Derivative trigonometric functions help
In summary: So in summary, you tried to solve a problem by taking a second derivative of x/dt=xsinx, but were not sure how to start. You also found it confusing because dx/dt does not have to be an explicit function of x. You simplified the problem by taking the derivative with respect to t and ended up with dx/dt(sinx+xcosx).
ada0713
45
Find d[tex]^{2}[/tex]x/dt[tex]^{2}[/tex] as a function of x if dx/dt=xsinx
I tried to solve the problem by taking a second derivative of dx/dt=xsinx
but I was not sure how to start. Also, it is confusing because
doesn't have to be dx/dt=tsint in order to make sense (since i should
take the derivatice w/ respect to t, not x)?
I'm totally lost here, please help me with the start,
and i'll try to figure out the rest!
Fortunately your question "doesn't have to be dx/dt=tsint in order to make sense?" made me look at the question again! I had thought you were just asking for the second derivative of x sin(x) and obviously you aren't.
Yes, you need to differentiate with respect to t, not x. But dx/dt does NOT have to be an explicit function of x. Since x itself is a function of t, x sin(x) is an implicit function of t. If you are told that dx/dt= f(x), use the chain rule:
[tex]\frac{d^2 x}{dt^2}= \frac{df}{dt}= \frac{df}{dx}\frac{dx}{dt}[/tex]
Just like "implicit differentiation" except this time you already know what dx/dt is.
so..
This is what i did.
since x=f(t)
f'(t)=dx/dt
so, x'=dx/dt
if i take the second derivative of dy/dt,
it'll be like
(dy/dt)'= 1*(dx/dt)sinx + x*cosx* (dx/dt)
the red part is where i used the chain rule.
since I don't know the actual function of x, I just set the derivative of it as
dx/dt (because I'm taking derivative w/ respect to t)
and since this is basically the derivative of of product, i used
a product rule to do the rest.
I simplfied it and ended up with
dx/dt(sinx+xcosx)
am i right..? my answer looks quite a bit complicated,,
That looks right.
1. What are the basic derivative trigonometric functions?
The basic derivative trigonometric functions are sine, cosine, and tangent.
2. How do you find the derivative of a trigonometric function?
The derivative of a trigonometric function can be found using the chain rule and the derivative rules for sine, cosine, and tangent.
3. Can you provide an example of finding the derivative of a trigonometric function?
Sure, the derivative of sin(x) is cos(x) and the derivative of cos(x) is -sin(x). So, the derivative of 2sin(x) + 3cos(x) would be 2cos(x) - 3sin(x).
4. Why are derivative trigonometric functions important in mathematics?
Derivative trigonometric functions are important because they allow us to calculate the rate of change of trigonometric functions, which is useful in many real-world applications, such as physics and engineering.
5. Are there any common mistakes to watch out for when finding derivative trigonometric functions?
Yes, common mistakes include forgetting to use the chain rule, not simplifying the expression, and forgetting to include the negative sign when taking the derivative of cos(x).
