Question regarding Moments
  • Thread starter Robm50
"A child and her father are playing on a seesaw. They are exactly balanced when the girl (mass 46 kg) sits at the end of the seesaw, 2.75m from the pivot. If her father weighs 824 N, how far is he from the pivot?"
(sum of) clockwise moment(s) = (sum of) anticlockwise moment(s)
moment (Nm) = force (N) * perpendicular distance from pivot to line of action of the force (m)
girl is mass 46kg (kilograms) whilst her father has weight 824 N (newtons)?!
46 x 2.75 = y x 824
126.5 = 6.51 * 824
y = 6.51?
= 6.51 metres from pivot?
Please show how you got your answer =]
Thanks,
Robm50
Answers and Replies
Orodruin
Staff Emeritus
Insights Author
6,626
126.5 = 6.51 * 824
6.51 * 824 is definitely larger than 126.5 - you have made an arithmetic error.
Edit: Also, the girl has mass 46 kg - not weight 46 N, which is what you seem to be assuming.
How would I go about solving this problem, then?
Orodruin
Staff Emeritus
Insights Author
6,626
What is the weight corresponding to a mass of 46 kg?
That's exactly my problem; I have no idea how to find such a weight.
Orodruin
Staff Emeritus
Insights Author
6,626
So, what is weight? If you do not know this you need to go back to your course literature and restudy gravitational forces.
Weight is the result of the gravitational attraction pulling an object's mass particles towards the Earth
Is that correct?
Orodruin
Staff Emeritus
Insights Author
6,626
Weight is the force with which gravitation pulls an object towards the ground. So how do you compute this force based on the mass of an object?
Would it be as simple as by using the formula:
"Weight = Mass * Gravitational Field Strength"?
Orodruin
Staff Emeritus
Insights Author
6,626
Yes. This will give you the weight of an object.
Thankyou for your help, Sir.
Related Threads on Question regarding Moments
  • Last Post
  • Last Post
  • Last Post
30K
  • Last Post
  • Last Post
