Quantum interpretations
  • Thread starter The Dagda
  • #76
2,567
We start with what you call "back-references" but it is going back to the true fundamentals of science...the experiment. Get too far from this and you begin arguing about things no-one can observe and that is a theological debate, not science.
No of course not. At some point the mathematical terms must be related to the physical...that by the way is the true interpretation of the theory. How a ket or Hermitian operator relates to an actual experimental device.
How can we define anything without "we"? Science is what scientists do.
I think I found why our views are so different.
Take the Classical mechanics. lets take F=ma. Do you see any 'we', 'our knowledge about'? For that reason Hilbert wanted to find the axiomatisation of physics.
No, the fundamental of science is a THEORY. An experiment is just a tool to prove or disapprove it. Without theories, the science would be just a heap of recepies... like alchemistry... This is what science about: the underlying formulas!
Let me ask some questions again
What do you think about the max Tegmark program 'physics from scratch'
We define TOE is a pure mathematical form, TOE(f)=0. So there are only equations, no words. Then we derive everything from there. We ask 'what a complicated system would percieve?" building frog's view from the equations?
Or do you believe that there are some 'physical' axioms which can not be expressed in forms of equations?
Do you agree that MWI is the best to be expressed in the TOE(f)=0 form?
Do you agree that MWI (when we pay a contre-intuitive price of accepting parralel realities) saves not only determinism, but also realism?
  • #77
2,567
Now, MWI assumes that all possibilities remain real (unless they cancel each other out, which is a very strange thing), and so removes the name "randomness". But the mechanics of why things happen this way in one world, and that way in another, are still missing.
it just seems a personal preference: Would you rather believe in randomness, or in trillions alternate versions of yourself and everyone else coexisting in trillions of alternate universes.
This is a very good question, I remember I was thinking about it when I learned the MWI...
I would say this is "no-issue": lets take dead/alive cat.
So what MWI predicts is that BOTH observers would say "I understand that there are alternative branches of reality where cat is alive/dead, but why *I* get this result, not another one? Why *my* consiousness is in THAT branch of reality???"
This is exactly what happens!
So MWI predicts BOTH (any) observer to be surprised and believe in randomness!
True
But again, waht is wrong with trillions alternative universes when our universe is INFINITE (in space at least)? If you multiply infinity by billion, the result is not bigger.
  • #78
2,567
And very definitely i see liquid water because all the particles have already decohered. Otherwise, very definitely, i wouldn't be able to see water. No one has ever seen a wavefunction. You see physical objects because their wavefunctions have "collapsed" to a single state.
The case with water is special, because H has only 1 electron, which means that if it's decohered, water molecules would fall apart, which is very definitely not the case.
Sorry, this is a nonsense
Please check how QED explains why light moves slower then C from water.
Hint: photons are slowed down because they are absorbed/reemitted by atoms, putting these atoms for a very short peiod of time into an excited state. That causes a delay. However, the process is absolutely reversible, so after photon had passed thru the water, there is no way to tell which atom had actually slowed the light down.
  • #79
258
True
To 1) No problem with the surprise factor, the appearance of randomness is a given.
However unless there is decoherence (which is the trivial case in both MWI and CI), MWI says the probabilities interact simply by mathematical operation, the physical process, the mechanics are still missing.
To 2) The problem is not the largeness of the number, but the belief that there would be (many) multiple alternate versions of each living being and non-living thing coexisting at the same time. Why would they not collide? Just because they are different terms in a wave function which can't be added mathematically? Doesn't that require a "how", a physical explanation?
  • #80
758
Why should I? What the heck does this have to do with anything that i was talking about?
No, what you say is completely not what i was talking about. I never spoke of light or c. You are talking about a subject of your choice, that i had no intention of discussing. Hint: Decoherence does not happen only when waves of matter hit photon waves.
  • #81
2,567
1. Mechanics is described in the Wiki article. It actually begins from the chapter "Mechanisms" :) There are all formulas you might need.
2. Why would they not collide? - because of the loss of coherence. Non-diagonal elements of the density matrix vanish, and branches lose the ability to influence each other. Check the "Density matrix" chapter.
  • #82
2,567
Because it is directly related to the subject we discuss:
OPTICAL effects (refraction, reflection, etc) are reversible and collapse-free. Put an aquarium behind 2 slits and still you will be able to see an interference pattern. This is an absolute proof that when photons pass thru water, they do not leave and 'which-path' traces, so there is no 'collapse' at all. So you can not say that 'photon had been slowed down by this and this hydrogen atom'. If you can say it then you know thepath and there would be no interference.
  • #83
Hurkyl
Staff Emeritus
If the wave function represents the physical state, then that is a physical explanation.
