Question about tension?
  1. Jul 1, 2010 #1
    A 20 kg loudspeaker is suspended 2.0 m below the ceiling by two cables that are each 30 degrees from the vertical. What is the tension in the cables
    2. Relevant equations
    3. The attempt at a solution
    Here is how I solved it but I am not sure if it is right. Also, I don't understand how to use the 2.0 meters given in the problems statements. Anyways, here goes:
    Fnetx=Wx + T1x + T2x =max=0
    0 + T1 - T2=0
    T1sinθ -T2sinθ=0
    Fnety=wy + T1y + T2y=may=0
    -w + T1 + T2=0
    (20 * -9.8) + T1cosθ + T2cosθ=0
    -196 + (T1 + T2)(cosθ)=0
    (T1 + T2)(cosθ)=196
    (T1 + T2)=196/cos(30)
    (T1 + T2)=226.3
    Since T1=T2, then 226.3/2=113 N. Therefore 113 N is the tension for both ropes?
    Is this correct?
  3. Jul 1, 2010 #2
    somebody please help!
  4. Jul 1, 2010 #3
    Yes! The 2 meters is not relevant to the solution of this problem.
  5. Jul 1, 2010 #4
    So the answer is 113 N for both cables? And my work is correct?
  6. Jul 1, 2010 #5
    Yes, the tension is 113 N in each cable. In your work, though, you noted
    Fnetx=Wx + T1x + T2x =max=0, correct, but then you said
    0 + T1 - T2=0, instead of saying 0 +T1sintheta -T2 sin theta = 0, which you later corrected. You did the same thing in the y direction, looks like just a typo.
  7. Jul 1, 2010 #6
    Thank you. I'll make sure not to make that mistake again.
Similar Threads - Question tension Date
Quick Question about Torque and Tension Jan 19, 2018
Question regarding tension Jan 29, 2017
A Question on surface tension Nov 17, 2016
Question about Centripetal Force May 22, 2016
