Question about limits
vincent_vega
32
suppose there is a function f(x), and it's limit as x goes to infinity is 0.
Is there a theorem that says it's derivative, f'(x), also approaches 0 as x goes to infinity?
Thanks.
Answers and Replies
micromass
Staff Emeritus
Insights Author
22,178
3,316
Probably not, since it is not true. Consider
[tex]f(x)=\frac{\sin(x^2)}{x}[/tex]
What is true, that if [itex]f^\prime(x)[/itex] has a limit, then this limit must be 0.
Bacle2
If f is differentiable in (-oo,oo) , use the mean value theorem:
f(b)-f(a)=f'(c)(b-a) . Maybe you can partition [0,oo)into [0,1],[0,2],...,[n,n+1].
Then:
f(1)=f(0)+f'(co) ;f(2)=f(1)+f'(c1) ;...f(n)=f(n-1)+f'(c_(n-1)).
Then you can find a closed form for f(n).
haruspex
Insights Author
2022 Award
39,207
8,519
micromass's example shows this isn't going to work.
Bacle2
Of course I'm assuming f'(x) is defined as x-->oo , that is implied in my argument.
Basically, take [0,b] . Then
f(b)-f(0)=f'(c)(b)
If f' is defined everywhere and we let b-->oo , then the limit cannot be 0 unless f'(c) decreases to zero.
If the OP says "its derivative approaches 0 as x --> infinity" seems to me to assume that the derivative is defined as x-->oo.
haruspex
Insights Author
2022 Award
39,207
8,519
You mean, that the limit is defined? If your argument relies on that then it needs to be stated.
Bacle2
From the OP:" it's derivative, f'(x), also approaches 0 as x goes to infinity? "
This looks to me like an assumption that f'(x) is defined as x-->oo
Bacle2
Maybe the OP can clarify the conditions of the problem to eliminate ambiguity?
haruspex
Insights Author
2022 Award
39,207
8,519
From the OP:" its derivative, f'(x), also approaches 0 as x goes to infinity? "
No, that's what he's trying to prove. He didn't say "if f' approaches a limit, that limit is 0", so the most reasonable interpretation is that he wants to prove "f' approaches a limit, and that limit is 0".
Bacle2
It's not clear to me either way. f'(x) is said to exist without any qualification; I see
no reason to assume it exists in a specific subset of the real line only, nor reason
to assume otherwise. In your interpretation, why didn't the OP say something like
is f'(x) defined, and if so , what is its limit. He refers to f'(x) which states that f'(x)
exists. It may exist somewhere or everywhere.
The problem is posed sloppily ; I think out of basic manners, the OP should clarify.
pwsnafu
85
Then it does not follow that the limit ##\lim_{x\rightarrow\infty}f'(x)## is defined. The statement "f' exists" is limited to ##x \in \mathbb{R}## because the domain of f is the real numbers and not the extended reals. What happens as ##x\rightarrow\infty## is considered a separate condition, and must explicitly be mentioned.
Suggested for: Question about limits
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
