Understanding the Quantum Zeno Effect (QZE)
In summary, the Quantum Zeno Effect (QZE) can be achieved by using rotators and polarizers to cause photons to enter into a superposition of vertical and horizontal orientations. By continuously measuring and collapsing the superposed state, the probability of the photon transitioning from vertical to horizontal decreases, leading to the inhibition of state transition. This superposition is often referred to as "rotating" the photon, as it can be seen as analogous to spin in which a particle can be in a superposition of spin-up and spin-down states depending on the direction of measurement.
James MC
174
Hi there, I'm trying to understand the Quantum Zeno Effect (QZE) but am coming across some difficulties.
A common experiment used to illustrate the effect uses polarization directions of photons (http://arxiv.org/abs/1211.3498). The photons are either "vertical" or "horizontal", but one can "rotate" their polarisation direction (e.g. "by 15 degrees"). Here, one sends vertical photons down a path of six rotators (so you eventually get a 90 degree turn and hence state transition), before the photon is measured by a polarizer, which absorbs horizontal photons, transmits vertical. Now the goal is to inhibit transition from vertical to horizontal. One does this simply by measuring the polarisation after each rotator interaction (with another polarizer). The polarizer after the first rotator will re-transmit the photon down the path (with some probability?), and apparently it can be shown that if one increases the number of stages, decreasing "rotation angle" at each stage, probability of transmission to final detector increases. If there were an infinite number of stages rotation is completely inhibited yielding QZE.
If the photons can only be "vertical" or "horizontal", then how can one rotate them just by 15 degrees? What exactly do the rotators do to the photons? Do they put them into a superposition of being vertical (with high amplitude) and being horizontal (with low amp)? Then I could see how continuous measurement (collapse) would inhibit state transition. But then why call such superpositions "rotations"?
Please help! :)
The photons can only be measured as vertical or horizontal in a vertical (or horizontal) polarizer. They can have a different orientation, and you can measure a different orientation, but that is not done here.
Yes, that is an alternative description of a photon rotated by 15 degrees. The two components have a specific phase relation, leading to those 15 degrees.
Likes 1 person
Thanks, I now see how QZE works in this case: rotators cause photon to enter into superposition of (high amp) vertical and (low amp) horizontal; the quicker the subsequent polarisation measurement, the lower the probability of collapse into horizontal state; taking the limit horizontal collapse becomes impossible --> QZE.
I was confused as to why this superposing is called "rotating". But I think I get it now: when the rotator's "rotate by 15 degrees" they only superpose the photons in the orientation of the polarizer's used in the experiment; but such "rotated" photons will actually be in eigenstates of vertial/horizontal for a polarizer that is rotated by 15 degrees? Then it would be analogous to spin, where particle is only spin-up or spin-down in some direction, and in that case, superposed given a different direction.
Exactly.
1. What is the Quantum Zeno Effect (QZE)?
The Quantum Zeno Effect is a phenomenon in quantum mechanics where the act of continuously observing or measuring a system can prevent it from evolving or changing its state.
2. How does the Quantum Zeno Effect work?
The QZE is based on the concept of wave function collapse in quantum mechanics. When a system is observed or measured, its wave function collapses to a specific state and is prevented from evolving. This can occur even if the system is only observed for a short period of time.
3. What are some real-world applications of the Quantum Zeno Effect?
The QZE has potential applications in quantum computing, where it can be used to protect quantum states from decoherence. It can also be used in precision measurements and quantum cryptography.
4. Can the Quantum Zeno Effect be observed in everyday life?
No, the QZE is a phenomenon that occurs at the quantum level and cannot be observed in everyday life. It requires precise measurements and control of quantum systems.
5. Are there any limitations to the Quantum Zeno Effect?
Yes, the QZE is not a foolproof method for preventing a system from evolving. It only works for short periods of time and is limited by the accuracy and precision of measurements. It also does not work for all types of quantum systems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
