Question about conservation of momentum
In summary, the problem involves a 10kg sphere colliding with two 5kg spheres at angles of 60 and 45 degrees from the normal. The 60 degree sphere ends up traveling at 4 m/s. In order to calculate the initial velocity of the 10 kg sphere, all momentum and energy must be conserved. However, this calculation may be affected by the order of collisions and the definition of "normal" in the problem. A picture may help in understanding the problem better.
harryWin
Hi everyone,
If you have a sphere of 10kg, traveling at an initial velocity v. And this sphere collides with two other spheres, each of 5kg. One shoots off at an angle of 60 degrees from the normal, and one at 45 degrees from the normal. There sphere that fires off at 60 degrees now travels at 4 m/s. How can I calculate the initial velocity of the 10 kg sphere?
All momentum is conserved.
Cheers
Is the 10 kg sphere at rest finally? I don't think it can't be done without that fact.
did you try to do the problem yourself?
Assuming the collision is elastic, then both momentum and energy are conserved. Before the collision, all of the momentum (mv) and energy (1/2 m v^2) was in the 10 kg sphere.
You also have to assume that the 10kg sphere collided with both the 5kg spheres at the same time. I'm not sure if it works out to be the same if you assume that the collsion with the 45 degree sphere occurred first and then the collsion with the 60 degree sphere second.
Also the problem statement quotes degress from the normal, which if meant literally, means that the 60 degree ball ends up going 30 degrees from the direction that the 10kg ball was going, if "normal" means perpendicular as it usually does.
Harry, draw a picture of the problem. It makes life easter:wink:
What is the law of conservation of momentum?
The law of conservation of momentum states that the total momentum of a closed system remains constant. This means that the total amount of momentum before and after a collision or interaction must be the same.
Why is the conservation of momentum important?
The conservation of momentum is important because it is a fundamental law of physics that helps explain and predict the motion of objects. It is also crucial for understanding and analyzing collisions and interactions between objects.
How is the conservation of momentum calculated?
The conservation of momentum is calculated by multiplying the mass of an object by its velocity. In a closed system, the total momentum before and after a collision must be the same, so the total initial momentum is equal to the total final momentum.
What happens if the conservation of momentum is not conserved?
If the conservation of momentum is not conserved, then the total momentum of a closed system will change, indicating that there is an external force acting on the system. This could be due to friction, air resistance, or other external factors.
Does the conservation of momentum apply to all types of collisions?
Yes, the conservation of momentum applies to all types of collisions, including elastic and inelastic collisions. In an elastic collision, both momentum and kinetic energy are conserved, while in an inelastic collision, only momentum is conserved.
