Question about Friction force
In summary, the friction force between an object and a wall increases as the force applied on the object increases. However, the coefficient of friction times the normal force equation only represents the maximum force that friction can handle. In order to increase the friction force, another force must be applied in the same direction as the friction force. Additionally, the direction in which the object is being pushed (parallel or perpendicular to the wall) affects the friction force.
AlbertE97
The harder I push a book to a wall, the larger is the friction force, since friction is (coefficient of friction (times) the force I use).
Why won't the friction force make the object go up instead of stay where it is since the friction worse can get arbitrarily large while gravitational force is constant?
(not a homework question but one I thought of)(English is my 2nd language)
Friction is a reactive force, so you need another force to create the friction. In your case, the force is the weight of the book so the friction force will never be greater than the weight of the book.
What the coefficient of friction times the normal force equation tells you is the MAXIMUM force that friction can handle. So by pushing harder you do not increase friction, but if you would add another force pushing the book down (say adding weight on it), the friction force could still resists the increased downward force.
It is not clear in your original statement which direction you are pushing the book (parallel to the wall or perpendicular to the wall?).
What Jack said was very good.
Perpendicular.
The friction force is a result of the interaction between two surfaces and is always in the opposite direction of the applied force. This means that the book will not go up because the friction force is acting in the opposite direction of the force you are using to push the book towards the wall. Additionally, the friction force can only increase to a certain point before it reaches its maximum value, known as the coefficient of friction. Beyond this point, the object will either start to slide or remain stationary, depending on the direction and magnitude of the applied force. On the other hand, the gravitational force is a constant force that acts in a downward direction, and it does not depend on the force you are using to push the book towards the wall. Therefore, the friction force will not make the object go up because it is always acting in the opposite direction of the applied force and can only increase to a certain point.
1. What is friction force?
Friction force is a force that resists the relative motion or tendency of motion between two surfaces in contact with each other.
2. What factors affect friction force?
The factors that affect friction force include the nature of the surfaces in contact, the force pressing the surfaces together, and the presence of any lubricants or contaminants.
3. How is friction force measured?
Friction force is typically measured using a device called a friction force sensor, which uses a spring to measure the force required to move an object across a surface.
4. How does friction force affect motion?
Friction force acts in the opposite direction of motion, causing objects to slow down or come to a stop. It can also cause objects to heat up due to the energy lost in overcoming friction.
5. How can friction force be reduced?
Friction force can be reduced by using lubricants, such as oils or greases, between surfaces in contact. Smooth and polished surfaces also have less friction than rough surfaces.
