Homework Help: Question about heat transfer
  1. Nov 24, 2008 #1
    Hello, first question here,
    A copper rod and an aluminium rod are in thermal equilibrium with each other. Copper rod = 50cm long and the aluminium rod is 20cm. Radius of pair is 8cm.
    Copper end is heated (and maintained) at 80C , other end of pairing is 20C. k of copper is 390 and k aluminium is 210. Calculate the rate of heat flow through the pairing.
    2. Relevant equations
    Q/t = kA.(temperature difference, theta)/l
    3. The attempt at a solution
    Thanks for any help!
  3. Nov 24, 2008 #2
    mgb_phys
    That's not much of an attempt at a solution.
  4. Nov 24, 2008 #3
    I think this is the answer, not 100%,
    delta Q = delta T / SUM ( R )
    => DQ = DT / R1+R2....+...R0
    R1 = 1 / k1A , R2 = 1 / k2A ,....., R0 = 1 / k0A
  5. Nov 24, 2008 #4
    mgb_phys
    You should explain what you have done.
    What do you know about the heat flow rate in both materials?
  6. Nov 24, 2008 #5
    I just need the equation, i am not going to derive everything from first principles, you can see what i have done,
    Dt / sum of R where, R is as stated.
    I am not William Thomson attempting to experimentally derive with this conclusion, i just have asked for a verification of the above formula.
  7. Nov 24, 2008 #6
    mgb_phys
    Yes the formula is correct - it's pasted out of wikipedia.
    The point of this site is to explain physics and help people understand it.
  8. Nov 24, 2008 #7
    Thanks for your help!
  9. Nov 26, 2008 #8
    Or should it be this,
    = DQ = DT/ (L1/k1A + L2/k2A) where L = length of the rod. A = cross sectional area of rod.
    i had,
    DQ = DT / (1/k1A + 1/k2A)
    Is it dependent on the length?
