Finding Eigenstates and Energies in Quantum Mechanics Exercise
In summary, the conversation discusses the 1D potential for three particles with mass m and the finding that a coordinate change can make solving the Schrodinger equation easier. The resulting Hamiltonian is found to be the sum of three independent Hamiltonians for two harmonic oscillators and a free particle, with different frequencies and energies. The ground state energy and wave function are determined and it is concluded that the particles being bosons or fermions does not affect the results.
eoghan
207
Let there be 3 particles with mass m moving in the 1D potential:
[tex]\frac{k}{2}[(x_1-x_2)^2 + (x_2-x_3)^2 + (x_1-x_3)^2][/tex]
where [tex]x_i[/tex] is the coordinate of the particle i.
1)Show that with the following coordinat change the Schroedinger equation is easy to solve:
[tex]y_1=x_1-x_2[/tex]
[tex]y_2=\frac{1}{2}(x_1+x_2)-x_3[/tex]
[tex]y_3=\frac{1}{3}(x_1+x_2+x_3)[/tex]2) Find the eigenstates and the energies of the equation you got in point 1)
[tex]x_1-x_2=y_1[/tex]
[tex]x_2-x_3=y_2-\frac{1}{2}y_1[/tex]
[tex]x_1-x_3=y_2+\frac{1}{2}y_1[/tex]
[tex]V=\frac{k}{2}\left[\frac{3}{2}y_1^2+2y_2^2\right][/tex]
[tex]H=\frac{P_1^2}{2m}+\frac{P_2^2}{2m}+\frac{P_3^2}{2m}+V[/tex]
So I have 2 independent harmonic oscillators with angular frequencies [tex]\sqrt{\frac{3k}{2m}}[/tex] and [tex]\sqrt{\frac{2k}{m}}[/tex]
and a free particle whose eigenfunction is [tex]exp\left[\frac{i}{\hbar}\vec P\vec r\right][/tex]
So the eigenstates are the tensor product of the eigenstates of two harmonic oscillators and an exponential.
The energies are [tex](a+\frac{1}{2})\hbar w_1+(b+\frac{1}{2})\hbar w_2 + E[/tex]
where w1 and w2 are the two frequencies of the two harmonic oscillators and E is the energy of the free particle.
You need to convert the momenta to the new coordinates as well.
ok, if I convert the momenta I get:
[tex]H=\frac{2P_1^2}{2m}+\frac{3}{4m}P_2^2+\frac{5}{18m}P_3^2+V[/tex]
Where [tex]P_i[/tex] now refers to the momenta in the new basis.
Now the new Hamiltonian can be written as [tex]H=H_1+H_2+H_3[/tex]
So I have the hamiltonian of 3 independent particles:
[tex]H_1=2\left[\frac{P_1^2}{2m}+\frac{k}{2}\left(\frac{3}{4}y_1^2\right)\right][/tex]
[tex]H_2=\frac{3}{2}\left[\frac{P_2^2}{2m}+\frac{k}{2}\left(\frac{9}{4}y_2^2\right)\right][/tex]
[tex]H_3=\frac{5}{9}\left(\frac{P_3^2}{2m}\right)[/tex]
H1 and H2 are two independent harmonic oscillators with their own frequency, and H3 is an independent particle whose energy is multiplied by 5/9
Is this right?
I got the same potential in terms of the y's, but for the kinetic term, I found
[tex]\frac{1}{2m}\left(\frac{1}{2}p_1^2+\frac{2}{3}p_2^2+3 p_3^2\right)[/tex]
Besides the constant factors, though, you're correct in that you get what looks like two oscillators and a free particle. The coordinate y3 is the center of mass of the three particles, so the "free particle" is actually the system taken as a whole.
Uhm... I calculate the momenta in the new coordinates again and I get:
[tex]\frac{1}{2m}\left(2p_1^2+\frac{3}{2}p_2^2+\frac{1}{3}p_3^2\right)[/tex]
Anyway... in the end, the energy is the sum of 3 energies:
E1: energy of a harmonic oscillator with mass m/2 (or 2m according to your result) and frequency [tex]\left(\omega=\sqrt{\frac{m}{k}}\right)[/tex] w=3 (or 3/4 according to your results);
E2: the energy of the second harmonic oscillator
E3: the energy of a free particle of mass 3m, i.e. E3=[tex]\frac{P_3^2}{3m}[/tex]
Your answer is probably right. A mass of 3m for the whole system makes more sense than m/3.
EDIT: I redid the calculation and now get the same result you did.
And if the 3 particles are bosons what is the ground state energy?
I guess it is:
3*(E1+E2+E3)
and the wavefunction is:
[tex]\frac{\psi_1(x_1)\psi_2(x_2)\psi_3(x_3)+\psi_1(x_1)\psi_2(x_3)\psi_3(x_2)+\psi_1(x_2)\psi_2(x_1)\psi_3(x_3)+\psi_1(x_2)\psi_2(x_3)\psi_3(x_1)+\psi_1(x_3)\psi_2(x_2)\psi_3(x_1)+\psi_1(x_3)\psi_2(x_1)\psi_3(x_2)}{\sqrt{6}}[/tex]
But then, wouldn't the energy be 6*(E1+E2+E3)?
