Question about proper time
  1. Aug 9, 2014 #1
    This is a conceptual problem, right out of a book.
    Say Mavis is moving in a spaceship at 0.6c relative to Stanley on earth. When Mavis just passes earth, both of them start their clocks. When Mavis reads 0.4s, what does Stanley read on his?
    Now here's the problem. I think 0.4s being proper time, the time interval will seem longer from Stanley's reference frame. So, it should be γτ where τ=0.4s.
    But the book would have me believe otherwise.
    What's wrong here?
  3. Aug 9, 2014 #2
    Matterwave
    The problem is ill posed because you are still assuming that the statement "when Mavis reads .4s" can be applied to Stanley's reference frame without caveat. So are you asking what Stanley's clock will read when STANLEY reads Mavis's clock as .4s? If so, do you take into account the time delay in the light signal Stanley must use? Or does Stanley account for this?
  4. Aug 9, 2014 #3
    I'm sorry if I was unclear. It is : ...Mavis reads 0.4s on her timer ...
  5. Aug 9, 2014 #4
    What does the book say?
    They are both going to read their own proper time on their own clocks.
    Stanley will read a shorter time than 0.4s while looking at Mavis's clock because Stanley is in the "laboratory frame" and Mavis is in the primed or proper time frame.
    T=t'√(1-v^2/c^2)
  6. Aug 9, 2014 #5
    stevendaryl
    Staff Emeritus
    When you ask a question such as "When Mavis's clock reads 0.4s, what time does Stanley's clock read?", you are really asking a question about simultaneity of events. You are asking "What is happening at Stanley's clock at the same time that Mavis's clock reads 0.4s?" The problem with that question is that the notion of two distant events happening at the "same time" (or "simultaneously") is relative (which is why it's call "relativity"). Simultaneity of distant events is relative.
    So let's name a few events:
    [itex]e_1[/itex] = the event where Mavis' clock reads 0.4s/γ
    [itex]e_2[/itex] = the event where Mavis' clock reads 0.4s
    [itex]e_3[/itex] = the event where Mavis' clock reads γ 0.4s
    [itex]e_4[/itex] = the event where Stanley's clock reads 0.4s/γ
    [itex]e_5[/itex] = the event where Stanley's clock reads 0.4s
    [itex]e_6[/itex] = the event where Stanley's clock reads γ 0.4s
    In Mavis's frame,
    • [itex]e_1[/itex] happens first.
    • [itex]e_2[/itex] happens at the same time as [itex]e_4[/itex]
    • [itex]e_3[/itex] happens at the same time as [itex]e_5[/itex]
    In Stanley's frame,
    • [itex]e_4[/itex] happens first.
    • [itex]e_5[/itex] happens at the same time as [itex]e_1[/itex]
    • [itex]e_6[/itex] happens at the same time as [itex]e_2[/itex]
    So, according to Mavis, Stanley's clock is running slow, and according to Stanley, Mavis' clock is running slow.
  7. Aug 9, 2014 #6
    Matterwave
    But this act of Mavis reading .4s on her timer does not describe a universal time, that's the whole point of relativity. This "Mavis reads .4s on her timer" happens at different times according to different people, so are you asking at what time Stanley would say Mavis reads .4s on her timer?
  8. Aug 9, 2014 #7
    The book says Stanley will measure a shorter time of 0.32s.
    I'll directly quote the book:
  9. Aug 9, 2014 #8
    Well, that sounds about right to me, without doing the actual calculation..
    It's shorter than 0.4s.
  10. Aug 9, 2014 #9
    stevendaryl
    Staff Emeritus
    So, let me put some numbers to the events, using γ=0.8
    • [itex]e_1[/itex] = Mavis' clock shows time [itex]t'=0.32s[/itex]
    • [itex]e_2[/itex] = Mavis' clock shows time [itex]t'=0.4s[/itex]
    • [itex]e_3[/itex] = Mavis' clock shows time [itex]t'=0.5s[/itex]
    • [itex]e_4[/itex] = Stanley's clock shows time [itex]t=0.32s[/itex]
    • [itex]e_5[/itex] = Stanley's clock shows time [itex]t=0.4s[/itex]
    • [itex]e_6[/itex] = Stanley's clock shows time [itex]t=0.5s[/itex]
    In Mavis' rest frame, [itex]e_2[/itex] and [itex]e_4[/itex] are simultaneous.
    In Stanley's rest frame, [itex]e_2[/itex] and [itex]e_6[/itex] are simultaneous.
  11. Aug 9, 2014 #10
    I like the way you set up that table, stevendaryl, kind of just spells it all out there.
  12. Aug 10, 2014 #11
    The table cleared it up. So, what was actually being asked was the time from Mavis's perspective. I hadn't realized that.
    Thank you!
  13. Aug 10, 2014 #12
    ghwellsjr
    I am in total agreement with you.
    The phrase "When Mavis" doesn't have to imply Mavis's frame as the authors insist. They previously used the phrase in the statement "When Mavis just passes the earth" which is clearly not Mavis's frame or it would have been stated as "When the earth just passes Mavis". In fact everything in the problem is stated as specified according to Stanley's earth frame so there is no reason to assume that the question has jumped to Mavis's frame.
    So if the authors insist that there is only one correct answer (which there isn't), then it must be according to the one and only frame that they have been talking about all along.
Loading...
