Question regarding flow rate?
In summary, the balance reading will decrease when the water flow from the faucet is suddenly stopped due to the momentum of the water in the glass moving upwards and causing a net force in the upward direction. This momentum is caused by the breaking of equilibrium when the water flow is stopped. Additionally, the normal force from the glass and balance on the water also contribute to the decrease in the balance reading. The spring and pointer of the balance also play a role in the reading decrease, as the movement of the pointer and stretching of the spring are due to the forces acting on the water and balance.
PhyIsOhSoHard
158
Water from a faucet flows into a glass on a balance. The balance reacts quickly and the reading is increasing steadily. If the water flow is stopped suddently, how will the balance reading change compared to a reading just before the stop? Will the balance reading increase? Decrease? Or not change?
Attempt at an solution
Apparently the correct answer is that the balance reading will decrease. But why? I don't get it?
Hi PhyIsOhSoHard! :smile:
Hint: force = rate of change of momentum …
what is causing the momentum to change? :wink:
Likes 1 person
Hi!
I really have no idea. Gravitational force?
when the water comes out of the faucet, it has momentum
as it falls, that momentum even becomes slightly more (because of gravity)
after that, what causes that momentum to change?​
Hmm, Newton's 3rd law? Cause it hits the water already in the glass, and that water hits back?
yeees …
do you think you could use a physics word, rather than "hits"? :wink:
tiny-tim said:
yeees …
Penetrates? Contacts? It does actions and the other does reactions? :(
has your professor covered force yet? :smile:
Likes 1 person
Ohhh, you mean momentum as in this?
##\vec{F}=\vec{F_S}+\vec{F_B}=\frac{\partial}{\partial t}\int_{CV}\vec{V}\rho d∀+\int_{CS}\vec{V}\rho\vec{V}\cdot\vec{A}##
So we have a control volume that is the water inside the glass.
If we assume steady flow then the flow is not dependent of time. Our body force is the gravitational force and we have no pressures to account for on the surface.
So on our control surface we have ##\vec{Mg}_y=\int_{CS}\vec{V}\rho\vec{V}\cdot\vec{A}## and we can neglect density if we assume incompressible fluid so that leaves with the momentum:
##\vec{Mg}_y=\int_{CS}\vec{V}\vec{V}\cdot\vec{A}##
But how can you conclude a decrease in the reading based on that? Is it possible?
"control volume"? "control surface"?
are you majoring in engineering? :confused:
let's keep this simple
at any instant, there are three bodies:
i] the falling water
ii] the water in the glass (and the glass itself)
iii] the scale
do three free body diagrams, for each of the three bodies …
where does the force come from that stops the falling water?​
Likes 1 person
iii] the scale
Ya, this is for my fluid mechanics class. I was just hoping there were some of the equations in the chapter that could explain the phenomenon and since the equation is called momentum in my book, I thought maybe that was it lol
i] We have a force down
ii] The water in the glass exerts a reaction force (parallel and opposite in direction to the force coming from the water faucet
iii] The scale exerts a normal force
So as the water from the faucet flows into the glass, we have an equilibrium. When the water from the faucet suddenly stops, the equilibrium is broken and we have an acceleration (momentum) and a net force pointing upwards and since the acceleration by Newton's second law is defined as force divided by mass, the mass of the water inside the glass moves in the same direction as the acceleration (upwards parallel with the reaction force from ii]) and thus the reading will decrease for a very quick moment because of the mass moving upwards at that instant?
are you talking about the moment the faucet is turned off?
if so, you have a strange idea of what "equilibrium" is :redface:
i'm asking about the forces while the water is still flowing …
while the faucet is still on, what stops the falling water from falling?
(and you might want to mention the spring inside the scale, the one that's attached to the pointer :wink:)
Likes 1 person
Oh yeah. If the acceleration is constant then there's still equilibrium right? :)
You mean the normal force that the glass and balance exerts on the water?
how about the spring and the pointer?
what makes the pointer move?
1. What is flow rate and why is it important?
Flow rate is the measure of how much fluid or gas moves through a particular point in a given amount of time. It is important because it helps us understand and control processes involving liquids and gases, such as water flow in pipes, air flow in ventilation systems, and blood flow in the body.
2. How is flow rate measured?
Flow rate can be measured using various instruments such as flow meters, pitot tubes, orifice meters, and Venturi meters. These devices measure the velocity of the fluid or gas and calculate the flow rate based on the cross-sectional area of the pipe or channel.
3. What factors affect flow rate?
The flow rate of a fluid or gas is affected by several factors including the velocity of the fluid, the size and shape of the pipe or channel, the fluid's viscosity and density, and the presence of any obstacles or restrictions in the flow path.
4. How can flow rate be increased or decreased?
The flow rate can be increased by increasing the velocity of the fluid or by increasing the cross-sectional area of the pipe or channel. It can be decreased by decreasing the velocity or reducing the cross-sectional area. However, these changes may also have other consequences, such as changes in pressure and energy losses.
5. What are some common applications of flow rate in science and engineering?
Flow rate is an important concept in various fields of science and engineering, including fluid mechanics, hydraulics, aerodynamics, and chemical engineering. It is used to design and analyze systems involving liquids and gases, such as pumps, turbines, pipelines, and ventilation systems. It also plays a crucial role in environmental studies, medical devices, and industrial processes.
