Power of Water: Why is it so Important?
  • Thread starter Cod
  • Tags
    Water
In summary, water is a powerful force because it has a lot of mass and momentum, it is a great solvent, it is suitable for propagating life, and it has a lot of other properties.
Cod
325
What makes water such a powerful force (if not the most powerful force) on Earth? Or is water a powerful force regardless of atmosphere, planet, etc.?
This may be a stupid question, but I'd really like someone to explain this to me if they can. Its a question that I have no been able to figure out myself.
Any help is greatly appreciated.
Can you please elaborate on what you mean by a powerful force? Are you talking in terms of an erosional force like a river (or glacier), a destructive force like the recent tsunami in Asia, an atmospheric force like its role in storm formation, its ability to support life on this planet, or other things?
Water is not a force. The energy of the sun and geothermal energy are the main forces that drive the dynamics of Earth. Water is just the medium by which those sources conduct energy.
All of the above really. Sorry I wasn't more specific in my original post.
Water has a density of 1000 kg/m3, and then multiply that by 100's or 1000's of m3 - that is a lot of mass. If the mass is moving - that produces a lot of momentum, that when it impacts a non-moving object, produces a lot of force.
Also remember, wind, which has a density of about 1.25 kg/m3 (or 800 times less than water), can exert significant force at high enough velocity.
As for erosion, it is a continuous process. In the case of water or air, suspend solids (sand or soil, pebbles, stones, rocks, boulders in water and dust or sand in air) assist the erosion process.
It's a matter of mass and momentum.
Some quick math:
If a section of the tsunami was an average of 10m high, 300m long, and 1000m wide, that's 3 billion kg of water. At a speed of 10m/s, that's 150 billion joules of energy. A ton of TNT contains about 4 billion joules of energy, so that's ~37 tons of TNT. Put another way, pile pickup-truckloads of TNT every 27 meters along the beach and you have a rough approximation of the energy contained in all that moving water.
One thing to note, when a ton of TNT explodes, the energy goes in all directions (including up). When the wave hits, all the energy goes in the same direction, so its actually even more.
If the oceans were filled with oil, or alcohol, or mercury, a tsunami would be no less devastating.
As an agent of erosion, water is pretty good because it dissolves many salts, and also because it expands upon freezing. Hydrochloric acid would probably be much more erosive (not to add corrosive) than water.
In short, water is not a powerful force in the way you think it is. This is merely folklore passed on from the ancients.
However, water is beautifully suited to propagating life on earth. It exhibits all three states at ambient temperatures. It is a great solvent for inorganic salts yet perfectly harmless to organic stuff. It has a huge specific heat capacity. It expands on freezing. And it's a colorless liquid, among several other things.
1. Why is water considered the most important substance on Earth?
Water is considered the most important substance on Earth because it is essential for all known forms of life. It makes up about 71% of the Earth's surface and is a major component of all living organisms. Water is also crucial for many physical and chemical processes, such as photosynthesis and digestion.
2. How does water have the power to shape the Earth's surface?
Water has the power to shape the Earth's surface through erosion and weathering. This is because water can dissolve and carry away rocks and sediment, carve canyons and valleys, and create features such as waterfalls and beaches. Water also plays a role in shaping the Earth's surface through processes such as glaciation and deposition.
3. What makes water a unique and powerful solvent?
Water is a unique and powerful solvent due to its polarity and ability to form hydrogen bonds. This allows water to dissolve a wide range of substances, including salts, sugars, and gases. It also helps to transport nutrients and waste products within living organisms and plays a crucial role in many biochemical reactions.
4. How does water regulate the Earth's climate?
Water helps regulate the Earth's climate through the water cycle, also known as the hydrologic cycle. This involves the continuous movement of water between the Earth's surface, atmosphere, and underground. Water also has a high specific heat capacity, meaning it can absorb and release large amounts of heat without changing temperature significantly. This helps to moderate the Earth's temperature and regulate the climate.
5. What are the potential consequences of a water shortage?
A water shortage can have severe consequences on both the environment and human populations. It can lead to droughts, famine, and displacement of people. It can also cause damage to ecosystems, loss of biodiversity, and water-related conflicts. Without access to clean water, people are at risk of dehydration, disease, and even death. Therefore, it is essential to conserve and manage our water resources carefully.
30K
  • Biology and Medical
  • General Engineering
  • Electrical Engineering
