrees of freedom of a QG theory when pushed to the extreme breaking point eventually lose their significance b/c you can no longer ask questions about them since they lie behind horizons.
As for whether or not the spacetime is smooth. Well again, the question is a little fuzzy and only makes sense in certain limits. The metric is only part of the degrees of freedom of the whole (as yet to be understood) shebang, in fact its presumably not fundamental and therefore emergent. The main (string/brane) d.o.f as well as the precise nature of the moduli should in principle contribute to its dynamics, but like all emergent systems the technical details becomes really challenging. Still, since those d.o.f are decidedly quantum and fuzzy its a little hard to say with a straight face that spacetime is 'smooth'.. Its only 'smooth' when we make it so (by hand) as a sort of initial condition for calculational tractability.
Savant13 said:I'm not talking about strings. Can we please stop dragging other theories into this?
Quantized spacetime is a concept in physics that suggests that space and time are not continuous, but are instead made up of discrete units or "quanta". This idea was first introduced by the physicist Max Planck and has been further developed in the field of quantum mechanics.
Special relativity, developed by Albert Einstein, describes the relationship between space and time and how they are affected by the speed of an object. The concept of quantized spacetime is important in special relativity as it suggests that space and time are not absolute, but are relative to the observer and can be affected by factors such as velocity.
One of the main pieces of evidence for quantized spacetime is the phenomenon of blackbody radiation, which showed that energy is emitted in discrete units or "quanta". Additionally, experiments with particle accelerators have also provided evidence for the existence of quantized spacetime.
The idea of quantized spacetime has significant implications for our understanding of the universe and has led to the development of theories such as quantum field theory and string theory. It suggests that at a fundamental level, space and time are not continuous and can be affected by factors such as gravity and the behavior of subatomic particles.
While the concept of quantized spacetime is still largely theoretical, it has led to the development of technologies such as the laser and the transistor, which have had significant impacts on our daily lives. Additionally, understanding the nature of spacetime is crucial for advancements in fields such as quantum computing and space exploration.
