Atomic Clock Running Rate: Adjustment Possibilities?
In summary, the running rates of pendulum, mechanical, and electronic crystal clocks can be adjusted by changing their respective mechanisms. The running rate of an atomic clock can also be adjusted using intermediate mechanisms, by altering the number of atomic cycles counted per second. This can be seen in the synchronization and rate adjustments made on GPS clocks before and after launch. This technique does not change the behavior of the atoms, but rather the number of cycles counted to output a second.
exmarine
241
Pendulum clock running rates can be adjusted by changing the length of the pendulums. Likewise the running rates of mechanical and electronic crystal clocks can be changed and adjusted. Can the running rate of an atomic clock also be adjusted? It doesn’t seem like there could be any way to change the quantum properties of the cesium 133 atoms, or whatever they are using now. So when they set the GPS clocks to run about 37 μs slow before launch, is that just some offset between what the cesium atoms are really doing and what the physics package is broadcasting to the outside world?
There are intermediate mechanisms between the "clock atoms" in an atomic clock, and the clock's time display. When you "set the clocks to run slow", you adjust those intermediate mechanisms.
I don't know how those intermediate mechanisms actually work, but in the end, they must include some way to adjust, in effect, the number of "atomic cycles" that correspond to one "display second".
Likes russ_watters
Since one second represents about 9 billion transitions of the Caesium atom, I imagine you simply count a different number of transitions per "second" to alter your timekeeping.
Which type of adjustment are you talking about? There are two. One is synchronization, that is, two clocks can be running at the same rate, but might not be synchronized. The other is the rate. You can synchronize two clocks that are running at different rates, but of course they won't stay synchronized.
In the first part of your question you talk about rate adjustment, but then at the end your question seems to refer to a synchronization adjustment.
Anyway, I don't think that anything is done before launch that can't be undone or otherwise adjusted after launch. The atomic clock just puts out a signal that oscillates with some frequency and that signal is received at antennas. What the engineer does with that signal after it's received is a matter of choice, so it can be used to tell time only if it's interpreted correctly. Note that if the transmitter is moving relative to the receiver the emitted frequency won't match the received frequency anyway! (Doppler effect). Likewise if they are at different gravitational potentials.
Yes. There is a separate adjustment applied on board the satellites to the output of the atomic clocks before the time stamps that go into the emitted signals are generated.
For more information on this, and on the use of relativity in GPS in general, see the classic review article by Ashby:
https://link.springer.com/article/10.12942/lrr-2003-1
Note that this uses the technique of counting a different number of cycles, it doesn't change the behavior of the atoms, but you can change the number of cycles you count to output a second.
An EXTREMELY precise clock that only measures in seconds lol
1. What is an atomic clock and how does it work?
An atomic clock is a type of clock that uses the natural oscillations of atoms, typically cesium, to measure time. These oscillations are incredibly consistent and accurate, making atomic clocks the most precise timekeeping devices available.
2. Why does the atomic clock's running rate need to be adjusted?
The running rate of an atomic clock can be affected by various factors such as changes in temperature, gravitational pull, and other environmental conditions. These changes can cause the clock to drift from its original timekeeping frequency and require adjustments to maintain accuracy.
3. How often does an atomic clock need to be adjusted?
The frequency of adjustments needed for an atomic clock depends on the specific clock and its environment. Some clocks may require daily adjustments, while others may only need to be adjusted every few years.
4. What are the possible methods for adjusting the running rate of an atomic clock?
The most common method for adjusting an atomic clock's running rate is through the use of a control oscillator, which can be manually or electronically adjusted. Other methods include using temperature and pressure compensation systems or adjusting the clock's laser frequency.
5. Can the running rate of an atomic clock be adjusted to be completely accurate?
Yes, with the right adjustments and calibration, an atomic clock can be made to be extremely accurate. However, there will always be external factors that can affect the clock's running rate, so it may never be 100% accurate. The goal is to minimize any deviations from the true time as much as possible.
  • Atomic and Condensed Matter
29K
  • Materials and Chemical Engineering
