ahben86
- 3
I was hoping someone could help out, I am working out a problem with Kirchoff's Laws and cannot seem to get the math to work out properly, at least I think the math is not working properly.
I was hoping to run it by someone here.
The circuit is as follows:
A battery of 24 V on one end connected to two parallel resistors with values of 5 Ω and 7 Ω.
Mesh one will be the loop between the battery and the 5 Ω resistor, which has a current of I1.
Mesh two will be the loop between the 5 Ω resistor and the 7 Ω resistor, which has current of I2.
The equations I set up are as follows:
0 = -24 + 5*(I1 - I2)
0 = 7*I2 + 5*(I2 - I1)
After calculating the values I obtained these numbers:
I1 = 8.229 A
I2 = 3.429 A
I tried verifying these answers by using V = I*R
Finding Req to be 2.917 Ω.
Therefore I = V/R and I = 8.228 A and since the current from I1 is the same value it seems that the values obtained from Kirchoff's Laws do not match the Ohm's Law current.
I am uncertain if I am not realizing a concept but this does not make sense to me.
Any help is appreciated.
Thank you,
A.B.
I1 = 8.229 A
I2 = 3.429 A
Thank you,
A.B.
