Homework Help: Quantum Mechanics: Eigenstate
  1. Feb 16, 2015 #1
    Calculate ##\triangle S_x## and ##\triangle S_y## for an eigenstate of ##\hat{S}_z## for a spin##-\frac12## particle. Check to see if the uncertainty relation ##\triangle S_x\triangle S_y\ge \hbar|\langle S_z\rangle|/2## is satisfied.
    2. Relevant equations
    ##S_x =\frac12(S_+ +S_-)##
    ##S_y = \frac{1}{2i}(S_+-S_-)##
    3. The attempt at a solution
    I am not sure what I have to do in this problem. For the matrix representation I have that:
    ##S_x = \frac{\hbar}{2}\left[\begin{array}{ c c }0 & 1 \\1 & 0\end{array} \right]##
    ##S_y = \frac{\hbar}{2i}\left[\begin{array}{ c c }0 & -1 \\1 & 0\end{array} \right].##
  3. Feb 16, 2015 #2
    Orodruin
    Staff Emeritus
    2017 Award
    What is the definition of uncertainty? I suggest you start from that and see what you can find based on it.
  4. Feb 16, 2015 #3
    I was more concerned on the first part of the question.
  5. Feb 16, 2015 #4
    Orodruin
    Staff Emeritus
    2017 Award
    Yes? The uncertainty is ##\Delta S_x##, how is it defined? Later you can go on to the uncertainty relation, which as the name suggests is a relation of uncertainties.
  6. Feb 16, 2015 #5
    Ops, I thought you were talking about the uncertainty relation. But regarding ##\triangle S_x## the uncertainty is defined as ##\sqrt{\langle S_x^2\rangle -\langle S_x\rangle^2}##, where ##S_x = \frac{\hbar}{2}P_1 -\frac{\hbar}{2}P_2##.
    So all I do is do matrix multiplication with ##S_z##, i.e.
    ##(S_x) (S_z)=\frac{\hbar}{2}\left[\begin{array}{ c c }0 & 1 \\1 & 0\end{array} \right]
    \left[\begin{array}{ c c }1 & 0 \\0 & -1\end{array} \right].##
  7. Feb 16, 2015 #6
    Orodruin
    Staff Emeritus
    2017 Award
    So what do you get when you evaluate the expectation values for an eigenstate of ##S_z##? How do you compute the expectation value of any operator in a given state?
  8. Feb 16, 2015 #7
    To compute the expectation value of any operator ##\hat{\mathbb{O}}## for a particle in the state ##|\phi\rangle## is defined as ##\langle \hat{\mathbb{O}}\rangle = \langle \phi|\hat{\mathbb{O}}|\phi\rangle.## But what will the eigenstate for ##S_z## be?
  9. Feb 16, 2015 #8
    Orodruin
    Staff Emeritus
    2017 Award
    I suggest you take one of the ones required by the problem statement, i.e., any of the eigenstates of ##S_z##.
  10. Feb 16, 2015 #9
    That doesn't help me understand.
  11. Feb 17, 2015 #10
    Orodruin
    Staff Emeritus
    2017 Award
    So let us try it this way: What are the eigenstates of ##S_z##?
    Edit: Also, you should perhaps look for a different way of computing your expectation values. I suspect the one you quoted will not be very helpful. How would you compute ##P_1## and ##P_2## and how would you compute ##\left< S_x^2 \right>##?
  12. Feb 17, 2015 #11
    Well, in the book it states that ##\hat{\mathbb{J}}_+|\lambda,m\rangle## is an eigenstate of ##\mathbb{J}_z## (where I was told that ##\mathbb{J}_z## and ##\mathbb{S}_z## are interchangeable)##.
    So I can't use ##S_x = \frac{\hbar}{2}P_1 -\frac{\hbar}{2}P_2##? I do not know any other way of computing the expectation values other than that definition.
  13. Feb 17, 2015 #12
    Orodruin
    Staff Emeritus
    2017 Award
    Yes, but it requires that you already are familiar with another eigenstate. Are you familiar with how to find the eigenvectors of a matrix?
    Not unless you figure out how to comput ##P_1## and ##P_2##. What about the way you quoted in post #7?
  14. Feb 17, 2015 #13
    Yes, I am familiar with how to find eigenvectors. In quantum mechanics, I have difficulty in setting up the problem correctly. Computing it, I can do but setting it up I need a lot more practice with.
    That I know how to compute, its just that I am having trouble finding ##|\phi\rangle##. Since we have ##S_x##, i.e., ##
    S_x = \frac{\hbar}{2}\left[\begin{array}{ c c }0 & 1 \\1 & 0\end{array} \right].## Thus, I need to compute ##\langle\phi|S_x|\phi\rangle##.
  15. Feb 17, 2015 #14
    Orodruin
    Staff Emeritus
    2017 Award
    So, how do you represent ##S_z## in matrix form? What are the eigenvectors of that matrix? (The eigenvectors of the matrix represent the eigenstates.)
  16. Feb 17, 2015 #15
    In matrix form ##
  17. Feb 17, 2015 #16
    Orodruin
    Staff Emeritus
    2017 Award
    ... and so the eigenvectors are ...
  18. Feb 17, 2015 #17
    Will the eigenvectors just be ##|+z\rangle = {1\choose 0}## and ##|-z\rangle ={0 \choose 1}?##
  19. Feb 17, 2015 #18
    Orodruin
    Staff Emeritus
    2017 Award
    You tell me. Is ##S_z |+z\rangle = \lambda_+ |+z\rangle## for some constant ##\lambda_+##?
  20. Feb 17, 2015 #19
    Yup, it does satisfy that. I made this more difficult than it is. -__-. Thank you very much!
  21. Feb 17, 2015 #20
    Orodruin
    Staff Emeritus
    2017 Award
    Just to resolve the problem itself: What do you get for ##\langle S_x\rangle## and ##\langle S_x^2 \rangle##, respectively? What is the resulting uncertainty relation?
  22. Feb 17, 2015 #21
    Using ##\langle \hat{\mathbb{O}}\rangle = \langle \phi|\hat{\mathbb{O}}|\phi\rangle \implies \langle +z| S_x|+z\rangle.## Therefore, ##\langle S_x\rangle = 0##
  23. Feb 17, 2015 #22
    Orodruin
    Staff Emeritus
    2017 Award
    Yes, this is correct. And ##S_z^2##?
  24. Feb 17, 2015 #23
    ##S_x^2## will also equal ##0## since , ##\langle S_x\rangle^2=0##.
  25. Feb 17, 2015 #24
    No, ##S_x^2## is a different operator than ##S_x##. So you need to actually compute its uncertainty by itself.
  26. Feb 17, 2015 #25
    Opps, thank you very much for catching that! It will equal ##\frac{\hbar^2}{4}## instead of ##0##.
Have something to add?
Draft saved Draft deleted
