Quantum Dot Solids: Electron Minibands & Potential
In summary, the formation of minibands in quantum dot solids is a result of overlapping energy states of the coupling quantum dots. These minibands describe potential energy states, similar to bulk material energy bands. However, the specific potential between which states or bands the question is referring to is unclear. In the case of a 5 micron thick quantum dot solid, the transient field generated by a -10 V biased probe tip may cause excitons to form, potentially leading to the generation of transient positive currents into the probe tip. More information is needed to further clarify this question.
Christopher Rourk
Do electron minibands in quantum dot solids have a potential?
Hi
Could you give us some more information about your question?
It looks like you are doing some reading - good! But if you can tell us what you were reading - akin to the concept of a legal citation - the format does not matter. Good questions get good answers.
See https://www.researchgate.net/publication/234963173_Miniband_formation_in_a_quantum_dot_crystal. But its for interpreting some test results.
I haven't read the full paper because your question is still not accurate enough to give a satisfying answer. The minibands emerge from overlapping energy states of the coupling quantum dots. Similar to the bulk material energy bands that emerge from overlapping atomic orbitals. These (mini)bands are describing potential energy states so of course there are potentials. The question is what potential between what states or bands are you asking for?
Assume a 5 micron thick quantum dot solid, disposed on a ground plane, and a c-AFM probe tip at a -10 V bias. If the transient field generated as the probe tip comes into contact with the quantum dot solid causes excitons to form, could electron transport explain the generation of transient positive currents into the -10 V biased probe tip, as opposed to expected negative currents flowing out of the probe tip?
Let me know if you need additional info.
What are quantum dot solids?
Quantum dot solids are materials made up of a large number of quantum dots, which are tiny semiconductor particles. These dots are typically only a few nanometers in size and are arranged in a regular pattern.
How do quantum dot solids form electron minibands?
When a large number of quantum dots are brought close together, their energy levels become coupled. This results in the formation of electron minibands, which are energy levels that are closely spaced together and behave as a continuous band of energy.
What is the significance of electron minibands in quantum dot solids?
Electron minibands play a crucial role in the electronic properties of quantum dot solids. They allow for the manipulation and control of electron behavior, making these materials useful for a variety of electronic and optoelectronic applications.
How are potential barriers created in quantum dot solids?
Potential barriers in quantum dot solids are created by manipulating the size and shape of the quantum dots. By altering the dimensions of the dots, the energy levels can be controlled, creating potential barriers that can trap or confine electrons within the material.
What are potential applications of quantum dot solids?
Quantum dot solids have a wide range of potential applications, including in solar cells, LEDs, transistors, and sensors. They can also be used in quantum computing and for creating new types of materials with unique properties.
  • Atomic and Condensed Matter
