Is it possible to change a fundamental property of a particle?
In summary: However, in some cases, the particles involved will have to be of the same type for the entanglement to take place.
Adhruth Ganesh
If that can be done, will it's twin particle's state also be altered accordingly?
What exactly do you mean by "changing a fundamental property"?
Something like changing the spin?
What "twin particle"?
Changing what about the spin? Its magnitude or direction?
If two entangled particles are produced, let's take one of them to be the twin of the other.
Excuse me if I didn't get the terms right. I am new to this topic and this forum
Direction.
That's not really correct, since nothing requires the two particles to be of the same type.
Direction.
How are you going to change the direction of spin of one of the particles? Is it something that will also affect the other particle? Or are you arranging things so the particles are far enough apart that you can just act on one of them?
Yes. That is the case.
In the situation you describe, there are 2 types of transformations you can do on Alice's entangled particle (one "twin").
1. An irreversible measurement. Bob's particle will now be in a state consistent with the outcome of the measurement on Alice's particle (assuming an irreversible measurement has not already been performed by Bob). Note that the actual result of Alice's measurement is RANDOM.
2. A reversible operation on Alice's particle. This will have no effect on Bob's particle.
Likes Adhruth Ganesh, bhobba and PeterDonis
So does that mean if an irreversible measurement is made on Alice's particle and it is found to have a clockwise spin, does Bob's particle have an anti clockwise one (again, assuming an irreversible measurement has not been performed by Bob) ?
I didn't quite get what consistent means here.
It depends on the type of entanglement. Much entanglement is anti-correlated (opposite values), due to conservation principles. However, there are also cases where the entanglement is correlated. And other cases where the sum of 2 values will equal a constant, which is again due to conservation.
If it is selecting whether, for example, the spin is up or down, the result is random, but in accordance with what states are possible by the fundamental Schrodinger equation.
Fine. Thanks a lot.
Likes bhobba
two particle are entangle or not was decided at the moment when it was created. Such as an electron downward transition twice can create two photon with spin opposite entanglement.
That's not correct. Generally speaking, any time particles interact, they can become entangled.
Likes vanhees71
1. Can a fundamental property of a particle be changed?
Yes, it is possible to change a fundamental property of a particle through various methods such as particle accelerators, collisions, and high-energy experiments.
2. What are some examples of fundamental properties of particles?
Fundamental properties of particles include mass, charge, spin, and flavor. These properties determine the behavior and interactions of particles.
3. How do scientists change the fundamental properties of particles?
Scientists use advanced technology and techniques, such as particle accelerators, to manipulate and change the fundamental properties of particles. This allows them to study the effects of these changes on the behavior of particles.
4. Are there any limitations to changing fundamental properties of particles?
Yes, there are limitations to changing fundamental properties of particles. Some properties, such as mass, cannot be changed without altering the particle's identity. Additionally, the changes made to a particle's properties may only be temporary and may not be able to be sustained for long periods of time.
5. Why is it important to study the possibility of changing fundamental properties of particles?
Studying the possibility of changing fundamental properties of particles allows scientists to gain a deeper understanding of the fundamental building blocks of the universe. It also helps in the development of new technologies and advancements in various fields such as medicine and energy production.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
