hbj
- 8
If you have 2 coffee cups of equal volume and composition, if one is a shaped like a sector of a cylinder and the other is shaped with a more tapered bowl shape, which is more likely to spill?
Dr. Courtney said:Interesting question. It may depend on what you hold constant: distance from the top edge or volume of liquid in the cup.
hbj said:If you have 2 coffee cups of equal volume and composition, if one is a shaped like a sector of a cylinder and the other is shaped with a more tapered bowl shape, which is more likely to spill?
hbj said:My gut tells me that with the cylindrical one there'd be less inertial buildup in the direction of the spill because the forces would be more greatly diffused, but conservation of energy would say that in a round cup eventually those forces have to come around and support the spill. It would just happen later. That would give the spill vector energy time to dissipate.
hbj said:No ideas, eh?
The answer to this question is that taller, narrower cups are more prone to spilling than wider, shorter cups. This is because the center of gravity of the liquid inside a taller cup is higher, making it easier to tip over.
Taller, narrower cups have a higher center of gravity, making them easier to tip over. Additionally, the liquid inside a taller cup has more distance to travel when the cup is tipped, increasing the chances of a spill.
Yes, wider, shorter cups are less prone to spilling because they have a lower center of gravity and the liquid has less distance to travel when the cup is tipped.
Aside from cup shape, other factors that can contribute to spilling include the material of the cup (plastic cups are more slippery than paper cups), the stability of the surface the cup is on, and the amount and consistency of the liquid inside the cup.
While there is no foolproof way to prevent spills, some tips to reduce the chances include using wider, shorter cups, filling cups only partially, avoiding sudden movements while holding a cup, and using cups with lids or spill-proof mechanisms. Additionally, practicing good hand-eye coordination and being mindful while handling cups can also help prevent spills.
