Question: ice forming on wing
  1. Sep 14, 2006 #1
    For eg Boeing 777 , there's only anti ice feature on mid span of wing only, while wing root and tip area are not. Anyone know the reason why wing tip and root are less likely to form ice?
  3. Sep 14, 2006 #2
    Danger
    This is only a guess, so don't take it as fact. I've never looked into that, because I've never heard of it before. Mechanical de-icers always used to be along the leading edge. The spray-on ones cover the whole wing.
    All that I can surmise without investigating is that in flight the 'bow wave' of the nose diverts airflow outside of the root area, while the inherent flexiblility of the wings will crack off stuff trying to form on the tips. Again, that's only speculation. Can't wait to see what Fred and his ilk have to explain it for real.
  4. Sep 14, 2006 #3
    chroot
    Staff Emeritus
    I have to speculate, because I don't know for sure... Perhaps because most of the lift is generated there, perhaps a change in airfoil shape is most catastrophic there.
    Structural ice adds weight to an aircraft, and this is bad -- but, even worse, ice in the wrong place can change the shape of the leading edge of an airfoil, causing it to create much, much less lift that it should.
    - Warren
  5. Sep 15, 2006 #4
    russ_watters
    Staff: Mentor
    The leading edge of the wing is the laminar region and thus the flow is most unstable. A small disruption just kills the lift whereas further back, the flow is turbulent and not as easily disrupted.
  6. Sep 15, 2006 #5
    i agree with wat u said, but my question is comparing the leading edge of the root,mid span and tip.
  7. Sep 15, 2006 #6
    chroot
    Staff Emeritus
    AFAIK, the root and tip are not aerodynamically shaped for efficient lift -- meaning the mid-span is where most of the lift is generated, and where icing would be the most problematic.
    - Warren
  8. Sep 15, 2006 #7
    Hi Folks,
    I always thought that the elliptical lift distribution was the holy grail, so that most of the lift is produced at the root, with a decreasing lift profile as you move outboard. This also serves to minimize the tip vorticity.
    There could be another reason that the anti-icing (wing heater) system is centered at the middle of the wing... the fact that the 777's engines are wing-mounted at about that position. And hot bleed air is generally used to heat the wings. From this website:
    http://www.meriweather.com/777/over/antiice.html [Broken]
    AFAIK, if you directly heat the middle of the wing with bleed air, you can generally keep the temp of the tip and the root above the freezing point where ice will not form over the lift-producing leading edge of the wing. Another aspect is that the further away from the engine (the heat source) that you try to transport the heat, the more heat (total energy) you will "steal" from the engine. So by not running the anti ice ducts too far away from the engines (just far enough) you minimize the total thermal load on the engine due to anti-ice heat demands.
    I could be wrong, however.
    Rainman
  9. Sep 16, 2006 #8
    Danger
    Hell of a post there, Rainman. To give you an indication of how long it's been since I was flying... I didn't even know that they were using the engines for de-icing. The last that I knew of was resistance heating from inside the wing. Thanks for the update.
  10. Oct 3, 2006 #9
    Although more lift is created near the root of the wing, wing tip stalling is actually more dangerous because it creates a stronger rolling moment around the longitudinal axis. In most wing designs the root angle of attack is therefore larger than at the tip.
