Quarter wavelength confusion
In summary, a quarter wave transmission line has a length that is equal to one fourth of the wavelength of the incident wave, which is determined by the frequency and velocity factor of the transmission line. An open circuit at one end of the line will be transformed into a short circuit at the other end, and vice versa, due to the phase shift of 90 degrees at the 1/4 wave point. This happens because of the reflection of the mismatched impedance, which causes a change in the relative phase of the wave. The result is that an open circuit will appear as a short circuit and a short circuit will appear as an open circuit when looking into the line.
hobbs125
108
Reading up on quarter wave transmission lines and I'm confused about the actual length of the line.
Is a quarter wavelength line equal to the length of the incident and reflected wave?
Or is it only equal to the length of the incident wave?
The incident wave and the reflected wave will have the same frequency.
In the same medium, they will travel at the same speed, so they will have the same wavelength.
Likes davenn
yup
so --- λ/4 ( in metres) = 300/freq(MHz) /4 x VF ( Velocity Factor) of the transmission line
eg
300/1296 = 0.23m (free space wavelength)
0.23/4 = 0.057 (free space λ/4 wavelength)
0.057 x 0.66 = 0.038m electrical λ/4
The 0.66 VF I used is just a common velocity factor of a number of coaxial cables ( there are many others)
Dave
Ok, now I understand that part (thanks btw)..But what about when people say the quarter wavelength transforms an open circuit to a short circuit and vise versa?
Can someone explain that?
What I don't understand, say you have an open circuit, a quarter wavelength transforms it into a short circuit...so does this mean the source only sees a short and maximum current flows through the entire circuit?
If you take an electrical 1/4 wave transmission line and short circuit one end, the other end appears as an open circuit when looking into the line. Conversely, if you leave one end open, the other end will appear to be a short circuit.
Imagine looking at the start and end of a 1/4 wave line. This corresponds to a phase shift of 90 degrees.
If there is an impedance mismatch at the 1/4 wave point, it will send back a reflection. By the time reflected wave returns, it will have shifted an additional 90 degrees.
Now, if the mismatch is an open, then there will be no place for the energy in the line's inductive component (current) to go, and so it will charge the capacitive part forming a voltage that reflects in-phase.
If the mismatch is a short, the capacitive component of the line will see a short, and the energy will be transferred to the inductive component. This will form a 180 degree out of phase reflection.
By the time the wave from the mismatch travels back up the 1/4 wavelength, the signal will have traveled a total of 180 degrees (down and back). The open mismatch starts in phase, but appears as 180 degrees out of phase. The short will be 180 degrees out of phase but it will have an additional 180 degrees from the delay of the line for a total of 360 degrees. Thus the returned signal appears as the incoming signal in this case.
A short appears an open and an open appears as a short.
1. What is quarter wavelength confusion?
Quarter wavelength confusion is a phenomenon that occurs when a signal is transmitted or received at a frequency that is close to a quarter of the wavelength of the medium through which it is traveling. This can result in interference and distortion of the signal.
2. How does quarter wavelength confusion affect communication?
Quarter wavelength confusion can cause signals to become distorted or weakened, making it difficult for the receiver to accurately interpret the information being transmitted. This can lead to errors in communication and can be particularly problematic in wireless communication systems.
3. What factors contribute to quarter wavelength confusion?
Quarter wavelength confusion is primarily caused by the physical characteristics of the medium through which the signal is traveling, such as the speed of propagation and the wavelength of the signal. Other factors such as interference from other signals and the quality of the transmission equipment can also contribute to this phenomenon.
4. How can quarter wavelength confusion be mitigated?
There are several techniques that can be used to reduce the impact of quarter wavelength confusion. These include using advanced modulation techniques, implementing adaptive equalization algorithms, and using frequency hopping or spread spectrum techniques to reduce interference.
5. Is quarter wavelength confusion a common issue in communication systems?
Yes, quarter wavelength confusion is a common issue in communication systems, particularly in wireless and satellite communication systems. It is important for scientists and engineers to understand this phenomenon and take steps to mitigate its effects in order to ensure reliable communication.
  • Electrical Engineering
