What is the Limit of 3+dx? Understanding Limits in Calculus
  • Thread starter CuriousBanker
  • Tags
    Limits
In summary, the conversation discusses the concept of limits in calculus, specifically the limit of a function at a certain point. The function f(x)=2x is undefined at x=3, but the limit of f(x) as x approaches 3 is still 6. The concept of dx (or delta x) is also brought up, and it is explained that it is not a number, but rather a mnemonic device in calculus. The conversation also mentions the idea of "infinitely small numbers" and how they can be confusing when trying to understand limits. Overall, the conversation emphasizes the importance of understanding the definitions of limits and derivatives in calculus.
CuriousBanker
190
24
Hello.
Let us say that we have a graph f(x)=2x when x does not equal 3, and f(x)=undefined when x=3
The limit of f(x) as x→3, is still 6.
But what about the limit of 3+dx? Does it exist?
I am not up to the derivatives section of my class, so maybe there is something I am not understanding yet.
Because 3+dx is the smallest possible number after 3...and the limit of 3+dx=2(3+dx)=6+dx, if you just plug it into the function. But, immediately to the left of 3+dx, f(x) is not defined, so the graph isn't getting closer and closer to 3+dx as you approach it from the left hand side...because the graph is actually getting closer and closer to being undefined.
So would the limit not exist for 3+dx in this example?
Thanks
if you consider dx to be delta x then the limit at x+deltax = f(x+deltax)
it doesn't matter how small delta x is it could be .1 .01 .001 ... or .000000000000000000000000000000000000000000001 and smaller
and the limit is still by definition of the function f(x) still f(x)
only when x + delta x = 3 ie delta x = 0 is the limt 6 but the function is undefined. It may boggle your mind in a physical sense but when doing math you live in a geometrical world where things can have zero size (a point) zero length or zero thickness (a plane)...
But isn't DX defined to be infinitely small? So that nothing could be in between 3+DX and 3?
No matter what non-zero value you choose for dx there is always a point 3 + dx/2 between 3 + dx and 3.
True. Still, doesn't there have to be SOME number over there where there's no limit ? There has to be some endpoint before the function becomes undefined...no?
There is no limit at x if the function jumps at x. So if you find that the "limit" of f(x) at x approaching from the left is different from approaching from the right, you say there is no limit at x.
What number is it in the function I described where the function jumps?
No! As a previous post said, there is ALWAYS another number between two different real numbers.
Unless you are working with hyperreal numbers (and from your OP I don't think you are), "3 + dx" is not a number, if "dx" is supposed to mean something related to "dy/dx". Vague ideas about "infinitesimally small numbers" will only confuse you. There is no such thing as "the smallest possible number after 3".
If dx is an (ordinary) real number, if doesn't matter if it's 0.0001 or 10-1000000000000000000. There are an infinite number of different numbers between 3 and 3+10-1000000000000000000, just like there are an infinite number between 3 and 3.0001.
But don't feel too bad about having problems with this. The ancient Greeks got tied in knots as well over the paradox of Achilles and the tortoise, etc.
I doesn't jump at any number "in" the function, because you said the function was not defined for the number 3.
I understand. That's crazy
No.
In the standard texts on calculus "DX" by itself has no meaning. (In the somewhat eccentric approach of "nonstandard analysis", it might have.) The use of symbols such as "dy" and "dx" as if they were numbers is a handy way to remember certain rules in calculus. It is a mnemonic device. You can also made intuitive idea of some ideas in calculus if you think of "dy" and "dx" as numbers. However, thinking this way sometimes leads to wrong conclusions. There is no isubstitute for understanding the actual definitions of limit and derivative (the so-called epsilon-delta definitions).
What is a limit?
A limit in mathematics is a fundamental concept that describes the behavior of a function as its input approaches a certain value. It represents the value that a function approaches as its input gets closer and closer to a specific value, but may not necessarily reach.
Why are limits important?
Limits are important because they allow us to understand the behavior of a function at a specific point. They help us determine if a function is continuous, has a discontinuity, or if it approaches a finite or infinite value. Additionally, limits are used in calculus to calculate derivatives and integrals.
How do you find the limit of a function?
The limit of a function can be found by evaluating the function at values close to the desired input value. If the function approaches a specific value as the input gets closer and closer, that value is the limit. If the function approaches different values from the left and right sides of the input, the limit does not exist.
What is a one-sided limit?
A one-sided limit is the limit of a function as its input approaches a specific value from either the left or right side. It is denoted by a superscript '+' or '-' after the input value. One-sided limits are used to determine if a function has a discontinuity at a specific point.
What are the different types of limits?
There are several types of limits, including finite limits, infinite limits, left and right-sided limits, and limits at infinity. Finite limits are those that approach a specific value, while infinite limits approach either positive or negative infinity. Left and right-sided limits are used to determine the behavior of a function approaching a specific value from either side. Limits at infinity describe the behavior of a function as its input approaches positive or negative infinity.
  • Calculus
  • Calculus