MWI worlds are not Sci-Fi parallel universes; they do not consist of distinct collections of matter living in parallel dimensions. Worlds are just another wave phenomenon, a product of evolution according to the Schrödinger equation. In principle, they could interfere, but that's incredibly unlikely for large systems, and essentially impossible for nonisolated systems.
  • #84
251
That's just explaining-away the randomness. To me the real paradox of quantum physics is that the probabilities of flying through either slit will interact with each other, but in the end the photon will appear only in one place, not smeared out like butter. And trying to measure the path will strangely make the interference go away. MWI doesn't seem to change that.
Yeah people seem to get all goose pimply when we say it's absolutely random, not chaotic but there is no way to know what state photons are in without a measure. MWI is I suppose just a semantic/philosophical issue, it makes no difference to scientists experiments or what actually is, except they have the notion that the wavefunction an abstract mathematical object is actually representing the pictorially and really the nature and image of photons, which of course we can't know. Strange times.
  • #85
vanesch
Staff Emeritus
Yes but this is the same as CI for all practical purposes, if so what's the point of it? I mean I can dream up anything to make QM deterministic does that mean my dreams exist?
First of all, the fundamental difficulty with QM in the CI is not its random character, but rather two other things:
1) the distinction in physical description of what is "observation" and what is "physical process". In other words, there are magical things out there which are called observers, and whenever they enter the picture, the way to solve the problem is different and mathematically incompatible with whatever are the rules when we consider physical processes. In other words, the way quantum theory is usually done (as in CI), it is impossible to analyze, from within the theory, what is the physical process of observation.
You cannot analyze detectors quantum-mechanically, in principle. You cannot write the Schroedinger equation of a detector. Of course, you can, but then your detector is no detector anymore.
2) The problem with Bell, if we insist on locality.
If in experiment QM is random, and in MWI which in experiment appears random where's the difference and isn't that just semantics?
Again, the problem is not the randomness per se. It is the fact that in CI, it is in principle impossible to describe the detection process. This is the problem that MWI tries to solve, and you get as two bonuses, that Bell isn't a problem anymore, and that on top of that, the objective reality (contrary to the subjectively perceived reality) became deterministic.
In how much this is actually *true* is a totally different (and in my opinion even irrelevant) matter. What you do get from it is a much clearer picture of how things are behaving *according to quantum theory*, because there's a whole lot of fuzzy handwaving contradiction that is gone now. It's why I like it.
Yes, I'm god, but don't tell anyone, I'm incognito :wink:
  • #86
vanesch
Staff Emeritus
The answer to that is simply the fact that the time evolution operator is a linear operator. You cannot influence the result of a linear operator acting on something, by adding something to the argument.
U (a + b) = U(a) + U(b).
U(a) is independent of whether there was a b or not.
Now, there is a "non-linear" part somewhere, which is the amplitude-> probability change. Indeed, if U(a) and U(b) have a common component, then the amplitude -> probability change will be influenced by the presence or not of b and hence U(b).
However, if a is a vector in many many dimensions and so is b, and they are essentially orthogonal, then (because U is not only linear, but also unitary), U(a) will also be orthogonal to U(b). As such, in the amplitude -> probability transition, you will not have any effect of the presence or not of b (and U(b) ).
That's what decoherence essentially tells you. Whenever you get hopelessly entangled, every "world" is essentially orthogonal to any other, and this will remain so. So the presence of another world or not will not influence whatever happens to one.
As long as a and b are not hopelessly orthogonal, you do have effects in the amplitude -> probability transition of the presence or not of b, and that is exactly what we call quantum interference.
  • #87
251
See that's why I don't like it, it's too convenient. It's like string theory: what physics would be like if God was a mathematician. But I suppose it's all hand waving at the end of the day to try and solve handwaving issues.
As physicists say the universe has no regard for what you expect to be true only what is.
  • #88
vanesch
Staff Emeritus
I'm not a mathematician (but I play one on TV...) :biggrin:
The way I view MWI is not as some "ultimate truth", but rather as the bare bones logical consequence of the theory of quantum mechanics if you want to keep to the math and the logic all the way down. The price to pay is that it doesn't fit at all with any preconceived ideas of what could be reality, but what you win from it is a crystal-clear view on the wheels and gears of the quantum-mechanical formalism, and that all so-called paradoxes disappear in a puff of logic. There are no difficulties anymore in viewing any EPR experiment, or any quantum eraser experiment or anything. It all comes out very clear.
(ok, what becomes incomprehensible in this view is general relativity of course...)
In other words, to me, MWI is the picture I try to keep in my mind when doing quantum mechanics, in order to "understand" and "get a feeling" for how the theory behaves. You can't do that if you are having a machinery which produces you apparently paradoxical situations, and so the fact of removing those, and even removing all the ambiguity of "do I measure this here now or not ? " or "is the information still available or not ? " or "did this polarizer actually measure the polarisation or not" and all the handwaving that comes with CI-style views on some more subtle experiments disappears completely from an MWI viewpoint.
