Probability of Boys and Girls in a Randomly Lined Up Group: Permutation Question
In summary, In this conversation, a group of 5 boys and 10 girls are lined up in random order. Each of the 15 permutations is assumed to be equally likely. a) What is the probability that the person in the 4th position is a boy? b) What is the probability that a particular boy is in the 3rd position?
chocok
A group of 5 boys and 10 girls is lined up in random order-that is, each of the 15! permutaions is assumed to be equally likely.
i tried to list out 1 possible combination but it gets pretty ugly since there are a total of 15 choices.. can someone please help?
I'm not sure about this, so I'll take a guess at what I think.
For a), wouldn't you just find the number of possible ways to organize the line such that the 4th position is a boy? Once you got that, you can just compare it with the total permutation, which should give you the probability of that happening.
For b), it's something extremely similiar, but you have to remember that you cannot change position 3.
Is your problem with the idea of finding the number of ways to organize the line with some conditions?
If that's the case, try googling some sample exercises about permutations. After a couple, you'll understand enough to apply it to this situation. Practice is what makes perfect.
Thanks for replying.
for part a), If I just look at the first 3 picks, i can either have 0,1,2,3 boys and the 4th postion have to be a boy. I calculated the probabilities of each of them individually and they added up to be 1/3. For which i multiplied it by 11! (5-15th selection) and divided by 15! (total permutation), but i ended up with 1.0175x10^-5 which seems way to small to be a correct answer..
what did i do wrong in my reasoning??
The precise position isn't relevant. What may be confusing you is that "permutations" are not at all relevant. Suppose, out of 5 boys and 10 girls, you choose one person at random (each equally likely to be picked). What is the probability that the person is a boy? (That should be easy.)
"What is the probability that a particular boy is in the third position."
Given that the person in the third position is a boy?? Or given that the person in the fourth position was a boy? If neither of those is intended: there are 15 persons who are all equally likely to be chosen. What is the probability that a specific one of them will be chosen?
If it is intended that the person in the third position is a boy, then there are 5 persons all equally likely to be chosen.
Halls of Ivy: The precise position isn't relevant.
I remember an old Mutt and Jeff cartoon. As they are traveling on a train, Jeff asks Mutt, "How many sheep do you think are in that herd we just passed?"
Mutt replies, "876."
"That's amazing! You mean you counted every one as the train sped past?"
"No, not really. I just counted the legs and divided by four."
1. What is a permutation?
A permutation is a way of arranging a set of objects in a specific order. It is a mathematical concept that involves rearranging the elements of a set or sequence.
2. How many permutations are possible for a given set of objects?
The number of possible permutations for a set of n objects is n factorial (n!). For example, if there are 3 objects, there are 3! = 3 x 2 x 1 = 6 possible permutations.
3. What is the difference between a permutation and a combination?
A permutation involves arranging objects in a specific order, while a combination is a selection of objects without regard to their order. For example, ABC and ACB are different permutations, but they are the same combination.
4. How is permutation used in real life?
Permutation is used in various fields, such as computer science, statistics, and genetics. In computer science, it is used for data encryption and password generation. In statistics, it is used for analyzing data sets. In genetics, it is used to understand the possible combinations of genetic traits.
5. What is the formula for calculating permutations?
The formula for calculating permutations is n! / (n-r)!, where n is the total number of objects and r is the number of objects being chosen. This is also known as the nPn formula, where nPn = n!.
  • General Math
  • General Math
