Freedom
- 4
1.Which of the following experimental techniques reduces the systematic error of the quantity being investigated?
A.timing a large number of oscillations to find a period
B.measuring the diameter of a wire repeatedly and calculating the average
C.adjusting an ammeter to remove its zero error before measuring a current
D.using a metre rule graduated in 0.5 mm rather than 1 mm to measure diameter
2.In an experiment to determine the period of oscillation,T, of an oscillation, the time ,t
,taken. It is found that the time for 20 complete oscillations is 36.5 +/- 0.2 s.Which of the following sattements is/are correct?
A.The reading error in t can be reduced by counting 100 oscillations.
B.The percent error in T is the same as that in t.
C.The period T determined should be quoted as 1.83 +/- 0.01 s.
