Radio Signal Basics: Generating & Receiving
  • Thread starter wannab
  • Tags
    Radio
In summary: To the base or the collector? Would you be able to show me a circuit diagram where this oscillation...Yes, you could connect the collector to the base.
wannab
32
What are the most basic components I need to generate and receive a radio signal and how would I arrange them?
For instance imagine I want to make an LED in my bedroom flicker when my front door opens. Firstly how would I make this happen at the most basic level, so that some signal is received and secondly how would I amplify this signal so that, for instance, the light stays on for 5 seconds? I'm guessing for the latter I just need to learn how a 555 chip works so I'm more interested in the former question.
Thanks in advance.
Thanks in advance.
The easiest way is to send the signal along wires. Fit a switch on the door jamb.
Do this with low voltage ac current (not batteries) and the signal IS INDEED a traveling wave field (radio!) guided by the wire.
To light the led you need a source of power. 2 volts at 25 mA and a resistor to limit the current below 30 mA..
To send the signal wirelessly, you need an oscillator.
Any one will do. A transistor with positive feedback! A 555 chip wired fo feedback.
But TRY not to annoy the neighbours - choose a frequency (and one alone!) not in the radio bands.
How about using ultrasound (provided you have no dog,cat ar canary)
Piezo-electric transducers are cheap
Get two. Rig up one as transmitter (oscillator) - the other as receiver
The old Space Command" Zenith Tvs used ultrasound. In your case a littl "hammer" strikes an aluminium rod (in the Space command unit) (think of a xylophone) and the receiver picks up the untrasound and switches on your LED instead of the TV.
Go to a model shop and ask about model airoplane and car radio-control components.
They might have a "broken" model they'd give you the radio parts from.
Above all, have FUN.
A transistor is capable of sending a radio signal? How does this work? How would I receive it?
You need a power supply - enough to turn on the transistor 2 or 3 volts
Feed the transistors oupput to its input, via a capacitor to block dc
It will oscillate.
This will launch a radio wave - using the tansistor circuit wires as antenna
Any wire or loop will pick up this signal
Another transistor will amplify it (use it to turn on current from a powr supply)
This current can light your LED
It will oscillate.
To the base or the collector? Would you be able to show me a circuit diagram where this oscillation occurs?
The "Grounded emmitter" is the easiest. From the power supply to ground joinn 2 1K resistors in series
If the supply is 3v the mid point will be at 1.5 volts.
This would turn the transistor on, if of the right type for the polarity of your power supply.
Though 1.5v from base to emitter (emitter grounded) would turn the transistor on, it is thermally unstable.
To stabilise it we apply "negative feedback"
All this means is "The higher the current the LOWER the base volts".
This is so SIMPLE to do. Put a 470 ohn resistor from ground to emitter as the only emitter connection.
Now it will sit there with current flowing.
Now to get an output voltage, put a 1K resistor from collector to power supply so the collector current flows thru it
Now join a 1 uF capacitor from collector to base
Expect oscillations around t=1/RC = 1/(500 times 10^-6) = 2 KHz
Hear these with headpones.
To up the frequency to 200 KHz try .01 uF
If it needs more gain (unlikely with modern transistors) place a .1uF capacitor in parallel with the 470 ohm resistor
Have FUN
1. What is a radio signal?
A radio signal is an electromagnetic wave that carries information or data through the air. It is generated by a transmitter and received by a receiver, usually in the form of radio waves.
2. How is a radio signal generated?
A radio signal is generated by an electronic device called a transmitter. The transmitter converts an audio or data signal into an electromagnetic wave, which is then transmitted through an antenna.
3. What factors affect the strength of a radio signal?
The strength of a radio signal is affected by several factors, including the power of the transmitter, the type and size of the antenna, the frequency of the signal, and any obstacles or interference in the transmission path.
4. How is a radio signal received?
A radio signal is received by an electronic device called a receiver. The receiver picks up the electromagnetic waves transmitted by the transmitter and converts them back into the original audio or data signal.
5. What is the purpose of modulation in radio signals?
Modulation is the process of changing the characteristics of a radio signal in order to carry information. It is necessary because radio waves can only travel in a straight line, so modulation allows for the signal to be transmitted over long distances and through obstacles.
  • Electrical Engineering
