1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Question on Differentiation
  1. Jul 2, 2008 #1
    I'm having some trouble with the following question, it was on a test previously and I haven't been able to figure it out :/
    Let V=4*L^3 cm^3, where dl/dt=10*t cm/s. Find dV/dt at t=0.1 second
  3. Jul 2, 2008 #2
    rock.freak667
    Since V is a function of L.
    What you can do is use the chain rule and say that
    [tex]\frac{dV}{dt}=\frac{dV}{dL} \times \frac{dL}{dt}[/tex]
  4. Jul 2, 2008 #3
    Right, following the chain rule I do get dv/dt=120*L^2, I tried before to get L in terms of t, via integration but of course that gives 5t^2+C whereas C would pose as a problem since I've no way of obtaining it, so I can't get a numerical solution I just get a solution in terms of L...
  5. Jul 2, 2008 #4
    rock.freak667
    [tex]\frac{dV}{dt}=12L^2[/tex]
    You don't need L in terms of t when they tell you that [itex]\frac{dL}{dt}=10t[/itex]
  6. Jul 2, 2008 #5
    so then this question doesn't have a numerical solution, only one in terms of L?
  7. Jul 2, 2008 #6
    rock.freak667
    Is that all the data presented in the question? you don't have the initial length or any length at a particular time?
  8. Jul 2, 2008 #7
    that's about it, my first post states out the entire question, no initial values, at all...and thanks by the way.
  9. Jul 2, 2008 #8
    rock.freak667
    Well without a length at any particular time, you can't find a numerical solution.
  10. Jul 15, 2008 #9
    I would think that as you are given dl/dt and you can work out dv/dl and you are looking for dv/dt
    dv/dl [12L^3] dL = 12L^2 dl/dt = 10t
    dv/dl x dl/dt... the dl's cancel to leave dv/dt
    Wouldn't that be the chain rule?
    Perhaps u'v + v'u
    or in this case v't + t'v
    NO WAIT!!!!! So much simpler.
    Look at it as...
    the change in v over the change in time. The change in V is simply 12L^3 , so dv/dt = 12L^3 / dt ( it would seem something is missing as one is not sure the intial time, I would have to assume time began at zero and so dt would be 0.1 s,
    thus dv/dt = 12L^3/0.1 = 120L^3 (I think).
    eta: oh I missed he t=0.1 s
  11. Jul 15, 2008 #10
    Isn't dv/dt the differential of v with respect to t? Then surely the answer shouldnt be given in 'L' Also you have worked out dv/dl not dv/dt
    I think the chain rule is needed.
  12. Jul 16, 2008 #11
    rock.freak667
    Yes that was a typo on my part.
Have something to add?
Similar Discussions: Question on Differentiation
Loading...