Questions raised by CI, such as: if the detector clicks, but I don't look, is there a measurement or not ? And if I destroy the record ? And if I throw it in a black hole ? and over which one can have heated philosophical debates become a trivial issue from the MWI viewpoint.
  • #89
251
God is on TV playing a mathematician! :D I must notify The Vatican?!??
  • #90
2,567
Very good description of the 'enlightment' I felt whan I realized the beauty of MWI!
The second enlightment I experienced when I read the Max Tegmark article about the Mathematical Universe... what do you think about it?
  • #91
vanesch
Staff Emeritus
Not in every universe, of course, but in some, He (I) is (am) :biggrin:
  • #92
vanesch
Staff Emeritus
Don't know what it is. Are you talking about his classifications of infinity in different universes ?
  • #93
758
I never ever said anything about light. I don't agree that only light can "collapse" the wavefunction of H. I don't agree with Decoherence because we can only observe particles, not waves. Do you understand? When you are looking at a glass of water, its atomic particles have collapsed, if they weren't you wouldn't see water. Any system that is isolated from interactions with the environment, according to Decoherence, is invisible. The fact that a cup of water is visible, means that ALL(each and every damn particle) has already collapsed?
And Decoherence is strictly an irreversible process, once decohered particles are particles, not waves.
And what happens to the 1 electron H atoms in the H2O molecule? It breaks apart, because the electron has collapsed to a single state and can no longer be at multiple places all at once and keep the covalent bonds between atoms in the molecule.
If you haven't grasped what I am saying, i will no longer reply to your posts.(and notice I am not talking about any light whatsoever).
  • #94
2,567
Offtopic: Dont know what is the show, but just curious, did you change the scripts? Did you ever tell them "I will not repeat this because it does not make any sense?"
You know, things like "Switch on the wormhole drive! Oh, no, the graviton emitter does not function! Somebody has to go there and repair a Higgs particle reflector plate manually!" :)
  • #95
2,567
http://arxiv.org/abs/0704.0646v2
It had really opened my eyes!
He touches slightly MWI, but it is not the point.
THe main point is that PHYSICS = MATHEMATICS
  • #96
2,567
That is why I provided you a proof that when light interacts with water, there is no decoherence/collapse.
Just peform the 2 slit experiment in water. Result will be the same.
You are wrong saying that 'we can observe only particles, not waves'. When you observe water with gamma rays, their wavelength is short enough so they hit an electron in H, measuring its position, so it irreversibly flies away leaving a detectable track.
Visible light has a wavelength much longer then an atom, so it does not reveal any 'particle' nature of electron in atom. This process is resersible, it does not leave any detectable tracks in water. There is no collapse/decoherence
  • #97
Hurkyl
Staff Emeritus
What do you mean? Decoherence is a reality, both theoretical and experimental.
No it's not. The simplest model for decoherence is given by unitary evolution -- a process that is by definition reversible.
The way you talk about "particles" and "waves" makes it sound like you're thinking of their meaning in classical mechanics, which is definitely incorrect....
  • #98
258
To 1) I'm not talking about decoherence from a mathematical point of view, all the formulas may be there... but they appear as a high-level formula with a missing low-level explanation, which is a problem of the wavefunction in general. A sum of probabilities with a complex amplitude that can interact with each other, or not. In my view that is not a physical explanation. The "wavefunction" isn't similar to the description of a classical wave. In a classical wave, there is a physical explanation of why it behaves that way. In quantum physics, MWI postulates that the wave function should be taken for granted, even as a physical reality. That would be some odd reality to take for granted.
To 2) That's a purely high-level mathematical statement. It doesn't say how it can be possible that two photons cancel each other out. Just because the formula says so?
MWI doesn't solve the mystery of the probability-nature of quantum physics, just a tiny fraction of it, if at all, at the expense of asking us to believe that there are trillions of worlds with trillions of alternate versions of each human being.
  • #99
258
If it is, then it is. If not, then not. For me that would be like believing that floating point numbers have a physical existence.
But each world would have conscious human beings, you would be conscious in each of many worlds which result from you observing a quantum phenomenon, since there is no explanation why most of those would be only mathematical constructs and only one of them with real conscious human beings. So how is this not "parallel universes", as a result for us human beings?
  • #100
2,567
ColorSpace, regarding the physical explanations
There are some constants (like water density at 0C) which can be derived from c,h,and other parameters of the Standard Model.
However, the fundamental constants like G, h,c can not be calculated this way
The same for the laws. Some things, like viscosity, have someunderlying mechanisms, so you can give a physical explanation of a phenomena. However, fundamental physical laws do not have any futrher explanations and do not have any sub-components... just formulas
Related Threads on Quantum interpretations