Where [tex]\psi_1[/tex] is the wavefunction of the first harmonic oscillator,
[tex]\psi_1[/tex] is the wavefunction of the second HO
and [tex]\psi_1[/tex] is the wavefunction of the free particle
Ah.. no...the energy is still 3*(E1+E2+E3) because I have to divide by 6
I guess it is:
3*(E1+E2+E3)
What are E1, E2, and E3? The argument of the wavefunctions should be the y's, not the x's. The Hamiltonian isn't symmetric with respect to exchanging the y's, so if [itex]\psi_1(y_1)\psi_2(y_2)\psi_3(y3)[/itex] is a solution, [itex]\psi_1(y_2)\psi_2(y_1)\psi_3(y3)[/itex] won't generally be one.
E1: energy of a harmonic oscillator with mass m/2 (or 2m according to your result) and frequency [tex]\left(\omega=\sqrt{\frac{m}{k}}\right)[/tex] w=3;
E3: the energy of a free particle of mass 3m.
So the wave function of the ground state is simply [itex]\psi_1(y_1)\psi_2(y_2)\psi_3(y_3)[/itex]?
Where psi1 is the wavefunction of a HO with frequency w=3, psi2 is the wavefunction of the second HO and psi3 is the wavefunction of a free particle
So why would the energy be 3*(E1+E2+E3)? Wouldn't it be just E1+E2+E3?
Ah, yes, the energy is E1+E2+E3.
So, I don't care if the particles are bosons or fermions? In both cases the wave-function is
[itex]
[/itex]
I'm not sure actually. I'll see if someone else can offer some help on this point.
plug and chug
[itex]
[/itex]
Yeah, I think it doesn't matter. As far as I remember, the Pauli exclusion principle really comes from the antisymmetrization of the wavefunctions of identical fermionic particles, but in this case, the masses corresponding to y1 and y2 (and y3) are different, so the particles are distinguishable and we don't have that issue. And in any case, these are bosons you're talking about, so there's definitely no exclusion principle to worry about. Just drop everything in its lowest energy state and add them up.
Thanks to everybody for your help!
I'm wondering about the ground state wavefunctions for the fermion and boson cases. Because of the symmetry of the original Hamiltonian, I'd expect the individual particle wavefunctions to be the same and the ground state would be symmetric and antisymmetric combinations depending on the type of particle. Since the ground state wavefunctions in terms of the the x's are different, I'd expect the ground state wavefunctions in terms of the y's to be different.
Good point, I'll have to take a closer look at this...
You can swap x2 and x3 in the original coordinate transformation to get
[tex]\begin{align*}
y'_1 &= x_1-x_3 \\
y'_2 &= \frac{x_2+x_3}{2}-x_1 \\
y'_3 &= \frac{x_1+x_2+x_3}{3}
\end{align*}[/tex]
and find a solution. Other transformations derived from permuting the xi's will work as well, so the ground state solution would be
[tex]\begin{align*}
\psi(x_1,x_2,x_3) = \frac{1}{\sqrt{3}} [ &
\psi_1(x_1-x_2)\psi_2\left(\frac{x_1+x_2}{2} - x_3\right)\psi_3\left(\frac{x_1+x_2+x_3}{3}\right) + \\
& \psi_1(x_2-x_3)\psi_2\left(\frac{x_2+x_3}{2} - x_1\right)\psi_3\left(\frac{x_1+x_2+x_3}{3}\right) + \\
& \psi_1(x_3-x_1)\psi_2\left(\frac{x_3+x_1}{2} - x_2\right)\psi_3\left(\frac{x_1+x_2+x_3}{3}\right) ]
\end{align*}[/tex]
where [itex]\psi_1[/itex] and [itex]\psi_2[/itex] are the harmonic oscillator ground state wavefunctions (which are even so sign changes in the arguments don't matter) and [itex]\psi_3[/itex] is the free particle wavefunction. The ground state is symmetric so the spin part of the state would have to take care of the overall symmetry or asymmetry of the state.
Ok, so I have to return back to the original coordinates x's and make the wave function symmetric with respect to the x's. In that case the spin part would have to be symmetric as well.
Is this right?
Since in your case the particles are bosons, yes, the spin part would have to be symmetric as well so that the overall wave function is symmetric.
What is quantum mechanics exercise?
Quantum mechanics exercise is a type of problem or activity that involves applying the principles and equations of quantum mechanics to solve a specific problem or understand a particular concept.
What are the main concepts and principles of quantum mechanics?
The main concepts and principles of quantum mechanics include wave-particle duality, uncertainty principle, superposition, entanglement, and quantum tunneling. These concepts help explain the behavior of particles at the quantum level and their interactions with each other.
Why is quantum mechanics important in science?
Quantum mechanics is important in science because it provides a framework for understanding the behaviors of particles at the atomic and subatomic levels. It also helps explain many phenomena that classical mechanics cannot, such as the behavior of particles in a superposition state or entangled particles.
What are some real-world applications of quantum mechanics?
Some real-world applications of quantum mechanics include quantum computing, quantum cryptography, and quantum teleportation. It also plays a crucial role in the development of technologies such as transistors, lasers, and MRI machines.
How can I improve my understanding and skills in quantum mechanics?
To improve your understanding and skills in quantum mechanics, you can practice solving quantum mechanics exercises, attend lectures or workshops, and read textbooks or research papers. It is also helpful to have a strong foundation in mathematics and physics.
  • Linear and Abstract Algebra
